node-red-contrib-levoit-purifier 0.2.0
Node-RED node for Levoit air purifiers (Vital 100S, Core 200S/300S/400S/600S) via VeSync cloud API
npm install node-red-contrib-levoit-purifier
Node-RED node for controlling Levoit air purifiers via the VeSync cloud API.
  • Two-step OAuth authentication — supports the current VeSync API (2025+)
  • EU and US region support — automatic cross-region redirect
  • Dynamic device discovery — devices populate in dropdown from the VeSync API
  • Air purifier control — power on/off, fan speed, mode (auto/manual/sleep), display, child lock
  • Status polling — periodic status updates with PM2.5, filter life, air quality
  • Zero dependencies — uses only Node.js built-in https and crypto modules
  • Credentials stored securely — via Node-RED's built-in credential system
Supported Devices
Model Tested
Vital 100S (LAP-V102S) ✅
Vital 200S Should work
Core 200S Should work
Core 300S Should work
Core 400S Should work
Core 600S Should work
Via Node-RED Palette Manager
Search for node-red-contrib-levoit-purifier in Manage palette → Install.
Via npm
Quick Start
  1. Drag a levoit purifier node onto your flow
  2. Create a new Levoit Config — enter your VeSync app email, password, and select your region
  3. Click Test Connection to verify credentials
  4. Deploy the flow
  5. Open the purifier node again — your devices will appear in the dropdown
  6. Select your device, set poll interval, and deploy
Control via input messages
// Turn on / off
{ "payload": "on" }
{ "payload": "off" }
// Set fan speed (1-4)
{ "payload": { "action": "speed", "value": 2 } }
// Set mode: "manual", "auto", "sleep"
{ "payload": { "action": "mode", "value": "auto" } }
// Poll status
{ "payload": "status" }
// Display on/off
{ "payload": "display_on" }
{ "payload": "display_off" }
// Child lock
{ "payload": "child_lock_on" }
{ "payload": "child_lock_off" }
Output
The node outputs msg.payload with the current device status on every poll and after every command.
MIT
Credits
API protocol based on research from pyvesync, homebridge-levoit-air-purifier, and openHAB VeSync binding.
Disclaimer
This software is NOT an official Levoit or VeSync product. Levoit and VeSync are registered trademarks of VeSync Co., Ltd.
Version: 0.2.0
Updated 7 months, 1 week ago
  • levoit-config
  • levoit-purifier
  • levoit
  • air-purifier
  • vesync
  • vital-100s
  • core-300s
  • smart-home
  • iot
  • air-quality
  • pm25
