node-red-contrib-lsh-logic 3.1.14
A Node-RED node for coordinating devices that implement the public LSH MQTT/protocol contract.
npm install node-red-contrib-lsh-logic
Node-RED Contrib LSH Logic
npm Node-RED Library npm downloads CI Node.js Latest Release License
works with MQTT Homie
node-red-contrib-lsh-logic is the Node-RED node that runs the LSH coordination logic inside a flow. It listens to the public LSH MQTT contract, keeps a live registry of configured devices, coordinates distributed long-click actions, publishes commands, and emits alerts when a bridge or controller needs attention.
The package also includes two small helper nodes:
  • lsh-external-state stores non-LSH actor state in the context shape that the coordinator reads for smart toggles;
  • lsh-actuator-sync mirrors a downstream smart device state back to the LSH actuator that powers it.
The original LSH installation uses Controllino controllers and ESP32 bridges, but the useful boundary is the protocol: if a device stack publishes the same LSH and Homie topics, this node can orchestrate it from Node-RED.
LSH Logic Node
When to Use It
Use this node when Node-RED should own the orchestration layer for LSH-compatible devices:
  • track configured devices, actuator state, and Homie lifecycle;
  • react to long-click and super-long-click events;
  • send commands back to LSH devices;
  • route generic intents to flows that target Zigbee, Tasmota, Home Assistant, or custom systems;
  • keep external actor state available for smart-toggle decisions;
  • synchronize downstream smart bulbs or modules back to the upstream LSH relay when an external app changes their state;
  • keep startup, watchdog, and recovery behavior predictable after restarts.
The node is focused on LSH messages; its input expects the LSH protocol. Keep other devices in normal Node-RED flows, and handle LSH-generated intents through the Other Actor Commands output.
Install it from the Node-RED Palette Manager, or from your Node-RED user directory:
Node.js 18 or newer is required.
Basic Wiring
The usual flow is small:
  1. Wire mqtt in into lsh-logic.
  2. Wire output 1 to mqtt out for LSH commands.
  3. Wire output 2 to your non-LSH actor flow.
  4. Wire output 3 to notifications or a debug node.
  5. Wire output 4 back to the same mqtt in node for dynamic subscriptions.
  6. Use output 5 while developing or diagnosing a flow.
LSH Logic Flow
Dynamic subscriptions are the recommended setup. Leave the mqtt in topic empty and let lsh-logic keep the topic list aligned with the devices in the inline System Config.
Example import: examples/lsh-logic.json
Configure the Node
Most installations touch two places:
  • the Node-RED editor fields for MQTT paths, payload protocol, timing, and optional context exports;
  • the inline System Config JSON, which lists LSH devices and long-click actions.
The editor validates that JSON against the LSH System Config shape, offers LSH-specific JSON completions/snippets, previews the exact MQTT topic set, and can import the generated lsh-stack-config/v1 export from lsh-core.
Multiple lsh-logic nodes can run in the same Node-RED runtime when each one owns a distinct LSH stack, MQTT topic space, or isolated test flow. Keep their context export keys separate when helpers read exported state or config: use flow for self-contained flows, global when helper flows must share the same coordinator exports, and none when no flow needs that optional export.
Start with a small config and add actions one at a time:
  "devices": [
      "name": "c1",
      "longClickButtons": [
          "id": 1,
          "actors": [
              "name": "j1",
              "allActuators": true,
              "actuators": []
          "otherActors": ["zigbee_table_lamp"]
      "name": "j1"
That means: when device c1 reports a long click on button 1, toggle all actuators on device j1 and also emit an intent for zigbee_table_lamp.
Outputs
Output Name Typical destination
1 LSH Commands mqtt out, for commands to LSH devices and bridge service.
2 Other Actor Commands User flows that translate generic intents to other systems.
3 Alerts Notifications, logs, metrics, or a debug node.
4 Configuration The same upstream mqtt in node for dynamic subscriptions.
5 Debug Original inbound messages after successful processing.
The second output is deliberately protocol-neutral. The node emits the intended state; your surrounding flow decides how a Zigbee light, Tasmota plug, Home Assistant service, or local script should receive it.
External State Helper
Use lsh-external-state when a non-LSH actor appears in otherActors and the coordinator must know its current boolean state before choosing a smart-toggle direction. The helper accepts MQTT or flow messages from ESPHome, Zigbee2MQTT, Shelly, Home Assistant, or custom integrations, normalizes the configured state property to a boolean, and stores it as:
<otherDevicesPrefix>.<actorName>.state
Retained MQTT state is accepted by default because this helper only stores observed state; it does not command devices. Point External State Store at the same context selected by the lsh-logic node in Read External Actor State. The prefix can come from the exported lsh_config.otherDevicesPrefix, which avoids mismatches when the main node uses a custom prefix.
Multiple lsh-external-state nodes can run in the same Node-RED instance. They do not conflict when each instance stores a different actor, or when separated flows intentionally use different context stores or prefixes.
Example import: examples/lsh-external-state.json
External State Flow
Actuator Sync Helper
Use lsh-actuator-sync when a smart device is powered through an LSH actuator but can also be controlled from another app or system. The helper consumes those external state updates, reads the selected lsh-logic context exports, and emits a Homie state/set command only when the upstream LSH actuator needs to be aligned.
The flow remains explicit: collect the external device state, use a Change node or Function node to add msg.deviceId and msg.actuatorId, then wire the helper output to the same MQTT output used for LSH commands. If you run more than one lsh-logic node, give each one unique state/config export keys and point each helper instance at the matching keys.
Multiple lsh-actuator-sync nodes can run side by side. The normal pattern is one helper policy per downstream device, or per group of devices that share the same retained-message, direction, cooldown and state-parsing rules.
Example import: examples/lsh-actuator-sync.json
Actuator Sync Flow
Runtime Behavior
The node is intentionally conservative. It reuses retained conf and state snapshots, but it does not treat retained lifecycle traffic as proof that a device is alive right now. Distributed clicks are confirmed only when target state is authoritative, and recovery probes are rate-limited so an unreachable device does not flood the broker.
The Node-RED status text stays compact: it reports coordinator state plus device registry, bridge and controller reachability counts.
JSON payloads are the default. MsgPack is available when your firmware supports it and the upstream mqtt in node preserves LSH payloads as Buffers.
Documentation
The full documentation map lives in DOCS.md. Start there when you want configuration details, optional Homie discovery guidance, dynamic subscription behavior, or the lifecycle contract.
If you are new to the wider LSH stack, the project-level starting points are:
Maintainer Notes
The published package supports Node.js 18 or newer. The local quality gate runs type checking, linting, Markdown checks, formatting checks, package validation, coverage, and a production dependency audit:
npm ci
npm run check
For the isolated network-click scenarios alone:
npm run test:network-clicks
These exercise the real wrapper and installed coordinator using synthetic Node-RED messages in JSON and MessagePack: request/ACK/confirm, duplicate and retained events, expired/replaced correlations and invalid targets. They never connect to a broker or actuate hardware. Coordinator-only regressions, including a target going offline after ACK, are tested in the coordinator repository; its fixes must be released there before updating this package's dependency.
Apache-2.0. See LICENSE.
Version: 3.1.14
Updated 3 weeks ago
108 in the last week
  • lsh-logic
  • lsh-actuator-sync
  • node-red-node
  • lsh
  • lsh-protocol
  • home-automation
  • smart-home-automation
  • typescript
  • mqtt
  • mqtt-automation
  • homie
  • smart-home
