node-red-contrib-lgtv-notify 1.0.5
Send toast notifications to LG webOS TVs from Node-RED. Works with webOS 10+ (2025 TVs).
npm install node-red-contrib-lgtv-notify
Send toast notifications to LG webOS Smart TVs from Node-RED.
Works with webOS 10+ (2025 TVs) - Includes built-in SSL handling for newer TV firmware.
  • Simple toast notifications on your LG TV
  • Works with webOS 3.0 and newer (including 2025 models)
  • Automatic SSL certificate handling (no manual configuration needed)
  • Auto-reconnection and message queuing
  • Saves pairing key for seamless future connections
From Node-RED Palette Manager
  1. Open Node-RED
  2. Go to Menu > Manage palette > Install
  3. Search for node-red-contrib-lgtv-notify
  4. Click Install
From Command Line
Then restart Node-RED.
Setup
  1. Drag an LG TV notify node onto your flow
  2. Double-click to configure
  3. Add a new TV configuration with your TV's IP address
  4. Deploy
  5. Important: Check your TV for a pairing prompt and accept it
After accepting the pairing prompt once, the node will remember the connection key.
Basic Example
[inject] → [lgtv-notify] → [debug]
Set msg.payload to your notification message:
msg.payload = "Someone is at the front door!";
Example Flow
Import this flow into Node-RED (Menu → Import):
[{"id":"a1b2c3d4","type":"inject","name":"Send Notification","props":[{"p":"payload"}],"payload":"Hello from Node-RED!","payloadType":"str","repeat":"","crontab":"","once":false,"x":160,"y":100,"wires":[["e5f6g7h8"]]},{"id":"e5f6g7h8","type":"lgtv-notify","name":"LG TV","tv":"","message":"","x":370,"y":100,"wires":[["i9j0k1l2"]]},{"id":"i9j0k1l2","type":"debug","name":"Response","active":true,"tosidebar":true,"complete":"true","x":540,"y":100,"wires":[]}]
  1. Import the flow above
  2. Double-click the "LG TV" node and configure your TV's IP address
  3. Deploy
  4. Accept the pairing prompt on your TV
  5. Click the inject button to send a notification
Home Automation Example
[mqtt in] → [function] → [lgtv-notify]
doorbell      format
Function node:
msg.payload = "Doorbell: " + msg.payload;
Requirements
  • LG webOS Smart TV (webOS 3.0 or newer)
  • TV and Node-RED on the same network
  • "LG Connect Apps" enabled on the TV
    • Settings > General > External Device Manager > LG Connect Apps
Troubleshooting
TV not connecting
  1. Make sure the TV is powered on (not in standby)
  2. Check that "LG Connect Apps" is enabled
  3. Verify the IP address is correct
  4. The TV takes ~25 seconds after power-on before the API is available
Pairing prompt not appearing
  • Restart Node-RED and redeploy the flow
  • Try removing and re-adding the TV configuration
Notifications not showing
  • Notifications only appear when the TV is on and displaying content
  • Maximum message length is 60 characters
Support
If you find this useful, consider buying me a coffee:
Buy Me A Coffee
MIT
Credits
Built on lgtv2 by Sebastian Raff.
Version: 1.0.5
Updated 11 months, 2 weeks ago
  • lgtv-config
  • lgtv-notify
  • lgtv
  • lg
  • webos
  • tv
  • notification
  • toast
  • smart-home
  • home-automation
