node-red-contrib-lg 0.7.3
Node-RED nodes to control and monitor LG ThinQ air conditioners and LG webOS TVs.
npm install node-red-contrib-lg
node-red-contrib-lg
  • ❄️ Air conditioners (LG ThinQ) β€” one lg-ac node: send commands in, get live state out (turn on/off, set mode / temperature / fan).
  • 🌑️ AC status β€” temperature, power, mode, etc. are emitted on a schedule even when the AC is off, plus real-time push so changes made on the AC itself (its remote, the LG app) emit instantly.
  • πŸ“Ί TVs (LG webOS) β€” one lg-tv node: turn on (Wake-on-LAN) / off / toggle, plus picture settings (OLED Pixel Brightness, Reduce Blue Light, picture preset); on/off events out.
  • πŸ”‘ Automatic auth β€” log in once with your LG account; the refresh token is extracted and saved for reuse.
Unofficial project. Not affiliated with or endorsed by LG. Use at your own risk.
From your Node-RED user directory (usually ~/.node-red):
Or use Menu β†’ Manage palette β†’ Install and search for node-red-contrib-lg.
Restart Node-RED. Two nodes (LG AC, LG TV) appear under the LG category, plus the LG ThinQ account config node.
Requires Node.js 18+ and Node-RED 3.0+.
Node Kind Purpose
lg-account config LG ThinQ account + shared device poller
lg-ac in + out Control an AC and emit its state (after commands and on every poll)
lg-tv in + out Control a webOS TV (on/off/toggle + picture settings) and emit on/off events
Each device is a single node: wire your commands into its input, and wire its output to read state. There are ready-made example flows under Menu β†’ Import β†’ Examples β†’ node-red-contrib-lg.
Quick start β€” Air conditioners (ThinQ)
1. Configure your account
Add an lg-account config node (it appears when you drop an lg-ac node and open it):
  • Country β€” the ISO code of the country your LG account is registered in (e.g. US, GB, PT).
  • Language β€” e.g. en-US, pt-PT.
  • Username / Password β€” your LG ThinQ account credentials.
  • Click Extract refresh token / Test. This logs in, pulls a long-lived refresh token (filled into the field) and lists your devices. Click Done and Deploy.
How the token is handled:
  • It is stored as an encrypted Node-RED credential when you use the button.
  • At runtime it is also cached to disk at <userDir>/node-red-contrib-lg/thinq-<nodeId>.token, so restarts never need a fresh username/password login. If the refresh token ever becomes invalid, the node automatically logs in again using the stored username/password.
2. Add an AC β€” lg-ac
Pick the account and the AC from the dropdown. The single lg-ac node both takes commands on its input and emits the AC state on its output.
Input β€” commands (msg.payload):
msg.payload Effect
true / "on" Turn on
false / "off" Turn off
"status" Just read the current state now
22 (number) Set target temperature to 22 Β°C
"cool" / "heat" / "fan" / "dry" / "auto" Set mode
{ "power": true, "mode": "COOL", "temperature": 22, "fan": "HIGH" } Set several at once
{ "verticalVane": 1, "horizontalVane": 1 } Aim the louvers (1 = top / left … higher = down / right; "swing" = sweep; "off" = stop)
{ "swing": "both" } Swing shorthand ("vertical" / "horizontal" / "both" / "off")
{ "raw": { "airState.xxx": n } } Escape hatch: send any LG airState.* key directly
Rapid or concurrent messages to the same AC are serialized (applied one-at-a-time, in order), so a sequence of changes behaves like the LG app rather than overlapping into 0103 errors.
An LG AC rejects mode/temperature/fan changes while it is off, so the node automatically turns the AC on first when you change one of those while it is off (power-on is sent before the other settings, with a short gap so the unit is ready). Turning the AC off ignores any other settings in the same message. This makes it safe to drive from HomeKit, where power, mode and temperature arrive as separate messages. Set msg.deviceId to target a different AC at runtime.
Output β€” state is emitted after every command and on each poll cycle:
  "topic": "<deviceId>",
  "deviceId": "<deviceId>",
  "name": "Living room",
  "event": "change",
  "changed": ["power"],
  "payload": {
    "online": true,
    "power": true,
    "mode": "COOL",
    "currentTemperature": 23.5,
    "targetTemperature": 22,
    "fanSpeed": "HIGH",
    "humidity": null,
    "verticalVane": 1,
    "horizontalVane": 1
Vane positions are raw LG values: 0 = stop, 1..N = fixed position, 100 = swing. The valid fixed positions are model-dependent (e.g. vertical 1–6, horizontal 1–5).
msg.event tells you why it was emitted: initial / change / periodic (from polling), command (after a control), or query (after a "status" request). Enable Raw to also get the raw airState.* snapshot in msg.raw.
