node-red-contrib-ltcodes 0.1.0
Node-RED node that checks Lithuanian personal codes, company codes, VAT numbers and IBANs
A Node-RED node that checks Lithuanian personal codes (asmens kodas), company codes (įmonės kodas), VAT numbers (PVM mokėtojo kodas) and IBANs, and routes each message to a "valid" or an "invalid" output.
Useful in form, CRM and invoicing flows: stop a mistyped company code or IBAN before it reaches an accounting system.
From the Node-RED editor: Manage palette → Install → node-red-contrib-ltcodes.
Or in your Node-RED user directory (usually ~/.node-red):
npm install node-red-contrib-ltcodes
Use
The LT code check node is in the function category.
- Code in – the message property that holds the code,
msg.payloadby default. - Check as – any Lithuanian code, or only a personal code, a company code, a VAT number or an IBAN.
The node adds msg.ltcodes:
"code": "33309240064",
"valid": true,
"kinds": ["personal"],
"birthDate": { "year": 1933, "month": 9, "day": 24 }
kinds lists everything the code is valid as (personal, company, vat, iban); a company code is often also a valid VAT number. An example flow is under Import → Examples → node-red-contrib-ltcodes.
What is checked
- Personal code: 11 digits, the first digit gives the century and sex, the next six the birth date, and the last one is a check digit. Codes that start with 9 carry no date, so only the check digit is tested.
- Company code: 9 digits with a check digit.
- VAT number: 9 or 12 digits, with or without the
LTprefix. - IBAN: 20 characters that start with
LT, checked with the MOD-97 rule.
The check digit only proves that a code is well formed, not that it was issued to anyone. The checks come from the @ellolt/ltcodes package and pass the shared test cases of the ltcodes repository.
Made by KokybiskaSvetaine.lt. Licence: MIT.
