node-red-contrib-m-bus 3.2.1
Node-Red node for M-Bus protocol
npm install node-red-contrib-m-bus
Logo
NPM version Downloads
PRs Welcome MIT Licence
NPM
Buy Me A Coffee
Description
Node-Red node that uses node-mbus to communicate with mbus devices via serial or TCP connections.
npm install node-red-contrib-m-bus --save
Hardware
You need an M-Bus-Serial or an M-Bus-Ethernet (TCP) converter. Here a list of tested hardwares:
This package will add a new set of nodes in your node palette.
mbus-client
Configuration node that manage the M-Bus client connection. Once a client is inited it will try to open the SERIAL/TCP connection with provided configuration, if it fails it keeps retry every reconnectTimeout milliseconds. Once the connection is opened it scans the M-Bus network (via secondary IDs) to find all connected devices (if auto scan option is enabled). Once the scan is done (it can takes many minutes, depends on the number of total meters in the network) it will emit the event mbScanComplete with the array of secondary IDs found:
["11490378", "11865378", "11497492"]
Once the scan is completed it will start reading all devices one by one to update values (if auto scan option is enabled), every time a device is updated, the node will emit the event mbDeviceUpdated with the new updated device info/data
  "SlaveInformation": {
    "Id": 11490378,
    "Manufacturer": "ACW",
    "Version": 14,
    "ProductName": "Itron BM +m",
    "Medium": "Cold water",
    "AccessNumber": 41,
    "Status": 0,
    "Signature": 0
  "DataRecord": [
      "id": 0,
      "Function": "Instantaneous value",
      "StorageNumber": 0,
      "Unit": "Fabrication number",
      "Value": 11490378,
      "Timestamp": "2018-02-24T22:17:01"
      "id": 1,
      "StorageNumber": 0,
      "Unit": "Volume (m m^3)",
      "Value": 54321,
      "id": 2,
      "StorageNumber": 1,
      "Unit": "Time Point (date)",
      "Value": "2000-00-00",
      "id": 3,
      "StorageNumber": 1,
      "Value": 0,
      "id": 4,
      "StorageNumber": 0,
      "Unit": "Time Point (time & date)",
      "Value": "2012-01-24T13:29:00",
      "id": 5,
      "StorageNumber": 0,
      "Unit": "Operating time (days)",
      "Value": 0,
      "id": 6,
      "StorageNumber": 0,
      "Unit": "Firmware version",
      "Value": 2,
      "id": 7,
      "StorageNumber": 0,
      "Unit": "Software version",
      "Value": 6,
      "id": 8,
      "Function": "Manufacturer specific",
      "Value": "00 00 8F 13",
If property storeDevices is set to true, once connected, the client will check for existing devices json file mbus_devices_<clientName>.json (where clientName is the name property set in client configuration and MUST BE UNIQUE IF YOU HAVE MULTIPLE M-BUS CLIENTS) that is stored in ~/.node-red dir. If it is a valid Array of strings or Numbers, once it is successfuly loaded, client will emit mbDevicesLoaded event and than start reading devices (scan is skipped so the init process is quicker in this way).
Other mbus-client events are:
  • mbConnected: when the connection has been successfully opened
  • mbClosed: when the connection has been closed
  • mbError: when an error occurs (with error message as argument)
  • mbRestarted: when the client is restarted
  • mbScan: when the scan starts
  • mbPrimarySet: when a device has successfully set a new primary ID
mbus-out
This node will subscribe to a M-Bus client events and will output messages on mbScanComplete, mbDeviceUpdated and mbDevicesLoaded events with data in msg.payload and the event name in msg.topic.
mbus-controller
This node is used to send commands to an M-Bus client. msg.topic must contains command name and msg.payload tha command data. Allowed commands are:
  • scan: Start a scan of devices. Will return an Array of strings with found devices secondary IDs
  • setDevices: Manually set the array of primary and/or secondary IDs of devices to read. Input: msg.payload an Array of Numbers and/or Strings.
  • getDevices: Will return an Object as msg.payload with two properties:
    • devices: Object where keys are devices secondary IDs and values are devices data.
    • errors: Object where keys are devices secondary IDs and values are true if devices has an error
  • getDevice: Input msg.payload.address must contain the address (primary or secondary) of the device to read. Output will contain requested device datas.
