node-red-contrib-lennox-icomfort 0.1.1
Node-RED node for controlling Lennox iComfort thermostats
npm install node-red-contrib-lennox-icomfort
A Node-RED node for controlling Lennox iComfort thermostats
  • Control and monitor Lennox iComfort thermostats
  • Config node for secure credential storage
  • Polling support (interval or manual refresh)
  1. Add a Lennox iComfort Thermostat node to your flow (one per thermostat).
  2. Configure credentials in the config node.
  3. Set the polling interval.
  4. Optionally enable 'Create global variable':
    • This will update a global variable named Lennox_{GatewaySN}_status with the current device status on each refresh.
    • The global variable is useful for dashboards and control flows.
  5. Use one or more Lennox iComfort Command nodes to send commands to the thermostat:
    • Select a command. Only relevant fields will be shown.
  6. Command may also be set directly in the incoming message. See the built-in help text in the Thermostat node for additional info.
    • The command node ignores incoming message parameters and always sends its configured command.
Deadband enforcement:
  • For setSetpoints, the cooling setpoint must be at least 3°F higher than the heating setpoint. The editor will prevent saving if this is not met.
  • For level up/down commands, the thermostat node will automatically adjust the other setpoint if needed to maintain the 3°F deadband.
  • In High Dehumidification mode, the deadband is 5°F. This is not currently handled by this node. Setpoint or level up/down command may silently fail if they don't meet this deadband requirement and the thermostat is in this mode. See https://www.lennox.com/literature/Lennox_icomfortWiFi_Installation_Manual.pdf (page 17).
  • Supported commands: refresh, systemInfo, setSetpoints, setThermostatMode, setFanMode, away, home, heatLevelUp, heatLevelDown, coolLevelUp, coolLevelDown.
    • Level up/down commands adjust the setpoint by 1º and do not require setpoint input.
    • For setSetpoints, both heating and cooling setpoints are required.
Notes
  • Only Fahrenheit units are currently supported.
  • If required parameters are missing, the node will throw an error.
Development
  • PRs and issues welcome!
MIT
Version: 0.1.1
Updated 1 year ago
179 in the last week
  • lennox-icomfort-config
  • lennox-icomfort-thermostat
  • lennox-icomfort-command
  • lennox
  • icomfort
  • thermostat
