node-red-contrib-mcz 1.2.0
Node-RED nodes for MCZ pellet stoves — supports reading metrics and writing commands (Socket.IO)
npm install node-red-contrib-mcz
npm version npm downloads Node.js ≥16 Node-RED ≥2 License: MIT
If you'd like to support me, Ko-fi
A complete Node-RED module for connecting to legacy MCZ pellet stoves via the official MCZ Cloud API (Socket.IO app.mcz.it:9000) it also works with the local IP address of the stove 192.168.120.1:81 or [IP_ADDRESS:PORT]. This node package allows you to monitor stove metrics (temperatures, fans, alarms) in real-time and send logical execution commands (power on/off, temperature setpoint, etc.).
Note: This is for stoves using the old MCZ app (which communicates via Socket.IO). It is not designed for the newer MCZ Maestro REST architecture, although many concepts are similar.
V1.1: Second output on mcz-in for system events, confirmation output on mcz-out, full bilingual UI (English / Italian) with translated labels, help panels and command dropdowns, and a complete unit-test suite (109 tests).
To install, you can run the following command in your Node-RED user directory (typically ~/.node-red):
Or you can install it via the Palette Manager in the Node-RED UI.
Nodes Overview
The package provides 4 components:
  1. mcz-config: The hidden configuration node representing a single stove connection.
  2. mcz-in: The Read node. Outputs the current stove state.
  3. mcz-out: The Write node. Accepts inputs to control the stove.
  4. mcz-debug: A read-only diagnostic node that outputs raw hexadecimal arrays and visualizes internal mappings. Useful for identifying unknown model fields to build custom templates.
1. Configuration Node (mcz-config)
This behaves like a physical device connection. You must configure one config node per stove. The package natively supports connecting to multiple stoves simultaneously (e.g. your house and your vacation home); just create multiple config nodes and the underlying engine will multiplex the connections without conflicts.
  • Serial Number (SN): The 13-digit serial number of your stove.
  • MAC Address: The MAC address of the stove Wi-Fi module (without colons, e.g. XXXXXXXXXXXX).
  • Interval: If $> 0$, the node will automatically request stove metrics every X seconds (Auto-Polling). If set to 0, Auto-Polling is disabled.
  • Template: The stove dictionary template. Available options:
    • Aria: Air stoves with standard fan.
    • Aria Comfort Air: Air stoves with multizone ducted fans.
    • Idro: Standard Hydro stoves (puffer/boiler).
    • Musa Hydro: Hydro stoves with 3-way valve and internal pump (e.g., Musa, Club, Suite).
    • Custom: If selected, a box will appear allowing you to drop in a JSON mapping file to parse the proprietary data string.
2. Read Node (mcz-in)
Receives telemetry data from the associated mcz-config node and pushes it into your flow.
Output 1 — Telemetry:
  • msg.topic: mcz/SERIAL_NUMBER
  • msg.payload: A structured JSON object containing all the parsed metrics (Temperatures, Fan RPM, Potency, Active States).
  • msg.raw: A raw pipe-separated string received from the cloud (if "Output raw data" is checked).
  • On connect with HA Discovery enabled: emits the MQTT Auto-Discovery config payload.
Output 2 — Events: System-level events: connect, disconnect, error, reconnecting.
  • msg.topic: mcz/SERIAL_NUMBER/event
  • msg.payload.event: event type string.
Home Assistant (MQTT Auto-Discovery): By checking the "HA Discovery" box in the node settings, mcz-in will emit an MQTT Auto-Discovery configuration payload on Output 1 whenever it connects to the cloud. By routing this output directly to a standard Node-RED MQTT Out node (with a blank topic), your MCZ Stove will instantly and automatically pop up as a fully-featured native Climate Thermostat inside Home Assistant, requiring zero YAML configuration. Fan mode labels use the human-readable strings from the built-in FAN_STATES map ("Disabled", "Level 1" … "Automatic").
Manual Control (Input): You can interact with the underlying Socket.IO connection by injecting strings into the mcz-in node's msg.payload:
  • "connect": Connects the Socket.IO client.
  • "disconnect": Gracefully disconnects from the cloud.
  • "get": Forces an immediate telemetry update. (Required if Interval is set to 0 in your config).
  • "parameters" (or "param"): Requests the stove's configuration parameters (as opposed to live telemetry) — same call the Android app makes once right after connecting. Also runs automatically on connect when Interval > 0. Replies come back on Output 1 with msg.topic = mcz/SERIAL_NUMBER/parameters.
