node-red-contrib-loki-utils 1.0.0
Node-RED nodes for Grafana Loki — AI generated, provided as-is without ongoing maintenance
npm install node-red-contrib-loki-utils
No Maintenance Intended
Node-RED nodes for Grafana Loki log aggregation.
Note: This package was generated with AI assistance and is provided as-is without active maintenance. Issues and pull requests are welcome but may not be responded to. Use at your own risk in production environments. MIT licensed — feel free to fork and maintain your own version.
Node Description
loki-config Shared server configuration (URL + credentials)
loki-query On-demand LogQL query
loki-watch Polls Loki and triggers on new matching log lines
loki-tail Real-time log streaming via WebSocket
loki-labels Lists label names and/or their values
loki-ready Health check — is Loki up and ready?
loki-clean Removes all loki properties from a message
How runtime configuration works
All query nodes (loki-query, loki-watch, loki-tail, loki-labels) share the same pattern for runtime configuration:
1. Static config — set values in the node editor. Simplest option, no extra nodes needed.
2. Mustache templates — use {{property}} in string fields to resolve values from the incoming message at runtime. No upstream node needed:
{app="{{payload.app}}"} |= "{{payload.level}}"
3. msg.lokiOptions — set a single object on the message to override any node config value. One Change node to set it, one loki-clean node to remove it:
msg.lokiOptions = {
    query:    '{app="myapp"} |= "error"',
    lookback: '30m',
    output:   'lines',
Control commands for loki-watch and loki-tail are sent as msg.payload:
msg.payload = "stop";   // pause
msg.payload = "start";  // resume
msg.payload = "reset";  // reset watermark (loki-watch only)
Resource and load considerations
loki-watch (polling)
One HTTP request per poll interval per node. At the default 5 second interval that is 12 requests per minute. Zero load between polls. Load is linear and predictable. Tolerant of brief Loki outages.
loki-tail (WebSocket streaming)
One persistent WebSocket connection per node. Real-time delivery with no polling delay. However:
  • Loki has a default limit of 10 simultaneous tail connections
  • More resource intensive on Loki than poll queries
  • Logs during a connection gap are not delivered on reconnect
Rule of thumb: use loki-tail for sub-second latency with a small number of watchers. Use loki-watch for everything else.
Palette Manager (easiest)
Node-RED → ☰ menu → Manage palette → Install → search node-red-contrib-loki
npm
loki-tail extra requirement
cd ~/.node-red && npm install ws
Setup
  1. Drag any loki node onto the canvas and double-click it
  2. Click the pencil icon next to the Server dropdown
  3. Enter your Loki URL, optional credentials, and a name (e.g. prod-loki)
  4. All loki nodes in all flows share this config node
Multiple config nodes work for multiple environments:
[prod-loki]     https://loki.prod.internal
[staging-loki]  http://loki.staging.internal
[local-loki]    http://localhost:3100
Working with arrays and individual messages
All line-output nodes support two modes:
  • lines — one message with an array of all entries
  • each — one message per log line
Convert between them with built-in Node-RED nodes:
  • lines → individual: wire into a Split node
  • individual → array: wire into a Join node
Example flows
Alert on new error logs:
[loki-watch: {app="myapp"} |= "error", 10s, each]
  → [Switch: msg.lokiLabels.severity == "critical"]
  → [notification node]
Query with dynamic parameters:
[Inject or UI trigger]
  → [Change: msg.lokiOptions = { query: '{app="myapp"}', lookback: '30m' }]
  → [loki-query]
  → [loki-clean]
  → [next stage]
Health monitoring:
[Inject: every 60s] → [loki-ready] → [Switch: msg.lokiReady == false] → [alert]
Real-time dashboard:
[loki-tail: {namespace="prod"}, each] → [Function: format] → [UI node]
Requirements
  • Node-RED 2.0+
  • Node.js 16+ (18+ recommended)
  • Grafana Loki 2.x+
  • ws npm package (loki-tail only)
MIT
Version: 1.0.0
Updated 7 months, 3 weeks ago
  • loki-config
  • loki-query
  • loki-watch
  • loki-tail
  • loki-labels
  • loki-ready
  • loki-clean
  • loki
  • grafana
  • logs
  • logql
  • no-maintenance-intended