Output behaviour:
  • Poll (checkbox on the lg-ac node) β€” emit on every poll cycle (a steady heartbeat; always reports the current temperature, even while off). The poll interval lives on the account node (default 60 s, minimum 10 s) and is shared by all lg-ac nodes.
  • Real-time pushes β€” changes made on the AC itself (its remote, the LG app) are emitted instantly (event: "change") whenever Real-time is enabled on the account node. This is the single MQTT switch; there is no per-device toggle β€” every lg-ac gets pushes for its device.
For change-only output, turn Poll off (with the account's Real-time on you then receive only instant change pushes) β€” or add a filter/rbe node after the lg-ac node. Turn Poll off and the account's Real-time off to make the node control-only (no status output).
Quick start β€” TVs (webOS)
The lg-tv node is self-contained (no separate config node): it holds the connection, takes control commands on its input, and emits on/off events on its output.
1. Configure the node β€” lg-tv
  • IP address β€” the TV's IP (give it a static lease on your router).
  • MAC β€” the TV's MAC address. Required to turn the TV on via Wake-on-LAN.
  • Broadcast β€” usually 255.255.255.255 (or your subnet broadcast, e.g. 192.168.1.255).
  • Reconnect β€” retry interval (seconds, default 5) used while the TV is off. On/off detection is event-driven (an off is detected almost immediately); this interval is how quickly an off β†’ on transition is noticed. Lower it for snappier detection.
  • Secure β€” leave off to try ws://…:3000 first; enable for TVs that require wss://…:3001.
  • Action β€” From msg.payload (default), or hard-wire on / off / toggle.
On the TV, enable Settings β†’ General β†’ Mobile TV On (and keep Quick Start+ on) so Wake-on-LAN works while the TV is in standby.
Pairing: the first time Node-RED connects, the TV shows a pairing prompt β€” accept it once. The pairing key is then stored at <userDir>/node-red-contrib-lg/webos-<nodeId>.key.
2. Use it
Input β€” commands: with Action set to From msg.payload, send "on", "off", or "toggle". An object payload changes picture settings instead β€” { "brightness": 40 } (OLED Pixel Brightness, 0–100), { "reduceBlueLight": true }, { "pictureMode": "cinema" }. The TV has to be on for those. See the command reference for the full set.
Output β€” state is emitted whenever the TV turns on or off (and after a command):
  "topic": "Living room TV",
  "event": "on",
  "payload": { "power": true, "state": "On", "connected": true }
msg.event is on / off for status changes, or command right after a control. Detection uses the webOS power-state subscription when available, and falls back to the websocket connection state on older TVs.
Command reference
Air conditioner β€” lg-ac
Send any of these as msg.payload on the input. Set msg.deviceId to target a different AC than the one configured. Changing mode/temperature/fan/vane while the AC is off turns it on first; sending an "off" ignores any other settings in the same message.
Shortcut payloads
msg.payload Effect
true / "on" Power on
false / "off" Power off
"status" (or msg.topic = "status") Read current state, change nothing
a number, e.g. 22 Set target temperature (Β°C)
"cool" / "heat" / "dry" / "fan" / "auto" / "air_clean" Set mode
Object payload β€” combine any of these fields in one object:
Field Accepted values
power true / false (also "on", "off", "start", "stop", 1, 0)
mode "COOL", "DRY", "FAN", "HEAT", "AIR_CLEAN", "AUTO" (case-insensitive) or the numeric value
temperature number in Β°C (sent as-is; valid range is model-dependent, typically 16–30)
fan "SLOW", "SLOW_LOW", "LOW", "LOW_MID", "MID", "MID_HIGH", "HIGH", "POWER", "AUTO" or the numeric value
verticalVane 0 = stop, 1–6 = fixed position (1 = top), 100 = swing β€” or "off" / "swing"
horizontalVane 0 = stop, 1–5 = fixed position (1 = left), 100 = swing β€” or "off" / "swing"
swing "vertical", "horizontal", "both", "off" (shorthand for setting both louvers to swing/stop)
raw { "airState.<key>": value, … } β€” sends those LG keys verbatim (escape hatch for anything not modelled)
Example: { "power": true, "mode": "COOL", "temperature": 22, "fan": "HIGH", "verticalVane": 1, "horizontalVane": 1 }
Numeric value maps (for raw or when sending numbers):
Mode # Fan #
COOL 0 SLOW 0
DRY 1 SLOW_LOW 1
FAN 2 LOW 2
HEAT 4 LOW_MID 3
AIR_CLEAN 5 MID 4
AUTO 6 MID_HIGH 5
HIGH 6
POWER 7
AUTO 8
Which modes / fan speeds / vane positions a unit actually supports β€” and the exact numbers β€” is model-dependent; the fan map above is LG's standard enum but some models differ. The authoritative list is the device's model JSON (modelJsonUri, Value['airState.windStrength'].value_mapping). LOW / MID / HIGH (2 / 4 / 6) are reliable. AUTO fan is windStrength value 8 (LG's model JSON labels this value "NATURE", but it is the "auto" fan the app exposes).