3. Write Node (mcz-out)
This node sends commands to the stove. You can configure the command you want to send directly from the Node's UI using dropdowns, or you can send dynamic payloads into it.
Usage (UI Configuration): Simply double click the node and select your desired Command (e.g. Power) and Value (e.g. 1 or ON) from the dropdowns. If a UI setting is provided, it always overrides incoming messages.
Usage (JSON Object): Alternatively, if you leave the configuration empty ("From msg.payload"), you can pass a JSON object to msg.payload specifying the command and its value. The module automatically takes care of mathematical conversions (like multiplying temperatures by 2 for the internal MCZ registry).
Examples:
// Turn Stove ON
msg.payload = { "command": "Power", "value": 1 };
// Turn Stove OFF
msg.payload = { "command": "Power", "value": 0 };
// Set Target Temperature to 21.5°C
msg.payload = { "command": "Temperature", "value": 21.5 };
// Set Fan state to Auto (6)
msg.payload = { "command": "Fan_State", "value": 6 };
// Turn Eco Mode ON
msg.payload = { "command": "Eco_Mode", "value": "ON" };
Supported Commands:
  • Power (1/0 or ON/OFF)
  • Temperature (e.g. 21.5 — auto-multiplied ×2 internally)
  • Boiler_Setpoint (e.g. 50 — hydro stoves only, ×2 encoding)
  • Power_Level (1 to 5)
  • Fan_State (0 to 6 — 0=Disabled, 6=Automatic)
  • DuctedFan1 / DuctedFan2 (0 to 6)
  • Eco_Mode (1/0 or ON/OFF)
  • Silent_Mode (1/0 or ON/OFF)
  • Active_Mode (1/0 or ON/OFF)
  • Control_Mode (1/0 or ON/OFF)
  • Chronostat (1/0 or ON/OFF)
  • Sleep (minutes as integer)
  • Summer_Mode (1/0 or ON/OFF)
  • AntiFreeze (temperature setpoint)
  • Sound_Effects (1/0 or ON/OFF)
  • Reset_Alarm (trigger — value ignored)
  • Reset_Active (trigger — value ignored)
Commands with a known safe range (Temperature, Boiler_Setpoint, Power_Level, Fan_State, DuctedFan1, DuctedFan2) are validated before sending — an out-of-range value is rejected (buildCommandString returns null, mcz-out logs an error) instead of being sent to the stove. mcz-out also refuses to send anything while the stove is disconnected, rather than silently dropping the command.
Output: On every successful send, mcz-out emits a confirmation message:
  • msg.topic: mcz/SERIAL_NUMBER/command
  • msg.payload: { command, value, raw } — the command name, value used, and raw Socket.IO string sent.
Raw command builders (lib/commands.js): For undocumented or future parameters not in the table above, buildRawWrite(id, value) and buildDiagnostic(id, value) build a raw WriteParametri/Diagnostica string by numeric id — useful from a function node ahead of mcz-out.
Usage (Raw Strings): If you know undocumented codes, you can pass a direct pipeline string to msg.payload. The mcz-out node will forward it directly.
// Bypass the dictionary parser completely
msg.payload = "C|WriteParametri|34|1";
Custom Templates & Fields Mapping
MCZ cloud socket communication responds with a long string of HEX values separated by pipes (C|00|00|05|00|4A|FF|...). By default, this package includes internal parsing maps for all four built-in templates (Aria, Aria Comfort Air, Idro, Musa Hydro).
If you have a customized stove or want to read undocumented fields, you can select the Custom template in the configuration node and supply your own mapping JSON.
How the Mapping JSON works
A template is a JSON object with an array of fields. The package's parser loops through these fields and extracts data by reading the HEX string segment found at pos (0-indexed).
  "name": "My Custom Stove",
  "fields": [
    { "key": "fan_ambient", "pos": 2, "type": "map", "map": "FAN_STATES", "label": "Ambient Fan" },
    { "key": "temp_fumes", "pos": 5, "type": "temp", "label": "Fumes Temp (°C)" },
    { "key": "my_new_sensor", "pos": 102, "type": "int", "label": "Secret Metric" },
    { "key": "custom_dropdown", "pos": 103, "type": "map", "values": { "0": "Closed", "1": "Half", "2": "Open" } }
Available Parsing Types:
  • int: Converts HEX directly to an Integer.
  • temp: Converts HEX to Integer and divides by 2 (v / 2.0). Checks for 0xFF/0xFE (missing probe returning null).
  • bool: Converts hex 0/1 to false/true.
