node-red-contrib-maps 0.2.2
Node-RED Maps node
npm install node-red-contrib-maps
A Node-RED node implemented by Openlayers 5 to show Iot measures
Node-RED Maps Dashboard
Description
This node package permit to use Openlayers map from Node-RED. The objective is create a new url for the map created, this url path could be configured and updated at runtime.
npm install node-red-contrib-maps --save
Map configuration
The Map attributes are:
  • Path: The Map Url to be access. An example where path is MAP could be:
http://localhost:1880/MAP
  • Tittle: The map title
  • Payload: The map dataset object
The map payload attributes are:
  • channel: The channel legend
  • dataset: The map dataset
The payload dataset attributes are:
  • lon: longitude point
  • lat: latitude point
  • description: descripion value
  • value: value point
  • unit: value unit
  • color: color marker
Read node help to check the dataset structure for each chart. A Europe Temperature Map dataset could be like this:
        "channel": "TEMP",
        "dataset": [
                "lon": -3.703548,
                "lat": 40.417204,
                "name": "9fj04r",
                "description": "Temperature in Madrid",
                "value": 20.5,
                "unit": "°C",
                "iconColor": "Blue"
                "lon": -0.075906,
                "lat": 51.508319,
                "name": "04jgpe",
                "description": "Temperature in London",
                "value": 19,
                "unit": "°C",
                "iconColor": "Yellow"
                "lon": 2.34294,
                "lat": 48.859271,
                "name": "lfj82k",
                "description": "Temperature in Paris",
                "label": "Alert for strong frosts",
                "value": 11.7,
                "unit": "°C",
                "iconColor": "Red"
                "lon": 13.402786,
                "lat": 52.517987,
                "name": "0lw233",
                "description": "Temperature in Berlin",
                "value": 10.8,
                "unit": "°C",
                "iconColor": "Red"
Dependencies
Server side
Client side
  • socker.io-client: Socket.io client side
  • jquery: Multipurpose javascript library
  • bootstrap4: Build responsive, mobile-first projects on the web
  • popper.js: A kickass library used to manage poppers in the web applications
  • Openlayers: OpenLayers makes it easy to put a dynamic map in any web page
  • moment: Parse, validate, manipulate, and display dates and times in JavaScript.
  • jsPDF: The leading HTML5 client solution for generating PDFs
Example
Under example folder you have a json flow to be imported in your node-red instance to test the nodes.
Version: 0.2.2
Updated 8 years, 2 months ago
License: Apache License, Version 2.0
Rating: 4.7 3
14 in the last week
  • maps
  • openlayers
  • map
  • IoT
