node-red-contrib-maxcube2 0.3.4
A node-red node to control the eQ-3 Max! Cube with maxcube2.js
npm install node-red-contrib-maxcube2
A collection of node-red nodes to control the eQ-3 Max! Cube
Introduction
History
node-red-contrib-maxcube2 is a fork of https://github.com/ivesdebruycker/node-red-contrib-maxcube using https://github.com/normen/maxcube2.
Changes from node-red-contrib-maxcube
  • Settings to temporary disable maxcube connection (the cube can handle only one TCP connection at a time, since maxcube/maxcube2 use a permanent connection if you want to temporary use another client you have to stop node-red...now you can disable in node settings)
  • Node to query devices configurations
  • Set mode to all devices with a single payload ({"mode" : "AUTO"} without rf_address)
  • Output devices data as single message or separeted messages
  • I'm planning add some additional features like schedule settings
The old API didn't change currently so it's a drop-in replacement.
cd $HOME/.node-red
Restart Node-RED.
maxcube config node
Set ip and port of your Max! Cube
maxcube (input)
A node to query the eQ-3 Max! Cube for device states.
Whenever an input message is received, device states are updated from the Max! Cube, and sent as separate messages (one for each device) with following structure:
    "rf_address": "1709d7",
    "initialized": true,
    "fromCmd": false,
    "error": false,
    "valid": true,
    "mode": "AUTO",
    "dst_active": true,
    "gateway_known": true,
    "panel_locked": false,
    "link_error": false,
    "battery_low": false,
    "valve": 0,
    "setpoint": 17,
    "temp": 0,
    "device_type": 1,
    "device_name": "Termosifone Sala TV",
    "room_name": "Piano terra",
    "room_id": 1
or as a single message with the following structure:
    "1709d7": {
        "fromCmd": false,
        "error": false,
        "valid": true,
        "mode": "AUTO",
        "dst_active": true,
        "valve": 0,
        "setpoint": 17,
        "temp": 0,
        "device_type": 1,
        "room_id": 1
    "18eb18": {
        "rf_address": "18eb18",
        "fromCmd": false,
        "error": false,
        "valid": true,
        "mode": "AUTO",
        "dst_active": true,
        "valve": 4,
        "setpoint": 17
        "temp": 27.2,
        "device_type": 3,
        "device_name": "Termostato a parete",
        "room_id": 1
    "0a1d0e": {
        "rf_address": "0a1d0e",
        "open": false,
        "device_type": 5,
        "device_name": "Pulsante Eco"
maxcube configuration (input)
Whenever an input message is received, device configuration are updated from the Max! Cube, and sent as separate messages (one for each device) with following structure:
   "rf_address":"18b444",
   "device_type":1,
   "serial_number":"OEQ1131666",
   "comfort_temp":21.5,
   "eco_temp":16.5,
   "max_setpoint_temp":30,
   "min_setpoint_temp":4.5,
   "temp_offset":0,
   "max_valve":100
   "18b444":{
      "device_type":1,
      "eco_temp":16.5,
      "temp_offset":0,
      "max_valve":100
   "1709a1":{
      "rf_address":"1709a1",
      "device_type":1,
      "serial_number":"NKF0004984",
      "eco_temp":16.5,
      "temp_offset":0,
      "max_valve":100
maxcube (output)of a device
A node to set the temperature and/or the mode of a device. Valid modes are "AUTO", "MANUAL", "BOOST" and "VACATION".
Accepts messages with payload of type object with following structure:
MANUAL on specific device
  "rf_address": "0abc12",
  "degrees": 20,
  "mode":"MANUAL"
MANUAL on all devices
  "degrees": 20,
  "mode":"MANUAL"
AUTO on all devices
  "mode":"AUTO"
VACATION on all devices until specific date (ISO 8601)
  "mode":"VACATION",
  "untilDate" : "2019-06-20T10:00:00Z"
Version: 0.3.4
Updated 7 years, 1 month ago
9 in the last week
  • maxcube in
  • maxcube out
  • maxcube device config
  • maxcube-server
  • Max Cube
  • eq-3
  • eq3
  • maxcube
  • thermostat
  • home
  • heating
  • max
  • elv
  • Ives De Bruycker
  • Luca Mazzilli
  • tedstriker
  • Nils Schneider
  • Holger Pieta