  • setPrimary: Input: msg.payload.oldAddr (primary or secondary ID of the device) and msg.payload.newAddr (the new primary ID to set 0-250). Output will contain the same payload as input if success: {newAddr: msg.payload.newAddr, oldAddr:msg.payload.oldAddr}.
  • restart: Restarts the client connection.
IMPORTANT NOTE
Every command is queued, M-Bus is really slow and takes around 2/3 to read one device, many minutes for a scan, don't send repeated commands but wait for the response. Max commands queue is set to 10 commands, after the limit is reached the new command will be pushed in queue and the 'oldest' command in queue will be removed.
M-Bus Dashboard Flow
Flow
Remember to change client settings based on your connection parameters
MBusFlow
Dashboard
Click on a m-bus device row and his data will be displayed in the Data table. Devices get update every 10 seconds. If a device has an error just go to the status circle and a tooltip will show the error. Wire the scanPrimary function node to the mbus controller and set the Mbus client autoScan flag to false to manually scan using primary IDs
MBusDashboard
Flow data
[{"id":"ade0afc8.6013a","type":"tab","label":"M-Bus_Dashboard","disabled":false,"info":""},{"id":"2cebb543.145dca","type":"mbus-out","z":"ade0afc8.6013a","name":"","client":"bf6a52d7.703c1","x":471,"y":242,"wires":[["1aa1a0.ae47ee6"]]},{"id":"1aa1a0.ae47ee6","type":"debug","z":"ade0afc8.6013a","name":"","active":false,"console":false,"complete":"false","x":690,"y":242,"wires":[]},{"id":"4c5da910.a64938","type":"mbus-controller","z":"ade0afc8.6013a","name":"","client":"bf6a52d7.703c1","x":511,"y":303,"wires":[["8028460d.2b4658","22502fe8.d651e"]]},{"id":"250e511a.e4ccee","type":"inject","z":"ade0afc8.6013a","name":"scan","topic":"scan","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"x":122,"y":72,"wires":[["4c5da910.a64938"]]},{"id":"8028460d.2b4658","type":"debug","z":"ade0afc8.6013a","name":"","active":false,"console":false,"complete":"false","x":762,"y":361,"wires":[]},{"id":"c4e7a123.e6ba9","type":"inject","z":"ade0afc8.6013a","name":"Read ID 1","topic":"getDevice","payload":"{\"address\": 1}","payloadType":"json","repeat":"","crontab":"","once":false,"x":129,"y":146,"wires":[["4c5da910.a64938"]]},{"id":"326fb021.ee4a7","type":"inject","z":"ade0afc8.6013a","name":"Get Devices","topic":"getDevices","payload":"","payloadType":"str","repeat":"10","crontab":"","once":true,"x":145,"y":220,"wires":[["4c5da910.a64938"]]},{"id":"22502fe8.d651e","type":"ui_template","z":"ade0afc8.6013a","group":"b06b9c66.757c9","name":"mbus-table","order":0,"width":"14","height":"10","format":"<table>\n  <tr>\n    <th>ID</th>\n    <th>Primary ID</th>\n    <th>Info</th>\n    <th>Data</th>\n    <th>Last Update</th>\n    <th>Status</th>\n  </tr>\n  <tr style=\"cursor:pointer;\" ng-click=\"showData(device)\" ng-repeat=\"(id, device) in devices\">\n    <td>{{ device.secondaryID }}</td>\n    <td>{{ device.primaryID }}</td>\n    <td ng-bind-html=\"getInfo(device)\"></td>\n    <td>{{ device.DataRecord.length }}</td>\n    <td>{{ device.lastUpdate }}</td>\n    <td>\n        <div class=\"online\" ng-style=\"{background: !device.error ? '#4CAF50' : '#f44336'}\">\n            <md-tooltip md-direction=\"bottom\">{{ device.error ? device.error : 'OK' }}</md-tooltip>\n        </div>\n    </td>\n  </tr>\n</table>\n\n<style>\ntable {\n    border-collapse: collapse;\n    width: 100%;\n}\n\nth, td{\n    text-align: left;\n    padding: 8px;\n    background-color: #f2f2f2;\n    color: black;\n}\n\nth {\n    background-color: #4CAF50;\n    color: white;\n}\n\n.online {\n\tbackground:#ff3333;\n\twidth:20px;\n\theight:20px;\n\tmargin:0 auto;\n\t-webkit-border-radius:50%;\n\t-moz-border-radius:50%;\n\tborder-radius:50%;\n}\n</style>\n\n<script>\n\n\n(function(scope) {\n    \n    scope.send({topic: 'getDevices'});\n    scope.devices = [];\n    \n    scope.showData = function(device){\n        scope.send({topic: 'deviceData', payload: device});\n    }\n    \n    scope.getInfo = function(device){\n        var text = '';\n        var info = device.SlaveInformation;\n        \n        for(key in info){\n            text += `<p><b>${key}</b>: ${info[key]}</p>`;\n        }\n        \n        return text;\n    }\n\n    scope.$watch('msg', function(data) {\n        if(data && data.topic){\n            switch(data.topic){\n                case \"getDevices\":\n                    if(data.payload && data.payload.devices)\n                        scope.devices = data.payload.devices;\n                break;\n            }\n        }\n    });\n    \n})(scope);\n\n</script>\n","storeOutMessages":false,"fwdInMessages":false,"templateScope":"local","x":708,"y":303,"wires":[["66aaaff2.c67de"]]},{"id":"8d7abf50.fd2f2","type":"inject","z":"ade0afc8.6013a","name":"restart","topic":"restart","payload":"","payloadType":"num","repeat":"","crontab":"","once":false,"x":119,"y":108,"wires":[["4c5da910.a64938"]]},{"id":"66aaaff2.c67de","type":"ui_template","z":"ade0afc8.6013a","group":"f9357905.6d9348","name":"data-table","order":0,"width":"14","height":"10","format":"<p><b>Device ID:</b> {{ID}} </p>\n\n<br>\n<br>\n\n<table>\n  <tr>\n    <th>ID</th>\n    <th>Function</th>\n    <th>Unit</th>\n    <th>Value</th>\n    <th>Timestamp</th>\n  </tr>\n  <tr ng-repeat=\"(key, data) in deviceData\">\n    <td>{{ data.id }}</td>\n    <td>{{ data.Function }}</td>\n    <td>{{ data.Unit }}</td>\n    <td>{{ data.Value }}</td>\n    <td>{{ data.Timestamp }}</td>\n  </tr>\n</table>\n\n<style>\ntable {\n    border-collapse: collapse;\n    width: 100%;\n}\n\nth, td{\n    text-align: left;\n    padding: 8px;\n    background-color: #f2f2f2;\n    color: black;\n}\n\nth {\n    background-color: #4CAF50;\n    color: white;\n}\n\n.online {\n\tbackground:#ff3333;\n\twidth:20px;\n\theight:20px;\n\tmargin:0 auto;\n\t-webkit-border-radius:50%;\n\t-moz-border-radius:50%;\n\tborder-radius:50%;\n}\n</style>\n\n<script>\n\n\n(function(scope) {\n    \n    scope.deviceData = [];\n    scope.ID = '';\n\n    scope.$watch('msg', function(data) {\n        if(data && data.topic){\n            switch(data.topic){\n                case \"deviceData\":\n                    if(data.payload){\n                        scope.deviceData = data.payload.DataRecord;\n                        scope.ID = data.payload.SlaveInformation.Id;\n                    }\n                break;\n            }\n        }\n    });\n    \n})(scope);\n\n</script>\n","storeOutMessages":false,"fwdInMessages":false,"templateScope":"local","x":872,"y":303,"wires":[[]]},{"id":"51b94291.84bbec","type":"inject","z":"ade0afc8.6013a","name":"Read ID 2","topic":"getDevice","payload":"{\"address\": 