  • bool_gte: True if the HEX value is $\geq$ than a threshold config (e.g. used to determine "In Error" states).
  • map: Extremely powerful. Maps an Integer to a readable string.
    • Use "map": "FAN_STATES" to use one of the built-in system dictionaries.
    • Or define inline mapping using "values": { "0": "String1", "1": "String2" } exactly as shown in the example above.
    • Add "includeCode": true to a field to get { code, label } instead of just the label string — e.g. { "code": 6, "label": "Automatic" }. Off by default so existing templates and flows that expect a plain string keep working unchanged.
  • range_offset: Transforms an internal value using ranges (useful for power levels).
  • hours: Converts an integer to an HH:MM time string.
  • clock: Merges multiple positions to form a readable Date String.
This fully eliminates the need for any internal hardcoding if MCZ updates firmware, you can just tweak your Custom JSON right from the Node-RED panel.
Example Flows
Here are a few quick scenarios to integrate this package (you can copy-paste the JSON code into Node-RED via Menu -> Import):
1. Simple Polling and Debug
Configure your config node to fetch data every 30s. Connect an mcz-in to read the state and an mcz-debug node to spot unknown fields if you notice missing data in your specific stove model.
[{"id":"mcz_in_1","type":"mcz-in","name":"My Stove","stoveConfig":"config_1","topic":"","outputRaw":false,"x":200,"y":100,"wires":[["debug_state"],[]]},{"id":"debug_state","type":"debug","name":"State JSON","active":true,"tosidebar":true,"console":false,"complete":"payload","targetType":"msg","x":400,"y":100,"wires":[]},{"id":"mcz_debug_1","type":"mcz-debug","name":"Debug Raw","stoveConfig":"config_1","x":210,"y":160,"wires":[["debug_raw"]]},{"id":"debug_raw","type":"debug","name":"Position Array","active":false,"tosidebar":true,"console":false,"complete":"payload.flat_dec","targetType":"msg","x":410,"y":160,"wires":[]}]
2. Manual Polling
If you don't want Node-RED pinging the MCZ server 24/7 every 30 seconds, configure the Stove with an Interval of 0. Then, set up an Inject node to trigger "get" via msg.payload:
[Inject Node: interval every 5 mins] --> [msg.payload = "get"] --> [mcz-in] --> [Debug]
3. Dashboard Control
Use standard Node-RED dashboard widgets (like numeric inputs or sliders) to control the target temperature and send it to the stove dynamically.
[{"id":"dash_temp","type":"ui_numeric","name":"Target Temp","group":"dash_group","order":1,"format":"{{value}}","min":10,"max":35,"step":0.5,"x":210,"y":300,"wires":[["function_temp"]]},{"id":"function_temp","type":"function","name":"Format Command","func":"msg.payload = {\n    command: \"Temperature\",\n    value: msg.payload\n};\nreturn msg;","outputs":1,"x":410,"y":300,"wires":[["mcz_out_1"]]},{"id":"mcz_out_1","type":"mcz-out","name":"Set Stove","stoveConfig":"config_1","command":"","commandValue":"","x":600,"y":300,"wires":[[]]}]
Testing
The package includes a unit-test suite covering the parser, commands, maps, and template loading:
npm test
Tests use Mocha and Node.js built-in assert. No physical stove or network connection is required — all tests use synthetic hex strings and known-good inputs.
Contributing
Pull requests to support more proprietary data formats, templates, and newer firmware versions are heavily encouraged!
Roadmap & Future Developments
Here are some features and ideas planned for future releases (Contributions are welcome!):
  • Local Network Auto-Discovery: Automatically find stoves connected to the local Wi-Fi to eliminate the need to manually type IP/MAC/SN.
  • Node-RED Dashboard Widgets: Pre-configured UI nodes that automatically spawn beautiful thermostats and charts purely for MCZ stoves on the Node-RED Dashboard.
  • Native Chronostat Management: Dedicated nodes to visually manage the stove's internal weekly scheduling (Crono) without relying on external Node-RED inject loops.
  • Maestro Support (REST API): Parallel support for the newer generation of MCZ Maestro stoves which use an entirely different local REST/WebSocket interface.
  • Additional Built-in Brands Templates: Including default maps for MCZ-group subsidiary brands (such as Cadel, Red, Sergio Leoni) which share similar backend architectures.
Version: 1.2.0
Updated 2 weeks, 4 days ago
12 in the last week
  • mcz-config
  • mcz-in
  • mcz-out
  • mcz-debug
  • mcz
  • pellet
  • stove
  • stufa
  • home-automation
