node-red-contrib-manage-flow-by-git 0.0.18
For Node-RED. Manage flow by git. Export Flow XML. Easy to watch diff of function-node and template-node
npm install node-red-contrib-manage-flow-by-git
Feature
  • for Node-RED.
  • Manage flow by git.
  • It is easy to watch diff of function node and template node.
  • Export XML. Flow(XML) optimized for git diff.
  • Sort node by id.
  • JSON for restoration is also included in XML.
    • Be careful with handling due to it is informal processing.
  • Committing this XML to git makes it easy to manage.
Released
Date Version Description
2017-09-26 0.0.16 a little modification
2017-09-24 0.0.7 Update README.
2017-09-23 0.0.1 Released
npm install --save node-red-contrib-manage-flow-by-git
  • Open "by git" tab.
  • Select nodes.
  • Get XML.
  • Download XML.
Warning
  • <json></json> contains JSON that can be imported with Node-RED.
  • However, It can not be guaranteed.
  • Please check it yourself.
Example XML
<?xml version="1.0" encoding="utf-8"?>
<flow>
  <nodes>
    <node index="0">
      <id>584eb128.a27c8</id>
      <type>function</type>
      <name>get time</name>
      <func><![CDATA[
var datetime = new Date(msg.payload);
var to2digits = function(value) {
    return ("0" + value).slice(-2);
var time = [];
time.push(to2digits(datetime.getHours()));
time.push(to2digits(datetime.getMinutes()));
time.push(to2digits(datetime.getSeconds()));
msg.time = time.join(":");
]]></func>
      <noerr>0</noerr>
      <wires>
        <0>
          <0>9a8e7d63.37d2e</0>
        </0>
      </wires>
    </node>
    <node index="1">
      <id>9a8e7d63.37d2e</id>
      <type>template</type>
      <name>toJson</name>
      <field>payload</field>
      <fieldType>msg</fieldType>
      <format>handlebars</format>
      <syntax>mustache</syntax>
      <template><![CDATA[
  "timestamp": "{{{payload}}}",
  "time": "{{{time}}}"
]]></template>
      <output>json</output>
      <wires>
        <0>
          <0>eda3572b.b93a28</0>
        </0>
      </wires>
    </node>
    <node index="2">
      <id>e33d76a.36b0288</id>
      <type>inject</type>
      <name>repeat 1m</name>
      <topic>foo</topic>
      <payload></payload>
      <payloadType>date</payloadType>
      <repeat>60</repeat>
      <crontab></crontab>
      <once>false</once>
      <wires>
        <0>
          <0>584eb128.a27c8</0>
        </0>
      </wires>
    </node>
    <node index="3">
      <id>eda3572b.b93a28</id>
      <type>debug</type>
      <name>debug</name>
      <console>false</console>
      <complete>payload</complete>
      <wires>
        <0>
        </0>
      </wires>
    </node>
  </nodes>
  <json><![CDATA[
[{"id":"584eb128.a27c8","type":"function","name":"get time","func":"var datetime = new Date(msg.payload);\nvar to2digits = function(value) {\n    return (\"0\" + value).slice(-2);\n}\nvar time = [];\ntime.push(to2digits(datetime.getHours()));\ntime.push(to2digits(datetime.getMinutes()));\ntime.push(to2digits(datetime.getSeconds()));\nmsg.time = time.join(\":\");\nreturn msg;","outputs":1,"noerr":"0","x":160,"y":140,"wires":[["9a8e7d63.37d2e"]]},{"id":"9a8e7d63.37d2e","type":"template","name":"toJson","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n  \"timestamp\": \"{{{payload}}}\",\n  \"time\": \"{{{time}}}\"\n}","output":"json","x":190,"y":200,"wires":[["eda3572b.b93a28"]]},{"id":"e33d76a.36b0288","type":"inject","name":"repeat 1m","topic":"foo","payload":"","payloadType":"date","repeat":"60","crontab":"","once":"false","x":130,"y":80,"wires":[["584eb128.a27c8"]]},{"id":"eda3572b.b93a28","type":"debug","name":"debug","active":true,"console":"false","complete":"payload","x":230,"y":260,"wires":[[]]}]
  </json>
<flow>
Compare json with xml.
        "id": "e33d76a.36b0288",
        "type": "inject",
        "z": "37072f5.d943fd",
        "name": "repeat 1m",
        "topic": "foo",
        "payload": "",
        "payloadType": "date",
        "repeat": "60",
        "crontab": "",
        "once": false,
        "x": 130,
        "y": 80,
                "584eb128.a27c8"
        "id": "584eb128.a27c8",
        "type": "function",
        "name": "get time",
        "func": "var datetime = new Date(msg.payload);\nvar to2digits = function(value) {\n    return (\"0\" + value).slice(-2);\n}\nvar time = [];\ntime.push(to2digits(datetime.getHours()));\ntime.push(to2digits(datetime.getMinutes()));\ntime.push(to2digits(datetime.getSeconds()));\nmsg.time = time.join(\":\");\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 160,
        "y": 140,
                "9a8e7d63.37d2e"
        "id": "9a8e7d63.37d2e",
        "type": "template",
        "name": "toJson",
        "field": "payload",
        "fieldType": "msg",
        "format": "handlebars",
        "syntax": "mustache",
        "template": "{\n  \"timestamp\": \"{{{payload}}}\",\n  \"time\": \"{{{time}}}\"\n}",
        "output": "json",
        "x": 190,
        "y": 200,
                "eda3572b.b93a28"
        "id": "eda3572b.b93a28",
        "type": "debug",
        "name": "debug",
        "active": true,
        "console": "false",
        "complete": "payload",
        "x": 230,
        "y": 260,
Screenshots
  • Tab
Tab
  • Node (do nothing)
Node image
Version: 0.0.18
Updated 9 years, 3 months ago
18 in the last week
  • manage-flow-by-git
  • manage
  • flow
  • git
  • xml
