node-red-contrib-mealie 0.1.1
Node-RED nodes for Mealie recipe management system
npm install node-red-contrib-mealie
Node-RED nodes for interacting with Mealie, a self-hosted recipe manager and meal planner.
  • Connect to your Mealie instance using API token authentication
  • Recipe management: create, read, update, delete recipes
  • Meal planning integration
  • Shopping list management
  • Household and group management
  • Media and asset handling
  • Administrative functions for server maintenance and user management
Prerequisites
  • Node-RED >= 2.0.0
  • Node.js >= 14.0.0
  • A running Mealie instance with API access
Install via the Node-RED Palette Manager or run the following command in your Node-RED user directory:
  1. Add a mealie-server-config configuration node
  2. Enter your Mealie server URL (e.g., https://mealie.yourdomain.com)
  3. Enter your API token (generated from Mealie's settings)
  4. Set optional timeout value (default: 5000ms)
Available Nodes
The package provides domain-based nodes that consolidate multiple operations:
Configuration Node
  • mealie-server-config: Server configuration and connection management
Domain Nodes (v0.2.0+)
  • mealie-recipe: Recipe management (get, search, create, update, delete, image, asset)
  • mealie-household: Household management (get, getMembers, getPreferences, updatePreferences)
  • mealie-shopping: Shopping list management (getList, createList, updateList, deleteList, getItems, createItem, addRecipe)
  • mealie-planning: Meal planning (get, create, update, delete)
  • mealie-organizer: Recipe organization (getCategories, getTags, getCookbooks, createCookbook)
  • mealie-admin: Server administration (getInfo, getUsers, getGroups, manageBackup, maintenance)
  • mealie-utility: Utility functions (getSchema, getVersion)
  • mealie-bulk: Bulk operations (exportRecipes, importRecipes)
  • mealie-parser: Recipe parsing (parseUrl, parseText)
Each domain node supports multiple operations that can be configured statically in the node settings or dynamically via the input message.
Operation Pattern
The domain nodes use an operation-based pattern where:
  1. Each node has an "Operation" dropdown to select the function
  2. The UI dynamically adapts to show relevant fields for the selected operation
  3. Operations can be overridden at runtime by setting msg.payload.operation
Example Usage
Static configuration:
[mealie-recipe (operation: get, slug: "pasta-carbonara")] -> [debug]
Dynamic configuration:
// in a function node:
msg.payload = {
    operation: "search",
    params: {
        tags: ["italian", "quick"]
Documentation
For more detailed documentation, see:
Development
This project is developed in phases:
  1. Phase 1: Foundation (configuration, client wrapper, error handling) ✅ COMPLETED
  2. Phase 2: Essential Recipe Nodes ✅ COMPLETED
  3. Phase 3: Household & Shopping ✅ COMPLETED
  4. Phase 4: Organization & Planning ✅ COMPLETED
  5. Phase 5: Advanced Features ✅ COMPLETED
  6. Phase 6: Admin & Polish ✅ COMPLETED
  7. Phase 7: Domain-Operation Architecture ✅ COMPLETED
Running Tests
npm test
Linting
npm run lint
Contributing
Contributions are welcome! Please feel free to submit a Pull Request.
MIT License
Credits
Built on top of the node-mealie API wrapper.
Version: 0.1.1
Updated 1 year, 7 months ago
9 in the last week
  • mealie-recipe
  • mealie-household
  • mealie-shopping
  • mealie-planning
  • mealie-organizer
  • mealie-utility
  • mealie-bulk
  • mealie-parser
  • mealie-admin
  • mealie
  • recipe
  • cooking
  • meal planning
