node-red-contrib-melcloud 1.6.0
Node-RED node to interface with Mitsubishi Air Conditioning Device with MELCloud API
npm install node-red-contrib-melcloud
node-red node for mitsubishi with melcloud API
Enter your credentials (email & password) from your Mitsubishi melcloud account on https://app.melcloud.com/
First Node : melcloud-connect is provided in order to retrieve your devices lists
Alt text
Second Node : melcloud-device is provided in order to retrieve a device informations (buildingid and deviceid are shown with melcloud-connect)
Alt text
All provided setting (switch on/off, temperature, fan speed, mode ...) will update your melcloud configuration
You can also send input data with msg.device Alt text
possible mode's values are "auto", "heat", "dry", "fan", "cooling"
Full documentation on : https://www.npmjs.com/package/node-red-contrib-melcloud or https://github.com/ysimonx/node-red-contrib-melcloud
Version: 1.6.0
Updated 2 years, 11 months ago
Rating: 3.5 4
12 in the last week
  • melcloud-credential
  • melcloud-device
  • melcloud-read
  • melcloud-connect
  • mitsubishi
  • melcloud
  • MSZ-AP25VG
  • air conditioning
  • heat pump
  • pac
