node-red-contrib-lifesmart 2.0.1
A Node-RED node for Lifesmart smart home gateway integration with local device control and management
npm install node-red-contrib-lifesmart
Node-RED Lifesmart Gateway Integration
A specialized Node-RED node for integrating with Lifesmart brand local gateways. This node enables communication and control of Lifesmart smart home devices through their local gateway protocol.
  • Gateway Discovery: Automatically discover Lifesmart gateways on the local network
  • Device Management: Retrieve and control connected smart devices
  • Real-time Communication: UDP-based communication with Lifesmart gateways
  • Device Control: Send commands to control various Lifesmart devices including switches, sensors, and plugins
  • Multi-device Support: Support for multiple device types including:
    • Smart switches (SL_SW_ND series)
    • Blinds/Curtains (SL_CN_IF, SL_P)
    • Human sensors (ZG#HE200_ZB, SL_SC_BM, SL_SC_CM)
    • Smart plugs (SL_OL_3C, SL_OE_W, SL_OL_W)
Via Node-RED Palette Manager
  1. Open Node-RED in your browser
  2. Go to Menu → Manage Palette
  3. Click on the Install tab
  4. Search for geeqee-node-lifesmart
  5. Click Install
Manual Installation
  1. Navigate to your Node-RED user directory (usually ~/.node-red)
  2. Run the following command:
    npm install geeqee-node-lifesmart
  3. Restart Node-RED
Lifesmart In Node
Receives messages from Lifesmart gateways and devices.
Configuration:
  • Port: UDP port to listen on
  • Multicast: Enable/disable multicast listening
  • Interface: Network interface to bind to
  • Output Format: Choose between Buffer, UTF8 string, or Base64
Output Messages:
  • msg.payload: Device data or gateway response
  • msg.ip: Source IP address
  • msg.port: Source port
  • msg.ssid: Message type identifier
Lifesmart Out Node
Sends commands to Lifesmart gateways and devices.
Configuration:
  • Address: Target gateway IP address
  • Port: Target UDP port (default: 12348)
  • Multicast: Broadcast/multicast options
  • Local Port: Local binding port
Input Messages:
  • msg.action: Command type ("gateways", "devices", "control")
  • msg.args: Command arguments (for control actions)
  • msg.ip: Target IP (overrides node configuration)
  • msg.port: Target port (overrides node configuration)
Usage Examples
1. Gateway Discovery
// Send gateway discovery command
msg.action = "gateways";
2. Device Discovery
// Get all devices from gateway
msg.action = "devices";
3. Device Control
// Control a smart switch
msg.action = "control";
msg.args = {
    idx: "gateway_id",
    me: "device_id",
    type: "P1",
    val: 1  // Turn on
Message Types
Gateway Search Response
  • msg.ssid: "lifesmart_gateway_search"
  • msg.payload: JSON string containing gateway information
Device List Response
  • msg.ssid: "lifesmart_device_search"
  • msg.payload: JSON string containing array of devices with formatted information
Device Types Mapping
Device Code Type Description
SL_SW_ND* switch Smart switches (1-3 gang)
SL_CN_IF, SL_P blind Curtain/blind controllers
ZG#HE200_ZB, SL_SC_BM, SL_SC_CM humansensor Motion/presence sensors
SL_OL_3C, SL_OE_W, SL_OL_W plugin Smart plugs
Protocol Details
The node communicates with Lifesmart gateways using a proprietary UDP protocol:
  • Port: 12348 (default)
  • Format: Binary protocol with JSON payload
  • Authentication: MD5-signed requests with timestamp
  • Discovery: Broadcast "Z-SEARCH" command
File Structure
node-red-lifesmart/
├── geeqee-lifesmart.js      # Main node implementation
├── geeqee-lifesmart.html    # Node configuration UI
├── package.json             # Package configuration
├── locales/                 # Internationalization
│   └── zh-CN/
│       └── geeqee-node.json # Chinese translations
└── readme.md               # This file
Building Package
To create a distributable package:
tar -zvcf lifesmart.tgz package/
ISC License
Support
For issues and feature requests, please refer to the project documentation or contact the maintainer.
Version History
  • v2.0.0: Current version with enhanced device support and improved protocol handling
Version: 2.0.1
Updated 1 year, 3 months ago
  • lifesmart in
  • lifesmart out
  • lifesmart
  • smart-home
  • iot
  • gateway
  • device-control
  • automation
  • udp
  • local-network
  • switches
  • sensors
  • blinds
  • plugins
