node-red-contrib-mcdm 0.0.2
Node-RED Multi Criterion Decision Making Nodes
npm install node-red-contrib-mcdm
This is a collection of Node-RED nodes for working with Multi-Criteria Decision Making algorithms in your flow.
Installation ⚡
To install the node execute the following command inside the .node-red directory:
You can also install the collection from the Node-RED editor Manage palette option of the menu.
Local Incubator Server ⚙️
Clone the github repository by executing the following command:
git clone https://github.com/Doth-J/node-red-contrib-mcdm.git
Inside the project directory, install the dependencies and start the incubator server executing the commands:
cd ./node-red-contrib-mcdm
npm install;
npm start
A Node-RED incubator server will start in http://localhost:1880 already loaded with the Multi-Criteria Decision Making nodes:
> [email protected] start
> node incubator/server.js
8 Oct 20:34:28 - [info]
Welcome to Node-RED
8 Oct 20:34:32 - [info] Started Node-RED server: http://localhost:1880
8 Oct 20:34:32 - [info] Starting flows
8 Oct 20:34:32 - [info] Started flows
Multi Criteria Decision Making (MCDM) 📚
Multi-Criteria Decision Making, also known as MCDM, refers to making decisions in the presence of multiple, usually conflicting, criteria. The aim is to find the best possible solution by considering multiple decision criteria, which are typically conflicting in nature. These criteria can be quantitative or qualitative in nature.
Analytical Hierarchy Process (AHP) 📗
Analytic Hierarchy Process, also known as AHP, is a structured technique for organizing and analyzing complex decisions. AHP provides a comprehensive and rational framework for structuring a decision problem, for representing and quantifying its elements, and for relating those elements to the overall goals. AHP offers a mathematical and systematic approach to decision-making where multiple, often conflicting, criteria are involved. The AHP Node can be used by injecting a Pairwise Comparison Matrix to evaluate the relative importance of criteria through pairwise comparisons:
⚠️ Pairwise Comparison Matrix must be a square array!
  • Payload Format:
        [...], // Pairwise Comparison for Criteria #1
        [...], // Pairwise Comparison for Criteria #2
        [...], // Pairwise Comparison for Criteria #3
  • Node Response:
        "paiwiseComparisonMatrix":[
        "priorities":[
            p1, // Priority Vector #1
            p2, // Priority Vector #2
            p3, // Priority Vector #3
    AHP Example Flow
Simple Additive Weighting (SAW) 📗
Simple Additive Weighting, also known as the weighted sum model or SAW, is a popular Multi-Criteria Decision-Making (MCDM) method, utilized to determine the best option among a set of alternatives evaluated against multiple criteria. SAW is favored for its simplicity and ease of use, making it applicable to a wide array of decision-making problems. The SAW Node can be used by injecting a decision matrix and the corresponding weight for each of the criteria:
  • Payload Format:
        "decisionMatrix":[
            [...], // Alternative #1
            [...], // Alternative #2
            [...], // Alternative #3
        "weights":[
            w1, // Weight for Criteria #1
            w2, // Weight for Criteria #2
            w3, // Weight for Criteria #3
  • Node Response:
        "decisionMatrix":[
        "weights":[
        "scores":[
            s1, // Score for Alternative #1
            s2, // Score for Alternative #2
            s3, // Score for Alternative #3
        "bestAlternativeIndex": X // Highest Ranking Alternative
    SAW Example Flow
Technique for Order of Preference by Similarity to Ideal Solution (TOPSIS) 📗
Technique for Order of Preference by Similarity to Ideal Solution, also known as TOPSIS, is a multi-criteria decision-making (MCDM) method, developed to solve complex decision-making problems. TOPSIS assists decision-makers in identifying the best alternative from a set of available alternatives evaluated based on multiple, often conflicting, criteria. TOPSIS provides a robust method for handling complex MCDM problems, offering a logical approach to identifying the best alternative by considering the distance to ideal and negative-ideal solutions. The TOPSIS Node can be used by injecting a decision matrix and the corresponding weight for each of the criteria:
