node-red-contrib-linking-device 1.0.3
A Node-RED node to scan/control BLE devices called 'Linking device'.
npm install node-red-contrib-linking-device
[日本語]
A Node-RED node for providing access to BLE(Bluetooth Low Energy) devices called Linking devices.
See Project Linking for more information about the Linking Device.
There are following three nodes:
  • linking-scanner : To get beacon(sensor) data from Linking device
  • linking-sensor : To connect to Linking device and get sensor data
  • linking-led : To connect to Linking device and turn on LED.
Supported Devices
Supported
  • Tukeru TH (temperature, humidity, LED)
  • Sizuku THA (temperature, humidity, pressure, LED)
  • Tomoru / Tomoru full-color (LED)
  • Sizuku LED
  • Pochiru / Pochiru(eco) (button, LED)
  • Sizuku 6x (gyroscope, accelerometer, orientation, LED)
  • Sizuku Lux (illuminance, LED)
  • Oruto (motion sensor)
Note: Actual test has only be done with Tukeru TH, Sizuku THA, Sizuku Lux and Pochiru(eco).
Unsupported
  • Furueru (Vibration)
  • Oshieru (door sensor)
  • Kizuku (Vibration sensor)
  • BLEAD-TSH-LK
Dependencies
  • Linux OS (Tested on Raspberry Pi 3)
  • nodejs >= 8.0 (Tested by v8.11.3)
  • node-red (Tested by v0.18.7)
  • noble : Using modified version maintained by jrobeson/noble which doesn't work on MacOS.
  • node-linking
Install guide
Install bluetooth libraries
sudo apt-get -y install bluetooth libbluetooth-dev libudev-dev
Install node-red-contrib-linking-device
In your node-red directory:
Restart node-red
node-red-stop && node-red-start
Get beacon data by using linking-scanner
1.After installation you can see theree new nodes in Linking device category of pallete.
2.Drag-and-Drop the linking-scanner node into workspace, then double-click it.
  • Check Start automatically at startup
  • Set Interval to 60 (seconds).
3.Drag-and-Drop debug node then connect it with linking-scanner.
4.Press Deploy
You can see output messages like below every 60 seconds in debug tab.
msg: {
  advertisement: object,
  payload: {
    device: "Sizuku_tha0141790",
    service: "temperature",
    data: 25.625
  topic: "Sizuku_tha0141790_temperature"
advertisement is a LinkingAdvertisement object of node-linking. You can get detailed information like rssi from the object.
Get sensor data by using linking-sensor
1.Drag-and-Drop the linking-sensor node into workspace, then double-click it.
  • Select device
  • Select type of sensor (you might have to wait 10~20 seconds to get available sensors).
2.Drag-and-Drop debug node then connect it with linking-scanner.
3.Press Deploy
msg: {
  payload: {
    data: 25.625
It's almost the same with linking-scanner except advertisement.
Turn on LED by using linking-led
1.Drag-n-Drop the linking-led node into workspace, then double-click it.
  • Select device
  • Select color and pattern (you might have to wait 10~20 seconds to get available colors and patterns).
2.Drag-n-Drop inject node then connect it with linking-scanner.
  • Set payload of inject node to boolean true
3.Press deploy
4.Click inject node and see the LED turns on
You might have to wait 10~20 seconds to turn on LED.
Notes
Connection
Keeping connection extends battery life of Linking Device.
Range of Linking Device is not so long. If connection is unstable I recommend to use linking-scanner only.
Use linking-sensor with linking-scanner
If you use linking-sensor, use also linking-scanner. If linking-sensor fails to connect to the device, linking-scanner ges sensor data.
Use linking-led with linking-sensor
It takes 10-20 seconds to turn on LED when device is disconnected. Setting "Keep connection" in edit dialog will keep the device connectiong. But in the device is connected, linking-scanner can't get sensor from beacon signal. You should use linking-sensor in this case.
Useful Links
  • node-linking : node-red-contrib-linking-device is heavily relied on this library. Thanks!
Copyright (c) 2018 Takesh Inoue <[email protected]>
Licensed under the Apache License, Version 2.0 (the "License");
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
Version: 1.0.3
Updated 7 years, 5 months ago
12 in the last week
  • linking-scanner
  • linking-led
  • linking-sensor
  • Linking
  • IoT
  • Bluetooth
  • BLE