2}","payloadType":"json","repeat":"","crontab":"","once":false,"x":130,"y":184,"wires":[["4c5da910.a64938"]]},{"id":"eb834bfa.f39b38","type":"ui_button","z":"ade0afc8.6013a","name":"Scan","group":"9616a562.794988","order":3,"width":"2","height":"1","passthru":false,"label":"Scan","color":"","bgcolor":"","icon":"location_searching","payload":"","payloadType":"str","topic":"scan","x":97,"y":306,"wires":[["4c5da910.a64938"]]},{"id":"39e54d38.9b5692","type":"ui_button","z":"ade0afc8.6013a","name":"Restart","group":"9616a562.794988","order":4,"width":"3","height":"1","passthru":false,"label":"Restart","color":"","bgcolor":"","icon":"refresh","payload":"","payloadType":"str","topic":"restart","x":107,"y":343,"wires":[["4c5da910.a64938"]]},{"id":"a2230246.8fa8e","type":"ui_button","z":"ade0afc8.6013a","name":"GetDevices","group":"9616a562.794988","order":5,"width":"3","height":"1","passthru":false,"label":"Update Devices","color":"","bgcolor":"","icon":"refresh","payload":"","payloadType":"str","topic":"getDevices","x":115,"y":380,"wires":[["4c5da910.a64938"]]},{"id":"109df60b.64ce7a","type":"ui_button","z":"ade0afc8.6013a","name":"readAddress","group":"9616a562.794988","order":2,"width":"3","height":"1","passthru":false,"label":"Read Device","color":"","bgcolor":"","icon":"","payload":"deviceID","payloadType":"flow","topic":"getDevice","x":112,"y":419,"wires":[["2d59897b.43c5a6"]]},{"id":"1f181c53.970904","type":"ui_text_input","z":"ade0afc8.6013a","name":"Device_ID","label":"ID: ","group":"9616a562.794988","order":1,"width":"3","height":"1","passthru":true,"mode":"text","delay":300,"topic":"","x":559,"y":427,"wires":[["936174f7.8cbee8"]]},{"id":"936174f7.8cbee8","type":"function","z":"ade0afc8.6013a","name":"storeID","func":"\nflow.set('deviceID', msg.payload);\n\nreturn msg;","outputs":0,"noerr":0,"x":735,"y":427,"wires":[]},{"id":"2d59897b.43c5a6","type":"function","z":"ade0afc8.6013a","name":"readAddr","func":"var data = {address: msg.payload}\n\nmsg.payload = data;\n\nreturn msg;","outputs":1,"noerr":0,"x":270,"y":419,"wires":[["4c5da910.a64938"]]},{"id":"8be03de0.4f9be","type":"status","z":"ade0afc8.6013a","name":"controller_status","scope":["4c5da910.a64938"],"x":411,"y":97,"wires":[["26b478dc.103528"]]},{"id":"5c04640f.c158dc","type":"status","z":"ade0afc8.6013a","name":"mbus_status","scope":["2cebb543.145dca"],"x":404,"y":142,"wires":[["4d060118.9517e"]]},{"id":"26b478dc.103528","type":"ui_text","z":"ade0afc8.6013a","group":"4b71de29.b4c73","order":0,"width":0,"height":0,"name":"controller_status","label":"Controller","format":"{{msg.status.text}}","layout":"row-spread","x":623,"y":97,"wires":[]},{"id":"4d060118.9517e","type":"ui_text","z":"ade0afc8.6013a","group":"4b71de29.b4c73","order":0,"width":0,"height":0,"name":"mbus_status","label":"M-Bus","format":"{{msg.status.text}}","layout":"row-spread","x":613,"y":142,"wires":[]},{"id":"f81dd19b.fc3","type":"inject","z":"ade0afc8.6013a","name":"setPrimary","topic":"setPrimary","payload":"{\"newAddr\":3,\"oldAddr\":2}","payloadType":"json","repeat":"","crontab":"","once":false,"x":121,"y":35,"wires":[["4c5da910.a64938"]]},{"id":"fe4bfc1.4bd76","type":"ui_text_input","z":"ade0afc8.6013a","name":"Old_ID","label":"Old ID","group":"9616a562.794988","order":6,"width":"3","height":"1","passthru":true,"mode":"text","delay":300,"topic":"","x":566,"y":467,"wires":[["f7602233.01b7a"]]},{"id":"f7602233.01b7a","type":"function","z":"ade0afc8.6013a","name":"storeID","func":"\nflow.set('oldID', msg.payload);\n\nreturn msg;","outputs":0,"noerr":0,"x":733,"y":467,"wires":[]},{"id":"b61ffa85.eeed28","type":"ui_text_input","z":"ade0afc8.6013a","name":"New_ID","label":"New ID","group":"9616a562.794988","order":7,"width":"3","height":"1","passthru":true,"mode":"text","delay":300,"topic":"","x":563,"y":507,"wires":[["42a6992e.212798"]]},{"id":"42a6992e.212798","type":"function","z":"ade0afc8.6013a","name":"storeID","func":"\nflow.set('newID', msg.payload);\n\nreturn