  • Payload Format:
        "decisionMatrix":[
        "weights":[
  • Node Response:
        "decisionMatrix":[
        "weights":[
        "scores":[
    TOPSIS Example Flow
Multi-Objective Optimization on the basis of Ratio Analysis (MOORA) 📗
Multi-Objective Optimization on the basis of Ratio Analysis, also known as MOORA, is a multi-criteria decision-making (MCDM) method, used to determine the best alternative from a set of available alternatives, which are evaluated based on multiple, usually conflicting, criteria. MOORA focuses on optimizing multiple objectives, which are transformed into non-dimensional ratios to establish a more straightforward comparison between different alternatives. The MOORA Node can be used by injecting a decision matrix and the corresponding weight for each of the criteria:
  • Payload Format:
        "decisionMatrix":[
        "weights":[
  • Node Response:
        "decisionMatrix":[
        "weights":[
        "referencePoints":[
            rp1, // Reference Point for Alternative #1
            rp2, // Reference Point for Alternative #2
            rp3, // Reference Point for Alternative #3
        "ranks":[
            r1, // Rank for Alternative #1
            r2, // Rank for Alternative #2
            r3, // Rank for Alternative #3
    MOORA Example Flow
VlseKriterijumska Optimizacija I Kompromisno Resenje (VIKOR) 📗
Vlsekriterijumska Optimizacija I Kompromisno Resenje, also known as VIKOR, is a multi-criteria decision-making (MCDM) method that focuses on ranking and selecting from a set of alternatives and determines compromise solutions for a problem with conflicting criteria. VIKOR is particularly useful when the decision-maker cannot express an explicit preference regarding the importance of the criteria, introducing a particular measure of 'closeness' to the 'ideal' solution. The VIKOR Node allows configuration of the "Majority Rule" and can be used by injecting a decision matrix and the corresponding weight for each of the criteria:
  • Payload Format:
        "decisionMatrix":[
        "weights":[
  • Node Response:
        "decisionMatrix":[
        "weights":[
        "referencePoints":[
        "ranks":[
    MOORA Example Flow
Preference Ranking Organization Method for Enrichment of Evaluations (PROMETHEE) 📗
Preference Ranking Organization Method for Enrichment of Evaluations, also known as PROMETHEE, is a multi-criteria decision-making method that ranks alternatives by comparing them pairwise concerning multiple criteria. The method uses preference functions to manage these comparisons and employs a pairwise comparison matrix to determine flows which are used to rank the alternatives. The PROMETHEE Node allows configuration of the "Preference Function" with the corresponding values for the criterion applies and can be used by injecting a decision matrix and the corresponding weight for each of the criteria:
  • Preference Functions:
  1. Usual Criterion:
    alternatives[i] >= alternatives[j] ? 0 : 1*
  2. Level Criterion:
    Math.abs(alternatives[i] - alternatives[j]) <= parameters[0] ? 0 : (alternatives[i] > alternatives[j] ? 1 : 0)
  3. Quasi Criterion:
    Math.abs(alternatives[i] - alternatives[j]) <= parameters[1] ? (alternatives[i] > alternatives[j] ? 1 : 0) : 0
  4. Gaussian Criterion:
    alternatives[i] <= alternatives[j] ? 0 : -Math.exp(-Math.pow(alternatives[i] - alternatives[j],2) / (2 * Math.pow(parameters[2],2)))
  5. Linear Criterion: **
    if(alternatives[i] - alternatives[j] <= parameters[0]) 0;
    else if(alternatives[i] - alternatives[j] >= parameters[2]) 1;
    else{
        (alternatives[i] - alternatives[j] - parameters[0]) / (parameters[2] - parameters[0])
  • Payload Format:
        "decisionMatrix":[
        "weights":[
  • Node Response:
        "decisionMatrix":[
        "weights":[
        "ranks":[
            r1, // Ranking for Alternative #1
            r2, // Ranking for Alternative #2
            r3, // Ranking for Alternative #3
PROMETHEE Example Flow
Version: 0.0.2
Updated 3 years, 4 months ago
1 in the last week
  • ahp
  • saw
  • topsis
  • moora
  • vikor
  • promethee
  • node-inq