An unsupported value returns resultCode 0001. A transient resultCode 0103 means the unit couldn't apply the command at that moment (busy, or fan speed while in an auto-managed mode, or just after a power/mode change) β€” the node now retries these automatically; if it still fails, the AC was likely in a mode that doesn't allow that change (e.g. fan speed in AUTO).
Output msg (emitted after a command and on every poll / real-time change):
Field Description
payload { online, power, mode, modeValue, currentTemperature, targetTemperature, fanSpeed, fanSpeedValue, humidity, energyWatts, verticalVane, horizontalVane }
event initial / change / periodic (poll) Β· command (after a control) Β· query (after "status") Β· change (real-time MQTT push)
changed array of fields that changed (poll / push)
deviceId, topic the AC device id
raw the raw airState.* snapshot (only if Raw is enabled)
commands labels of the commands that were sent (after a control)
TV β€” lg-tv
Set the node's Action to From msg.payload (default) and send a command, or hard-wire the Action to on / off / toggle (then the payload is ignored).
Input msg.payload β€” power:
msg.payload Effect
true / "on" / 1 Turn on (Wake-on-LAN)
false / "off" / 0 Turn off
"toggle" Toggle on/off
{ "power": true } / { "power": false } On / off
Input msg.payload β€” picture settings (the TV has to be on):
msg.payload Effect
{ "brightness": 40 } OLED Pixel Brightness, 0–100 (the backlight setting)
{ "reduceBlueLight": true } the TV's "Reduce Blue Light" toggle (eyeComfortMode)
{ "pictureMode": "cinema" } picture preset
{ "picture": { "backlight": 40, "contrast": 80 } } any picture setting, verbatim
Several can be combined in one message β€” { "brightness": 90, "reduceBlueLight": false } is applied as a single write. Keys inside picture override the shorthands above. Other picture keys the TV accepts: brightness (Black Level), contrast, color, sharpness, colorTemperature, energySaving, peakBrightness, dynamicContrast.
Brightness is stored per picture preset, and separately for SDR and HDR β€” pass pictureMode in the same message when the result has to be deterministic. Energy Saving can clamp or override it. The picture category's own brightness key is Black Level, not the panel light, which is why { "brightness": n } maps to backlight.
After a picture-settings write the node reads the same keys straight back, so msg.payload.actual is what the TV really holds (null if the read-back itself failed) rather than an echo of the request. When the two differ the node logs a warning β€” which is how you catch a value that was clamped or landed in a different preset / SDR-HDR slot.
The notification a picture write puts on screen
Every picture write shows a short notification on the TV for about 2 seconds, naming what changed in the TV's own menu language:
Message On screen (TV set to English / Portuguese)
{ "reduceBlueLight": true } Reduce Blue Light on / Reduzir a luz azul ligado
{ "reduceBlueLight": false } Reduce Blue Light off / Reduzir a luz azul desligado
{ "brightness": 30 } OLED Pixel Brightness 30% / Brilho dos pΓ­xeis OLED 30%
{ "reduceBlueLight": true, "brightness": 70 } Reduce Blue Light on | OLED Pixel Brightness 70% / Reduzir a luz azul ligado | Brilho dos pΓ­xeis OLED 70%
{ "pictureMode": "cinema" } Picture settings updated / DefiniΓ§Γ΅es de imagem atualizadas
Settings changed together are piped into one line. Only reduceBlueLight and brightness are named β€” a pictureMode or a raw picture key is not spelled out, since listing every key would make the line unreadable; a write with none of the named settings in it shows the generic line. Lines are capped at 80 characters, which no language's copy reaches (the longest is French at 65), so the cap only ever trims an absurd value passed through the raw picture escape hatch.
