node-red-contrib-local-context 1.0.5
A lightweight Node-RED package for creating and managing nested local execution contexts directly on message objects using a simple push/pop reference map.
npm install node-red-contrib-local-context
A lightweight Node-RED package for managing nested local scratchpads on messages.
The package provides two nodes for creating and removing local context layers:
  • Local Context — creates a new local scratchpad layer.
  • End Local Context — removes the current layer or completely terminates the local context system.
The current scratchpad can be accessed from a Function node using msg.scratchpad(), or more easily via msg.local which holds an updated reference to the newest item in msg.refmap.
Why local contexts?
Local contexts provide a convenient way for a flow to maintain temporary, flow-specific data without adding numerous properties directly to msg.
Each Local Context node creates a new scratchpad object. Nested local contexts can therefore be used when a flow needs temporary state with well-defined lifetimes.
For example:
        Local Context
       │  scratchpad │
        Local Context
       │  scratchpad │
     End Local Context
       (Pop local context)
        End Local Context
       (Terminate all)
The inner scratchpad exists only while the inner context is active. When it is popped, the previous context becomes active again.
Local Context
The Local Context node creates a new local scratchpad for the message.
If the message does not already have a local context system, the node initializes one.
Every time the node is executed, a new scratchpad layer is created.
For example, after one Local Context node:
Local Context stack
│ scratchpad 1  │  ← current
After another Local Context node:
Local Context stack
│ scratchpad 2  │  ← current
│ scratchpad 1  │
The scratchpads are independent objects, allowing nested operations to maintain their own temporary state.
End Local Context
The End Local Context node provides two operations.
Pop local context
Removes the current scratchpad and returns to the previous local context.
For example:
Before:
│ scratchpad 1  │
After:
This is useful when a nested operation has completed but the outer local context is still required.
Terminate all local context
Completely removes the local context system from the message.
This removes all local scratchpads and the associated local-context function.
This mode is intended as the final cleanup operation when the message no longer needs any local context.
Accessing the current scratchpad
The nodes manage the lifetime of the local contexts. A Function node can access the currently active scratchpad using:
msg.local
For example:
const local = msg.local;
local.counter = 10;
local.name = "example";
The next Function node can access the same scratchpad:
node.warn(local.counter);
node.warn(local.name);
The important distinction is that msg.local is primarily an access mechanism. The Local Context and End Local Context nodes should be used to create and remove context layers.
Nested scratchpads
Local contexts can be nested to provide temporary state with different lifetimes.
For example:
                 Local Context
             │ Outer scratchpad│
                 Function
                msg.local
                 Local Context
             │ Inner scratchpad│
                 Function
                msg.local
             End Local Context
              Pop local context
             Outer scratchpad
             becomes current
For example, the outer Function node might store:
msg.local.value = "outer";
After creating an inner context, another Function node can use:
msg.local.value = "inner";
While the inner context is active, msg.local refers to the inner scratchpad.
After the End Local Context → Pop local context node executes, the outer scratchpad becomes current again.
Therefore:
msg.local.value
again refers to the "outer" value.
Example flow
A typical flow might look like:
│ Local Context │
│ Function        │
│ local =         │
│ msg.local     │
│ local.user = {} │
│ Local Context │
│ Function        │
│ local =         │
│ msg.local     │
│ local.result=.. │
│ End Local Context      │
│ Pop local context      │
│ Terminate all context  │
Context lifetime
The local context is stored directly on the message.
A typical lifecycle is:
Local Context
Create scratchpad
Use msg.local from Function nodes
Local Context
Create nested scratchpad
Use nested scratchpad
End Local Context
(Pop)
Return to previous scratchpad
End Local Context
(Terminate)
Remove local context system
This makes local contexts particularly useful for subflows or processing sections where temporary state needs to exist only for the duration of a particular operation.
Node-RED Palette Manager
Once the package is available in the Node-RED Flow Library, it can be installed through:
Node-RED → Manage palette → Install
Search for:
npm
The package can also be installed from the Node-RED user directory:
For a Docker-based Node-RED installation using /data as the user directory:
cd /data
Restart Node-RED after installation.
Version: 1.0.5
Updated 1 month, 2 weeks ago
  • local-context
  • end-local-context
  • local-context
  • context
  • refspec