msg;","outputs":0,"noerr":0,"x":731,"y":507,"wires":[]},{"id":"a77dced1.37ff7","type":"ui_button","z":"ade0afc8.6013a","name":"SetPrimary","group":"9616a562.794988","order":8,"width":"3","height":"1","passthru":false,"label":"Set Primary ID","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"setPrimary","x":111,"y":460,"wires":[["17478b65.117325"]]},{"id":"17478b65.117325","type":"function","z":"ade0afc8.6013a","name":"setPrimary","func":"var data = {\n    oldAddr: flow.get('oldID'), \n    newAddr:flow.get('newID')\n    }\n\nmsg.payload = data;\n\nreturn msg;","outputs":1,"noerr":0,"x":280,"y":460,"wires":[["4c5da910.a64938"]]},{"id":"70de0f84.b91ec","type":"inject","z":"ade0afc8.6013a","name":"","topic":"getDevice","payload":"counter","payloadType":"flow","repeat":"3","crontab":"","once":false,"x":130,"y":520,"wires":[["5f55e860.d8f058"]]},{"id":"5f55e860.d8f058","type":"function","z":"ade0afc8.6013a","name":"scanPrimary","func":"\nif(msg.payload == null) msg.payload = 1;\n\nif(msg.payload >= 76) msg.payload = 1;\n\nmsg.payload++;\n\nflow.set(\"counter\",msg.payload);\n\nmsg.payload = {address: msg.payload};\n\nreturn msg;","outputs":1,"noerr":0,"x":310,"y":520,"wires":[[]]},{"id":"6d7d88b.d8f2b78","type":"inject","z":"ade0afc8.6013a","name":"setDevices","topic":"setDevices","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":120,"y":260,"wires":[["b238e6a0.e02928"]]},{"id":"b238e6a0.e02928","type":"function","z":"ade0afc8.6013a","name":"devices","func":"var devices = [\"1\",\"2\",\"3\",\"4\",\"5\",\"6\",\"7\",\"8\",\"9\",\"10\",\"11\",\"12\",\"13\",\"14\",\"15\",\"16\",\"17\",\"18\",\"19\",\"20\",\"21\",\"22\",\"23\",\"24\",\"25\",\"26\",\"27\",\"28\",\"29\",\"30\",\"31\",\"32\",\"33\",\"34\",\"35\",\"36\",\"37\",\"38\",\"39\",\"40\",\"41\",\"42\",\"43\",\"44\",\"45\",\"46\",\"47\",\"48\",\"49\",\"50\",\"51\",\"52\",\"53\",\"54\",\"55\",\"56\",\"57\",\"58\",\"59\",\"60\",\"61\",\"62\",\"63\",\"64\",\"65\",\"66\",\"67\",\"68\",\"69\",\"70\",\"71\",\"72\",\"73\",\"74\",\"75\",\"76\"];\n\nmsg.payload = devices;\n\nreturn msg;","outputs":1,"noerr":0,"x":258,"y":260,"wires":[["4c5da910.a64938"]]},{"id":"bf6a52d7.703c1","type":"mbus-client","z":"","name":"local","clienttype":"serial","tcpHost":"127.0.0.1","tcpPort":"2000","serialPort":"/dev/ttyUSB0","serialBaudrate":"2400","reconnectTimeout":"10000","autoScan":true,"storeDevices":true,"disableLogs":true},{"id":"b06b9c66.757c9","type":"ui_group","z":"","name":"M-Bus Devices","tab":"16de0243.87ddfe","order":3,"disp":true,"width":"14"},{"id":"f9357905.6d9348","type":"ui_group","z":"","name":"Data","tab":"16de0243.87ddfe","order":4,"disp":true,"width":"14"},{"id":"9616a562.794988","type":"ui_group","z":"","name":"Commands","tab":"16de0243.87ddfe","order":2,"disp":true,"width":"14"},{"id":"4b71de29.b4c73","type":"ui_group","z":"","name":"Status","tab":"16de0243.87ddfe","order":1,"disp":true,"width":"14"},{"id":"16de0243.87ddfe","type":"ui_tab","z":"","name":"M-Bus","icon":"plug","order":1}]
Testing
To test last version of this node from master:
  1. Clone this repo git clone https://github.com/robertsLando/node-red-contrib-m-bus
  2. Link the node to node-red modules:
go to the downloaded directory cd node-red-contrib-m-bus and run sudo npm link. in your node-red user directory (cd ~/.node-red) run: npm link node-red-contrib-m-bus.
Authors
Daniel Lando
Version: 3.2.1
Updated 2 years, 2 months ago
Rating: 4.7 3
84 in the last week
  • mbus-client
  • mbus-out
  • mbus-controller
  • m-bus
  • mbus
