node-red-contrib-mcp23017-ioema 0.0.1
Simple MCP23017 nodes for Node-RED based on node-mcp23017
npm install node-red-contrib-mcp23017-ioema
Node-RED nodes for controlling the MCP23017 16-bit I/O expander over the I2C bus.
This package provides simple input and output nodes for the MCP23017 module. It allows selected pins to be configured as digital inputs or digital outputs directly from Node-RED. The library is intended for experimental automation, prototyping, education, and embedded control applications.
  • communication with MCP23017 over I2C
  • support for all 16 GPIO pins
  • digital input node with polling
  • optional internal pull-up for input pins
  • optional sending only when the input value changes
  • digital output node
  • support for inverted output logic
  • shared configuration node for I2C bus and device address
  • suitable for simple digital I/O expansion in Node-RED projects
Install the package directly from the Node-RED Palette Manager:
Menu → Manage palette → Install
Search for:
and click Install.
Alternatively, install it from the Node-RED user directory:
After installation, restart Node-RED if required.
This package contains three Node-RED nodes:
Node Type Description
mcp23017-config configuration node Stores I2C bus, MCP23017 address, and debug option
mcp23017-in input node Reads selected MCP23017 pin periodically
mcp23017-out output node Writes a digital value to selected MCP23017 pin
Example flow
The following example shows a simple flow with one MCP23017 output node and one MCP23017 input node.
Example flow
Configuration node
The mcp23017-config node defines the shared hardware parameters of the MCP23017 module.
MCP23017 configuration
Parameters
Parameter Description Example
Name Optional name of the configured device MCP23017
I2C bus I2C bus number used by the target system 1 or 2
Address I2C address of the MCP23017 module 0x20
Debug Enables debug output false
Typical MCP23017 I2C addresses are:
0x20 - 0x27
Example configuration:
I2C bus: 2
Address: 0x20
Debug: false
The I2C bus number corresponds to the Linux device path:
/dev/i2c-X
For example, I2C bus 2 means:
/dev/i2c-2
Input node
The mcp23017-in node reads the selected MCP23017 pin periodically.
MCP23017 input node
Parameters
Name Optional name displayed on the node
MCP config Selected mcp23017-config configuration node
Pin MCP23017 pin number from 0 to 15
Pull-up Enables internal pull-up resistor
Poll (ms) Polling interval in milliseconds
Only on change Sends output only when the value changes
Topic Optional custom msg.topic
Output message
The output msg.payload contains a boolean value.
Example output:
  "payload": true,
  "pin": 1,
  "address": 32,
  "bus": 2,
  "topic": "mcp23017/20/pin/1"
If the Topic field is empty, the node automatically creates a topic in this format:
mcp23017/<address>/pin/<pin>
Output node
The mcp23017-out node writes a digital value to the selected MCP23017 pin.
Parameters
Set OUTPUT on start Configures the pin as output when Node-RED starts
Invert Inverts the output logic
Input message
The node accepts boolean, numeric, or string values in msg.payload.
Supported values:
true / false
1 / 0
"true" / "false"
"on" / "off"
"high" / "low"
Example input:
  "payload": true
Output message
After writing to the pin, the node sends the message to its output.
Example output:
  "payload": true,
  "pin": 0,
  "address": 32,
  "bus": 2
If the Invert option is enabled, the logical value is inverted before being written to the MCP23017 pin.
Pin numbering
The node uses MCP23017 pin numbers from 0 to 15.
0 - 7    GPIOA pins
8 - 15   GPIOB pins
The exact physical pin mapping depends on the MCP23017 module or board that is used.
Hardware requirements
This node requires:
  • Node-RED
  • MCP23017 I/O expander module
  • system with I2C support
  • enabled I2C interface
  • correct I2C wiring
  • Linux-based target device, such as Raspberry Pi, Luckfox, or another embedded board with I2C support
Wiring
Typical MCP23017 module connection:
MCP23017 pin Target device
VCC 3.3 V or 5 V, depending on the module
GND GND
SDA I2C SDA
SCL I2C SCL
GPIO pins Digital inputs or outputs
Make sure that the voltage levels of the MCP23017 module are compatible with the target device.
Platform note
This node uses the node-mcp23017 package and is intended to run on Linux-based devices with I2C support.
On Windows, the package may install successfully, but real I2C communication is not supported unless a compatible I2C interface and driver are available.
Notes
For reliable operation, make sure that:
  • the I2C interface is enabled,
  • the correct I2C bus number is selected,
  • the correct MCP23017 address is configured,
  • the MCP23017 module is connected correctly,
  • the selected pin number is in range 0 to 15,
  • the pin is not used by another part of the flow in a conflicting mode.
This project is licensed under the MIT License.
Version: 0.0.1
Updated 5 months, 2 weeks ago
  • mcp23017-config
  • mcp23017-in
  • mcp23017-out
  • node-red-contrib
  • mcp23017
  • i2c
  • gpio
  • io-expander
  • digital-input
  • digital-output
  • luckfox
