node-red-contrib-melcloud-atw 1.2.4
Mitsubishi Melcloud API connection for Air-to-Water(ATW) devices
npm install node-red-contrib-melcloud-atw
Only for Air-to-Water heatpumps.
For Air-to-Air heatpumps use : node-red-contrib-melcloud.
The nodes are triggerd from any incoming payload.
melcloud-connect-atw node
First in creditentials 'add a new melcloud-creditentials-atw' and enter your credentials from your Mitsubishi Melcloud account (email and password)
Then select for '>-Command' 'Devices list'
With a debug node find your buildingId and deviceId (under Structures > Devices)
Alt text
When calling this node most of the heatpump's parameters are published (under Structures > Devices > Devices).
Only call the node with a maximum frequency of 15 minutes, otherwise some of the data will not get updated.
Alt text
melcloud-device-atw
Select your credential settings and provide the buildingId and deviceId. Only 3 parameters can be written to your device from the node
  • SetTemperatureZone1
  • SetTemperatureZone2
  • SetTankTemperature
For SHW 'force hot water' can be set to On for instant startup.
Parameters can be left blank, exept for the ID's, if not needed. The node returns a list of actual parameters from the heatpump.
Alt text
from a function
Parameters can be provided from a function and send with a payload to the melcloud-device-atw node. Just privide the ID's and the parameter that needs to be published. If a parameter does not need to be publised, just leave it out. Available parameters from a function send as
msg.device ={ "buildingid": xxxx, "deviceid": xxxx, "command": { "temperaturezone1" : integer, "temperaturezone2" : integer, "temperaturetank" : integer, "forcehotwatermode" : boolean, "heatflowzone1" : integer, "heatflowzone2" : integer
} return msg;
Alt text
based on node-red-contrib-melcloud by ysimonx
Version: 1.2.4
Updated 1 year, 1 month ago
Rating: 4.7 3
44 in the last week
  • melcloud-credential-atw
  • melcloud-device-atw
  • melcloud-connect-atw
  • mitsubishi
  • melcloud
  • ecodan
  • air conditioning
  • heat pump
  • air-to-water
