node-red-contrib-logic-combiner 1.0.0
Node-RED logic combiner - combines multiple boolean inputs with AND/OR
npm install node-red-contrib-logic-combiner
Node-RED Logic Combiner - combines multiple boolean inputs with individual AND/OR operators per input.
  • AND / OR operator configurable per topic
  • Up to 99 topics
  • Inversion per topic (NOT)
  • Truthy/Falsy evaluation
  • Min. topics before first output
  • Optional initial value
Behavior
  • Each input is identified by msg.topic
  • Per topic configurable: Operator (AND/OR), Label, Inversion
  • Calculation is performed sequentially in the configured order
  • Output as soon as minTopics is reached
Example
Complex logic: (Pump AND NOT Fault) OR Bypass
Input 1 (Pump)         = true  → Start
Input 2 (Fault)   AND  = false → NOT → true
Input 3 (Bypass)  OR   = true
Calculation: (true AND true) OR true = true
Property Description Default
Min. Topics Number of topics before first output all
Initial Value Initial value for topics none
Topics List with: Operator (AND/OR), Topic, Label, NOT -
Topic Configuration
Each topic has the following properties:
  • Operator (AND/OR): Combination with the previous result (first topic = Start)
  • Topic: The msg.topic value for identification
  • Label: Descriptive name (optional)
  • NOT: Inverts the value before combination
Input
  • msg.payload - Any value (truthy/falsy)
  • msg.topic - Required - Must match a configured topic
Truthy/Falsy
Falsy (= false): false, 0, "", null, undefined, NaN, "false", "0", "off"
Truthy (= true): Everything else: true, 1, "on", etc.
Runtime Override
msg.reset true = reset all values
Output
{ "payload": true }
Use Cases
Application Configuration
Safety circuit EmergencyStop AND Door AND Release
Alarm system Sensor1 OR Sensor2 OR Sensor3
Ready state Pump AND (NOT Fault)
Complex (Pump AND NOT Fault) OR Bypass
Node Status
  • → true (3/3) - Result active
  • → false (3/3) - Result inactive
  • Waiting (1/3 Topics) - Not enough data yet
Author
sr.rpo
MIT
Version: 1.0.0
Updated 8 months ago
125 in the last week
  • logic-combiner
  • logic
  • and
  • or
  • boolean
  • combiner
  • plc
