node-red-contrib-mattermost-incoming 1.0.1
A node-red module to post to your mattermost server
npm install node-red-contrib-mattermost-incoming
A Node-RED node to post messages to custom mattermost setup.
Matter Most Incoming Webhook
Matter Most output node.
Expects a msg.payload with a string that will be posted to the channel.
Webhook URL
This can be found on the Incoming WebHooks for the channel of your choice.
Username
This is the name that will appear above each post to the channel
Icon Url
This is the emoji that will be dispalyed next to each of the messages in the channel. this can be a url of your choice, but it must be a full url.
Destination channel
You can optionally override the destination channel if required - either in the edit dialogue or by setting msg.channel.
You can also create Matter Most attachments by adding a msg.attachments property that must be an array. Unset the payload to make it even smaller.
For more information see Matter Most Incoming Webhooks.
Matter Most Outgoing Webhook
This is the initial fork of yayadrian node-red-slack.
it should properly adapt to mattermost, and pass the icon too.
Version: 1.0.1
Updated 4 years, 3 months ago
7 in the last week
  • MatterMostIncoming
  • mattermost
  • slack
  • axios
  • post
