node-red-contrib-mad-template-ai 1.0.1
A Node-RED node that generates dynamic HTML templates using OpenAI LLM based on input data, with intelligent caching and MadnessInteractive theming
npm install node-red-contrib-mad-template-ai
A Node-RED node that generates dynamic HTML templates using OpenAI's GPT models based on input data, with intelligent caching and MadnessInteractive theming.
🤖 AI-Powered Template Generation
  • Generate HTML templates dynamically using OpenAI GPT models
  • Support for GPT-3.5 Turbo, GPT-4, and other OpenAI models
  • Configurable creativity with temperature settings
🎨 MadnessInteractive Theming
  • Three built-in themes: Dark (Cyberpunk), Light (Modern), Neon (Vibrant)
  • Automatic CSS injection and theming
  • Responsive design with mobile support
⚡ Performance Optimized
  • Intelligent caching to reduce API calls and costs
  • Hash-based cache keys for efficient storage
  • Configurable cache duration and strategies
🛡️ Robust Error Handling
  • Automatic retry with exponential backoff
  • Fallback templates when AI generation fails
  • Comprehensive error logging and status indicators
🚀 Easy Configuration
  • User-friendly configuration interface
  • Theme-based system prompts
  • Boot-time template generation support
Or install directly through the Node-RED palette manager.
Quick Start
  1. Add the node to your flow from the function category
  2. Configure OpenAI API key in the node settings
  3. Select a theme (madness-dark, madness-light, madness-neon)
  4. Connect input data and deploy!
Basic Example
// Input message
msg.payload = {
    title: "Sales Dashboard",
    stats: {
        revenue: 125000,
        orders: 342,
        customers: 89
    charts: ["sales", "traffic"]
// Output: Beautiful HTML dashboard generated by AI
OpenAI Settings
  • API Key: Your OpenAI API key (stored securely)
  • Model: Choose between GPT-3.5 and GPT-4 variants
  • Temperature: Controls creativity (0 = deterministic, 2 = very creative)
  • Max Tokens: Maximum length of generated response
Template Settings
  • Theme: Built-in MadnessInteractive themes
  • System Prompt: Custom instructions for AI (optional)
  • Template Data: Message property containing data for generation
  • Output Format: String or parsed object output
Performance Settings
  • Enable Caching: Cache identical requests (recommended)
  • Cache Duration: How long to cache results (seconds)
  • Retry Attempts: Number of retry attempts on API failure
  • Timeout: OpenAI API timeout (milliseconds)
Themes
Madness Dark (Cyberpunk)
Perfect for dashboards, monitoring interfaces, and futuristic applications.
  • Dark backgrounds with neon accents
  • Glowing text effects and borders
  • Green, pink, and blue color scheme
Madness Light (Modern)
Clean and professional for business applications and reports.
  • White backgrounds with subtle grays
  • Professional blue, red, and green accents
  • Clean typography and spacing
Madness Neon (Vibrant)
High-energy theme for gaming, entertainment, and dynamic content.
  • Deep space backgrounds with intense colors
  • Multiple neon colors with glowing effects
  • Animated elements and visual effects
Examples
Dashboard Generation
    "title": "System Dashboard",
    "stats": {
        "users": 1234,
        "orders": 567,
        "revenue": 89012
    "charts": ["sales", "traffic"],
    "alerts": [
        {"type": "warning", "message": "High CPU usage"}
Report Templates
    "reportType": "monthly",
    "period": "January 2024",
    "data": [
        {"month": "Jan", "sales": 1000},
        {"month": "Feb", "sales": 1200}
    "summary": "Sales increased 20% this quarter"
Data Visualization
    "chartType": "bar",
    "title": "Performance Metrics",
    "datasets": [
        {"label": "CPU", "value": 65, "max": 100},
        {"label": "Memory", "value": 78, "max": 100},
        {"label": "Disk", "value": 23, "max": 100}
API Reference
Input
  • msg.payload (object): Data for template generation
  • msg.topic (string): Optional topic (passed through)
Output
  • msg.template (string): Generated HTML template
  • msg._madTemplateAI (object): Generation metadata
Metadata Object
    "cached": false,           // Whether result came from cache
    "model": "gpt-3.5-turbo", // OpenAI model used
    "theme": "madness-dark",   // Applied theme
    "timestamp": 1642678800000, // Generation timestamp
    "inputHash": "abc123..."    // Cache key hash
Cost Optimization
The node includes several features to minimize OpenAI API costs:
  • Smart Caching: Identical requests are cached to avoid duplicate API calls
  • Efficient Hashing: Input data is hashed for optimal cache key generation
  • Fallback Templates: Error scenarios use local templates instead of retrying
  • Configurable Models: Choose cost-effective models for your use case
Error Handling
The node gracefully handles various error scenarios:
  • API Key Issues: Clear validation and error messages
  • Network Problems: Automatic retry with exponential backoff
  • Rate Limiting: Respects OpenAI API limits with proper error handling
  • Invalid Responses: Falls back to error templates with user data
Development
Project Structure
node-red-contrib-mad-template-ai/
├── package.json              # npm configuration
├── mad-template-ai.js         # Main node implementation
├── mad-template-ai.html       # Configuration UI & help
├── examples/                  # Example flows
├── templates/
│   ├── system-prompts/        # Theme-based prompts
│   └── fallbacks/            # Error fallback templates
├── themes/                   # CSS theme files
└── README.md                 # This file
Contributing
  1. Fork the repository
  2. Create a feature branch
  3. Add tests for new functionality
  4. Submit a pull request
MIT License - see LICENSE file for details.
Support
Changelog
v1.0.1
  • Fixed repository URLs to point to MadnessEngineering organization
  • Updated GitHub links and issue tracking
v1.0.0
  • Initial release
  • OpenAI GPT integration
  • Three MadnessInteractive themes
  • Intelligent caching system
  • Comprehensive error handling
  • Example flows and documentation
Built with ❤️ for the MadnessInteractive ecosystem by D. Edens
Version: 1.0.1
Updated 1 year, 6 months ago
  • mad-template-ai
  • ai
  • openai
  • template
  • html
  • dynamic
  • generation
  • llm
  • dashboard
  • madness
  • interactive
  • gpt
  • caching
