node-red-contrib-mcp-tools 3.2.1
Node-RED component for executing MCP (Model Context Protocol)
npm install node-red-contrib-mcp-tools
A Node-RED node for connecting to Model Context Protocol (MCP) servers and executing AI prompts with tool use — no extra containers or services required.
Supports OpenAI, Anthropic, Google Gemini, and OpenRouter as LLM providers. Connects to MCP servers via Stdio (local process) or Streamable HTTP (remote URL).
Via Palette Manager (recommended)
  1. Open Node-RED → hamburger menu → Manage Palette
  2. Go to the Install tab
  3. Search for node-red-contrib-mcp-tools and click Install
Via terminal
Restart Node-RED after installation. The node appears in the function category.
Quick Start
Streamable HTTP (zero setup)
The simplest way to use the node — connect to a remote MCP server with just a URL:
  1. Drag an mcp-tools node into your flow
  2. Set Transport Type → Streamable HTTP
  3. Enter the MCP Server URL, e.g. https://mcp.exa.ai/mcp
  4. Enter your Bearer Token if the server requires auth, e.g. {{EXA_API_KEY}}
  5. Set your LLM Provider and API Key
  6. Connect an inject node with a prompt string and deploy
For running a local MCP server process inside the container:
  1. Set Transport Type → Stdio
  2. Configure MCP Servers with the command and args:
  "mcpServers": {
    "demo": {
      "command": "node",
      "args": ["/data/mcp-server-demo/build/index.js"]
Node Configuration
LLM Provider
Field Description
LLM Provider openai, anthropic, gemini, or openrouter
Model Model name — leave empty to use the provider default
API Key Your provider API key. Use {{ENV_VAR_NAME}} to reference an environment variable
Default models per provider:
Provider Default model
OpenAI gpt-4o
Anthropic claude-sonnet-4-6
Gemini gemini-2.5-pro
OpenRouter openai/gpt-4o
Transport Type
Streamable HTTP — remote MCP server via URL:
Field Description
MCP Server URL Full HTTPS URL of the MCP endpoint
Bearer Token Auth token for the server. Use {{MY_API_KEY}} for env var substitution.
Stdio — local MCP server process:
Field Description
MCP Servers Configuration JSON object with server names and their command/args
MCP Server Environment Variables JSON object of env vars to pass to the server process
Other fields
Field Description
Prompt Default prompt. Can be overridden by msg.prompt or msg.payload
Timeout Connection timeout in ms (default: 30000; auto-set to 300000 for npx servers)
{{VAR_NAME}} Environment Variable Substitution
Any field that accepts a {{VAR_NAME}} token will be substituted at runtime:
Priority: MCP Server Envs field > container environment (process.env)
Supported fields:
  • API Key → {{OPENAI_API_KEY}}
  • Bearer Token → {{EXA_API_KEY}}
  • args[] entries → {{MY_SERVER_PATH}}
  • Prompt text → {{MY_VALUE}}
  • MCP Server Environment Variables → {{ENV_MCP_VARIABLES}} (must resolve to a JSON object string)
MCP Servers Configuration (Stdio mode)
Single local server
  "mcpServers": {
    "demo": {
      "command": "node",
Note: npx-based servers automatically get a 300s connection timeout to allow package download on first run.
Multiple servers
When multiple servers are configured, the node automatically selects the best one based on keyword matching in the prompt.
  "mcpServers": {
    "search": {
      "command": "node",
      "args": ["/data/search-server/index.js"]
    "database": {
      "command": "node",
      "args": ["/data/db-server/index.js"]
Remote HTTP server (in Stdio config)
  "mcpServers": {
    "remote": {
      "url": "https://mcp.example.com/mcp",
      "token": "{{MY_TOKEN}}"
Inputs
Property Type Description
msg.payload string Prompt to execute (used if msg.prompt is not set)
msg.prompt string Prompt — overrides the node's default prompt
msg.provider string LLM provider override
msg.model string Model override
msg.apiKey string API key override
msg.mcpServers string/object MCP servers config override (Stdio mode)
msg.mcpServerUrl string MCP server URL override (HTTP mode)
msg.mcpServerToken string Bearer token override (HTTP mode)
msg.mcpServerEnvs string/object Server environment variables override
Outputs
msg.payload string Final text response from the LLM
msg.mcpResult object Full result object
msg.mcpResult.success boolean Whether execution succeeded
msg.mcpResult.response string LLM response text
msg.mcpResult.toolsUsed array Names of MCP tools called
msg.mcpResult.messages array Full conversation history
msg.mcpResult.originalPrompt string The prompt that was sent
Example Flow
    "id": "inject1",
    "type": "inject",
    "name": "Ask",
    "props": [{ "p": "payload", "v": "Search for the latest news about MCP protocol", "vt": "str" }],
    "x": 100, "y": 100,
    "wires": [["mcp1"]]
    "id": "mcp1",
    "type": "mcp-tools",
    "name": "MCP Tools",
    "provider": "openai",
    "model": "",
    "apiKey": "{{OPENAI_API_KEY}}",
    "transportType": "http",
    "mcpServerUrl": "https://mcp.exa.ai/mcp",
    "mcpServerToken": "{{EXA_API_KEY}}",
    "prompt": "",
    "timeout": 30000,
    "x": 300, "y": 100,
    "wires": [["debug1"]]
    "id": "debug1",
    "type": "debug",
    "name": "Result",
    "complete": "true",
    "x": 500, "y": 100,
Docker Setup
A ready-to-use Docker Compose setup is available at node-red-mcp-server.
services:
  node-red:
    image: nodered/node-red:4.0.0
    ports:
      - "1880:1880"
    environment:
      - OPENAI_API_KEY=${OPENAI_API_KEY}
      - EXA_API_KEY=${EXA_API_KEY}
Troubleshooting
invalid_token error on HTTP transport
  • Check that your Bearer Token field contains the correct env var, e.g. {{EXA_API_KEY}}
  • Verify the env var is set in your container environment
spawn ENOENT error
  • The MCP server command was not found. Check the command and args paths.
  • For servers inside Docker, paths must be absolute container paths (e.g. /data/...)
npx timeout
  • First run downloads the package — this can take 30–60s
  • The node auto-sets 300s timeout for npx commands
Provider API key not found
  • Use {{OPENAI_API_KEY}} (or the relevant provider env var) in the API Key field
  • Or set the env var directly in the container
LGPL-3.0-or-later
You may use this node freely in your Node-RED flows, including in commercial and proprietary projects. However, any modifications to this node's source code must be released under the same LGPL license and contributed back to the project.
Version: 3.2.1
Updated 7 months ago
License: LGPL-3.0-or-later
Rating: 5.0 10
260 in the last week
  • mcp-tools
  • mcp
  • model-context-protocol
  • ai
  • tools
  • openai
