node-red-contrib-ls-jms 0.2.1
Node-RED nodes to send and receive jms messages leveraging lightstreamer jms extender (https://lightstreamer.com/ls-jms-features)
npm install node-red-contrib-ls-jms
This projects contributes nodes to Node-Red (https://nodered.org/) to send and receive JMS messages by leveraging the lightstreamer jms extender (https://lightstreamer.com/ls-jms-features). While lightstreamer jms extender does the heavy work to actually perform JMS communication, this project bridges this communication into the node-red context by providing
  • an input node that receives JMS messages
  • an output node that sends JMS messages
  • a configuration node to setup the communication
If you have installed Node-RED as a global node.js package (you use the command node-red anywhere to start it), you need to install node-red-contrib-ls-jms as a global package as well.
npm install -g node-red-contrib-ls-jms
If you have a local node.js project, then you may install it as a local packages
npm install node-red-contrib-ls-jms --save
After installing node-red-contrib-ls-jms there are new nodes in the palette labelled with 'ls jms'. An input node for receiving jms messages. An output node for sending jms messages.
ls-jms-in-node
ls-jms-out-node
Drag and drop them onto the canvas of the node-red-editor as any other nodes. Configrue these nodes by double-clicking. For both nodes you can set a name, the destination type (queue or topic), the name of the destination and the lightstreamer jms configuration node.
ls-jms-in-node-config
The configuration node configures the reference to the lightstreamer jms extender. The lightstreamer jms extender has a configuration of its own for accessing jms brokers (refer to the lightstreamer jms extender documentation). In the configuration node you set the url of the lightstreamer jms extender and the name of the adapter (to the the jms broker) in the lightreamer jms extender configuration file
ls-jms-config-node
After applying these settings the configuration node can be referenced by any input or output node.
ls-jms-config-node2
Release History
  • 0.1.0 Initial release
The MIT License (MIT)
Copyright (c) 2014 gklevi
Version: 0.2.1
Updated 7 years, 3 months ago
6 in the last week
  • ls-jms-in
  • ls-jms-out
  • ls-jms-config
  • jms
  • lightstreamer
