node-red-contrib-mcp-protocol 0.1.2
Node-RED component for MCP protocol communication
npm install node-red-contrib-mcp-protocol
Node-RED MCP Protocol Component
A Node-RED component for communicating with devices using the MCP protocol.
  • Receive data from MCP protocol servers
  • Send data to MCP protocol servers
  • Configurable data formats (string, JSON, buffer)
  • Automatic reconnection on connection loss
  • Support for authentication
Local Installation
To install the node in your Node-RED installation:
npm install /path/to/node-red-contrib-mcp-protocol
Global Installation
To install the node globally:
npm install -g /path/to/node-red-contrib-mcp-protocol
  1. Add an MCP configuration node
  2. Configure the host and port for your MCP server
  3. Optionally set the device ID and authentication key if required by your MCP server
Receiving Data
  1. Add an "MCP In" node to your flow
  2. Configure it to use your MCP configuration
  3. Select the output format (Auto-detect, String, Buffer, or JSON)
  4. Connect the output to other nodes in your flow
Sending Data
  1. Add an "MCP Out" node to your flow
  3. Select the input format (Auto-convert, String, Buffer, or JSON)
  4. Connect other nodes to the input of the MCP Out node
Example Flow
        "id": "f6f2187d.f17ca8",
        "type": "mcp-in",
        "z": "2b9467.5f69d7cc",
        "name": "MCP Receiver",
        "server": "3fa97a8a.3b9946",
        "topic": "mcp/data",
        "dataType": "json",
        "x": 270,
        "y": 180,
                "25f5d5dd.2d836a"
        "id": "25f5d5dd.2d836a",
        "type": "debug",
        "name": "MCP Data",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "x": 460,
        "y": 180,
        "id": "3fa97a8a.3b9946",
        "type": "mcp-config",
        "name": "MCP Server",
        "host": "192.168.1.100",
        "port": "1234",
        "reconnectTimeout": "5000",
        "mcpVersion": "1.0",
        "deviceId": "node-red-client",
        "authKey": ""
Customizing the MCP Protocol
The current implementation uses a simplified version of the MCP protocol with newline-delimited messages. To customize for your specific MCP protocol implementation:
  1. Modify the processBuffer method in mcp-config.js to match your protocol's message format
  2. Adjust the authentication mechanism in the connect method if needed
  3. Update the data processing in mcp-in.js and mcp-out.js to handle your specific data formats
MIT License
Copyright (c) 2025 Hindurable
Version: 0.1.2
Updated 1 year, 8 months ago
Rating: 0.0
172 in the last week
  • mcp-in
  • mcp-out
  • mcp-sse
  • mcp-config
  • mcp
  • protocol