This is not decoration and it cannot be switched off: LG refuses ssap://settings/setSystemSettings from a paired third-party client, so a settings write has to go out as a system notification whose action carries the luna:// call β€” and closing that notification is what executes the write. No notification, no write. Since it is going to be on screen anyway, it says what it is doing.
Two consequences worth knowing:
  • The write lands when the notification closes, so it takes effect ~2 s after the message arrives, and the output message follows it.
  • One message, one notification. Send everything in a single message β€” { "brightness": 20, "reduceBlueLight": true } β€” and you get one write and one notification naming both changes on one line (Reduzir a luz azul ligado | Brilho dos pΓ­xeis OLED 20%). Sending the same two settings as two messages at the same time produces two writes and two notifications.
The TV's menu language is read once from localeInfo and cached until it reconnects. Copy ships for en, pt, es, fr, de, it, nl, pl, sv, da, nb, fi, tr and ru; any other language falls back to English, as does a TV that will not report its locale.
Input msg.payload β€” raw escape hatches:
msg.payload Effect
{ "request": "ssap://…", "params": { … } } any SSAP call; the response becomes msg.payload
{ "luna": "luna://…", "params": { … } } any luna service call
Settings writes have to take the luna route: LG refuses ssap://settings/setSystemSettings from third-party clients, so the node smuggles the call through a system alert (which may flash briefly on screen). Needs webOS 4 or newer. Volume, inputs and app launch have no shorthand β€” use request for those.
Output msg (emitted whenever the TV turns on/off and after a command):
Field Description
payload status change / power command: { power: boolean, state: string, connected: boolean } (state is the webOS label, e.g. On, Off) Β· picture settings: { ok: true, settings: { … }, actual: { … } } Β· luna: { ok: true, … } Β· request: the raw SSAP response
event on / off (status change) or command (after a control)
topic the TV name
How it works
  • ThinQ uses the (unofficial) LG ThinQ v2 cloud API: a gateway lookup, an OAuth login that yields a refresh token, and periodic polling of service/homes for each device's snapshot. AC commands are control-sync Set calls (airState.operation, airState.opMode, airState.tempState.target, airState.windStrength).
  • Real-time updates use LG's AWS IoT MQTT broker: the plugin requests a client certificate (it generates an RSA key + CSR), connects over mutual-TLS MQTT and subscribes to the account's topics. LG pushes a delta ({ deviceId, data: { state: { reported } } }) whenever a device changes, which is merged into the cached snapshot and emitted instantly. The poll runs alongside it for periodic temperature and as a fallback if MQTT is unavailable.
  • webOS uses the local WebSocket protocol (via lgtv2) for control and power-state subscription, and a built-in Wake-on-LAN magic packet to power on. Picture settings go through luna://com.webos.settingsservice/setSystemSettings, carried by a system alert because LG blocks the plain SSAP setter for third-party clients.
The poller and the MQTT connection are shared by all lg-ac nodes on the same account.
Notes & limitations
  • This relies on LG's cloud for ThinQ; if LG changes the API it may need updating.
  • Supported AC fan-speed values and modes vary by model; you can always pass a raw numeric value.
  • TV power-on requires Wake-on-LAN to be enabled on the TV and a reachable broadcast address.
  • TV picture settings need the TV on and webOS 4 or newer; the alert used to carry the write may flash briefly on screen. Which keys and values are accepted varies by model.
  • ThinQ "v1" (older) devices are not specifically handled; this targets ThinQ v2 ACs.
Development
npm install
npm test                 # unit + node-load tests (no network)
# Optional read-only live checks against a real LG account (never send control commands):
[email protected] LG_PASSWORD=secret LG_COUNTRY=PT LG_LANGUAGE=en-US npm run smoke:thinq
[email protected] LG_PASSWORD=secret LG_COUNTRY=PT LG_LANGUAGE=en-US npm run smoke:mqtt
Credits
Protocol details were learned from the excellent community projects homebridge-lg-thinq and homebridge-webos-tv.
MIT Β© Miguel Ruivo
Version: 0.7.3
Updated 2 months, 2 weeks ago
319 in the last week
  • lg-account
  • lg-ac
  • lg-tv
  • lg
  • thinq
  • webos
  • air conditioner
  • ac
  • tv
  • smart home
  • home automation
