node-red-contrib-letmepost 0.1.0
Node-RED nodes for letmepost.dev — publish to Bluesky, X/Twitter, LinkedIn, Instagram, Threads, Facebook, Pinterest and TikTok through one API, plus a signed webhook trigger.
npm install node-red-contrib-letmepost
Node-RED nodes for letmepost.dev — the open-source social-media publishing API. Publish or schedule to Bluesky, X/Twitter, LinkedIn, Instagram, Threads, Facebook, Pinterest and TikTok through one API, and trigger flows from signed webhook deliveries.
Node What it does
letmepost-config Config node holding your API key and base URL.
letmepost-publish Publish or schedule a post (POST /v1/posts).
letmepost-get-post Fetch a post and its attempts (GET /v1/posts/{id}).
letmepost-list-accounts List connected accounts (GET /v1/accounts).
letmepost-webhook Trigger a flow on a signature-verified webhook event.
From your Node-RED user directory (~/.node-red):
Or in the editor: Menu → Manage palette → Install and search for node-red-contrib-letmepost. Restart Node-RED.
Requires Node.js 18+ (uses the global fetch) and Node-RED 3.0+.
Configure credentials
  1. Mint an API key in the letmepost dashboard under Settings → API Keys (lmp_live_… for production, lmp_test_… for the test environment).
  2. Drop any letmepost node onto a flow, open it, and next to Connection click the pencil to add a new letmepost-config.
  3. Paste the key into API Key. Leave Base URL as https://api.letmepost.dev unless you self-host.
The key is stored encrypted in Node-RED's credentials store, never in the flow JSON.
Nodes in detail
letmepost-publish
Publishes or schedules a post. Each node field can be overridden by the matching msg property (msg wins; otherwise the node config is used).
  • Account IDs — comma-separated IDs, or an array on msg.accountIds. Each becomes a target { accountId }.
  • Platform — used only when no account IDs are given; auto-resolves to the single connected account for that platform (e.g. bluesky).
  • Text — applied to every target.
  • First Comment — auto-posted reply where the platform supports it.
  • Schedule At — ISO-8601 timestamp in the future; queues the batch (HTTP 202, status queued).
  • Profile ID, Idempotency Key — optional. The idempotency key is sent as the Idempotency-Key header so retries never double-post.
  • msg.media — optional array of MediaInput objects, passed through verbatim (e.g. [{ "kind": "image", "mediaId": "med_…" }]).
  • msg.payload.targets — advanced: if msg.payload already contains a targets array, the whole payload is sent as the request body and the fields above are ignored. Use this to build arbitrary multi-target / per-target override shapes.
Output msg.payload is the CreatePostResponse envelope: { id, status, createdAt, results[] }. The node status reflects the batch status (published / partial_failed / failed / queued).
letmepost-get-post
GET /v1/posts/{id}. Set Post ID on the node or msg.postId. Output msg.payload is the PostDetail (the post row plus attempts[]).
GET /v1/accounts. Optional Profile ID filter (or msg.profileId). Output msg.payload is the array of Account objects. Feed an account's id into the publish node's Account IDs.
letmepost-webhook
Triggers a flow when letmepost delivers an event. It registers an HTTP POST route at the configured URL Path, verifies the signature, and emits the event only when valid.
This node does not register itself with the API. Webhook endpoints are created from the letmepost dashboard — the registration API is a dashboard-session operation and does not accept an lmp_live_ API key. Register the URL by hand:
Setup
  1. Pick a URL Path (default /letmepost-webhook). Your public URL is the Node-RED base URL plus this path, e.g. https://your-host:1880/letmepost-webhook. Node-RED has to be reachable from the public internet for letmepost to deliver to it.
  2. In the letmepost dashboard, go to Settings → Webhooks, add an endpoint, and paste that public URL. Choose the event types you want (post.published, post.failed, token.expiring, …) or subscribe to all.
  3. Copy the signingSecret (whsec_…) the dashboard shows once at creation into the node's Signing Secret field.
Verification. Each delivery carries X-Letmepost-Signature: sha256=<hex>, an HMAC-SHA256 of the raw request body keyed by the signing secret (no timestamp). The node recomputes it over the exact received bytes and compares in constant time. Deliveries that fail get a 401 and are dropped; malformed JSON gets a 400.
Output: msg.payload is the parsed event, msg.topic is the event type.
Errors
Action nodes report API failures via node.error(err, msg), so a Catch node downstream can handle them. The message surfaces the letmepost error code, the failed rule, the remediation, and the requestId.
Apache-2.0
Version: 0.1.0
Updated 5 months, 1 week ago
  • letmepost-config
  • letmepost-publish
  • letmepost-get-post
  • letmepost-list-accounts
  • letmepost-webhook
  • letmepost
  • social-media
  • publishing
  • webhook
  • bluesky
  • twitter
  • linkedin
  • instagram
  • threads
  • pinterest
  • tiktok
