node-red-contrib-mediashuttle-signature-z 1.1.0
Node-RED node to generate signed URLs for Signiant MediaShuttle Metadata APIs
npm install node-red-contrib-mediashuttle-signature-z
Node-RED custom node to generate MediaShuttle SIG1 (HMAC-SHA256) signed URLs for the MediaShuttle Metadata API (v3.0).
The node prepares authenticated HTTP requests by calculating the required signature and query parameters, allowing downstream nodes (for example http request) to execute MediaShuttle API calls without manual cryptographic handling.
✨ Features
Generates SIG1-HMAC-SHA256 signatures compliant with MediaShuttle specifications
Supports multiple request types
Uses Node-RED credentials to securely store the registrationKey
Supports Node-RED TypedInput (string, msg, flow, global, env)
Automatically sets HTTP method, URL, and headers
πŸ“¦ Installation
From the Node-RED editor:
1 Menu β†’ Manage palette β†’ Install β†’ node-red-contrib-mediashuttle-signature-z
Or via npm:
1 npm install node-red-contrib-mediashuttle-signature-z
Restart Node-RED after installation.
🧩 Node: MediaShuttle Signature Z
Purpose
This node does not perform the HTTP call itself. It prepares a signed request by setting:
msg.method
msg.url
(optionally) msg.headers
These can then be passed to a Node-RED HTTP Request node.
βš™οΈ Configuration
Node Properties
Property
Description
Portal Prefix
MediaShuttle portal name (e.g. myportal)
Package ID
MediaShuttle package identifier
Request Type
Type of MediaShuttle API request
All fields support TypedInput (str, msg, flow, global, env).
Credentials
Credential
Description
Registration Key
MediaShuttle registration key (stored securely)
The credential can be overridden at runtime by providing:
1 msg.registrationKey
πŸ” Supported Request Types
1️⃣ GetPackageDetails
Retrieves metadata for a MediaShuttle package.
Behavior:
HTTP Method: GET
Body: empty
Generated URL format:
1
Output:
1 msg.method = "GET"
2 msg.urlβ€―β€―β€― = ""
2️⃣ RedirectPackageMetadata
Redirects or updates package metadata using a POST request.
Input:
msg.payload can be:
a JavaScript object (auto-converted to JSON)
a JSON string
Behavior:
HTTP Method: POST
Content-Type: application/json
Output:
1 msg.methodβ€― = "POST"
2 msg.urlβ€―β€―β€―β€― = ""
3 msg.headers = {
4 β€― "Content-Type": "application/json"
5 }
πŸ” Signature Generation Details
The node performs the following steps:
Generates an ISO 8601 timestamp
Hashes the request body using SHA-256
Builds a canonical query string
Derives a signing key using:
1 HMAC-SHA256(registrationKey, timestamp)
Generates the final signature using:
1 HMAC-SHA256(signingKey, stringToSign)
The signature is appended to the request URL as X-Sig-Signature.
βœ… Error Handling
The node will fail if any required parameter is missing:
portalPrefix
packageId
registrationKey
requestType
Visual feedback is provided via node status indicators in the editor.
πŸ”§ Example Flow
1 [ Inject ]
2 β€―β€―β€― ↓
3 [ MediaShuttle Signature Z ]
4 β€―β€―β€― ↓
5 [ HTTP Request ]
Example payload for RedirectPackageMetadata:
1 msg.payload = {
2 β€― title: "New Package Title",
3 β€― description: "Updated via Node-RED"
4 }
πŸ›‘οΈ Compatibility
Node-RED β‰₯ 0.20
Node.js β‰₯ 12
Backward compatibility for Node-RED < 1.0 is included.
πŸ“„ License
MIT
πŸ‘€ Author
zzzcrosss
πŸ“ Notes
This node is intended for backend / automation usage where MediaShuttle API authentication is required. It does not expose cryptographic secrets in messages or logs.
Version: 1.1.0
Updated 6 months, 1 week ago
  • mediashuttlesignature-z
  • mediashuttle
  • signiant
  • signature
  • metadata
  • hmac
  • security
