node-red-contrib-limit-latest 0.1.0
A Node-RED node that limits message flow by keeping only the latest value.
npm install node-red-contrib-limit-latest
Or install via the Node-RED Palette Manager.
Add the limit-latest node to your flow. It appears under the function category.
The node throttles incoming messages using a trailing strategy:
  1. The first message always passes through immediately.
  2. Any messages arriving within the configured time window are buffered — each new message replaces the previous one.
  3. When the window expires, the latest buffered message is sent.
Setting Description Default
Limit Number of time units per window 5
Unit Second, Minute, Hour, or Day Second
A blue pending status dot is shown on the node while a message is buffered.
MIT
Version: 0.1.0
Updated 7 months, 3 weeks ago
  • limit-latest
  • throttle
  • rate-limit
  • debounce
  • filter
  • latest
