node-red-contrib-line-notify 3.1.3
line notify node
npm install node-red-contrib-line-notify
An easy-to-use NodeRED node for sending Line Notify.
Note
The handling method of the message using the msg variable differs depending on the version.
3.0.0 or higher
Handle messages with msg.payload.
2.1.0 or lower
Handle messages with msg.message.
Usages
  1. Obtain an access token with LINE Notify and set it in the linetoken node.
  2. Enter necessary items on the setting screen and execute.
  3. LINE receives notification.
For further details of see LINE Notify API Document.
Version: 3.1.3
Updated 4 years, 11 months ago
Rating: 5.0 4
42 in the last week
  • line-notify
  • linetoken
  • line
