node-red-contrib-leafengines 1.0.0
Node-RED nodes for LeafEngines Agricultural Intelligence API - Soil analysis, weather, crop recommendations, carbon credits, and MCP integration
npm install node-red-contrib-leafengines
npm version License: MIT
Node-RED nodes for LeafEngines Agricultural Intelligence API. Connect your agricultural automation workflows to soil analysis, crop recommendations, weather data, carbon credit calculations, and more.
  • 20+ Agricultural Intelligence Endpoints - Soil, water, weather, crop, carbon, and AI analysis
  • Tier-Based Access Control - Automatically respects Free, Starter, Pro, and Enterprise rate limits
  • Offline-First Architecture - Built-in caching with formal uncertainty quantification
  • MCP Protocol Support - Compatible with Claude Desktop and other MCP agents
  • Visual Workflow Builder - Drag-and-drop agricultural intelligence automation
Method 1: Node-RED Palette Manager (Recommended)
  1. Open Node-RED (usually at http://localhost:1880)
  2. Go to Menu → Manage Palette
  3. Click Install tab
  4. Search for node-red-contrib-leafengines
  5. Click Install
Method 2: npm CLI
# Install globally for all Node-RED instances
npm install -g node-red-contrib-leafengines
# Or install locally to your Node-RED user directory
Method 3: Manual Installation
npm install https://github.com/soilsidekickpro/node-red-contrib-leafengines.git
Quick Start
1. Get Your API Key
  1. Visit soilsidekickpro.com/podcast for podcast-exclusive access
  2. Request your sandbox API key (ak_sandbox_*)
  3. Receive key via email (typically within a few hours)
2. Configure LeafEngines
  1. Drag a LeafEngines Config node to your flow
  2. Double-click to configure:
    • Name: Your configuration name
    • API Key: Your ak_sandbox_* key
    • API URL: https://[project].supabase.co/functions/v1
    • Tier: Select your subscription tier
3. Create Your First Soil Analysis Flow
[inject] → [LeafEngines Soil] → [debug]
Configure the LeafEngines Soil node:
  • Configuration: Select your config node
  • County FIPS: Enter a 5-digit FIPS code (e.g., 48453 for Napa County, CA)
  • Output Format: Choose Full Analysis, Summary Only, or Minimal Data
4. Deploy and Test
  1. Click Deploy
  2. Click the inject node button
  3. Check debug panel for soil analysis results
Available Nodes
Configuration Nodes
  • LeafEngines Config - API key management and connection settings
Specialized Data Nodes
  • LeafEngines Soil - USDA soil composition by county FIPS (Free tier)
  • LeafEngines Weather - Live weather and soil fusion data (Starter tier)
  • LeafEngines Water - EPA water quality monitoring and analytics (Starter tier)
  • LeafEngines Crop - AI crop recommendations, planting calendars, and plant identification (Starter/Pro tier)
  • LeafEngines Carbon - Carbon credit estimation with practice change analysis (Pro tier)
  • LeafEngines Prescription - Variable-rate prescription generation (Pro tier)
Optimization Nodes
  • LeafEngines Batch - Batch multiple API calls into single requests (optimizes rate limits)
  • LeafEngines Query - Generic node for any LeafEngines endpoint
Coming Soon Nodes
  • LeafEngines Environmental - Environmental impact scoring and risk assessment
  • LeafEngines Satellite - Google Earth Engine satellite integration
  • LeafEngines AI Chat - Advanced conversational AI (Enterprise tier)
  • LeafEngines Visual - Visual crop analysis and diagnostics
Example Flows
1. Automated Soil Health Monitoring
// Flow: Daily soil analysis with alerting
[schedule: daily 8am] → [LeafEngines Soil] → [function: check thresholds] → [switch: alert if needed] → [email/sms alert]
2. Irrigation Optimization
// Flow: Smart irrigation scheduling
[weather forecast] → [LeafEngines Soil] → [LeafEngines Water] → [function: calculate irrigation] → [sprinkler controller]
3. Carbon Credit Reporting
// Flow: Automated carbon credit calculation
[field sensor data] → [LeafEngines Carbon] → [function: format report] → [Google Sheets] → [email report]
4. Variable-Rate Application
// Flow: Real-time prescription generation
[GPS position] → [LeafEngines Soil] → [LeafEngines Prescription] → [function: format for equipment] → [sprayer controller]
5. Batch-Optimized Field Analysis
// Flow: Comprehensive analysis with batch optimization
[field parameters] → [prepare batch requests] → [LeafEngines Batch] → [combine results] → [field health score] → [report]
6. Carbon Credit Automation
// Flow: Automated carbon credit reporting
[field data] → [LeafEngines Carbon] → [practice change analysis] → [report generator] → [regulatory submission]
API Endpoints by Tier
Free Tier (2 endpoints)
  • get-soil-data - USDA soil composition
  • county-lookup - Geographic resolution
Starter Tier ($149/mo, 8 endpoints)
  • All Free tier endpoints plus:
  • territorial-water-quality - EPA water monitoring
  • multi-parameter-planting-calendar - Planting optimization
  • live-agricultural-data - Weather/soil fusion
  • environmental-impact-engine - Risk scoring
  • safe-identification - Plant ID with toxic lookalike warnings
Pro Tier ($499/mo, 7 endpoints)
  • All Starter tier endpoints plus:
  • agricultural-intelligence - AI crop recommendations
  • carbon-credit-calculator - Carbon credit estimation
  • generate-vrt-prescription - Variable-rate prescriptions
  • leafengines-query - Natural language interface
Enterprise Tier ($1,999/mo, 3 endpoints)
  • All Pro tier endpoints plus:
  • gpt5-chat - Advanced conversational AI
  • visual-crop-analysis - Visual diagnostics
  • geo-consumption-analytics - Geographic pattern analysis
Rate Limits & Batch Optimization
Standard Rate Limits
Tier Requests/Minute Requests/Day Concurrent Batch Size
Free 10 1,000 2 5
Starter 30 5,000 5 10
Pro 100 25,000 10 25
Enterprise 500 100,000 25 50
Effective Rate Limits with Batching
Tier Individual Calls With Batching (5 calls/batch) Improvement
Free 10/min 50/min 5x
Starter 30/min 150/min 5x
Pro 100/min 500/min 5x
Enterprise 500/min 2,500/min 5x
Batch Optimization Tip: A single POST containing multiple JSON-RPC calls counts as 1 rate-limited request. The LeafEngines Batch node automatically optimizes multiple API calls into single batch requests.
Batch Optimization Examples
  1. Soil + Water + Weather Analysis (3 calls) → 1 batch request (66% reduction)
  2. Multi-County Comparison (5 counties) → 1 batch request (80% reduction)
  3. Full Field Analysis (8 endpoints) → 2 batch requests (75% reduction)
See examples/batch-optimization.json for a complete implementation.
MCP Protocol Integration
LeafEngines implements the Model Context Protocol (MCP), enabling AI agents to discover and invoke agricultural intelligence tools natively.
Claude Desktop Configuration
Add to your claude_desktop_config.json:
  "mcpServers": {
    "leafengines": {
      "transport": "streamable-http",
      "url": "https://[project].supabase.co/functions/v1/mcp-server",
      "headers": {
        "x-api-key": "ak_sandbox_your_key_here"
OpenClaw Integration
LeafEngines appears as a discoverable MCP server in OpenClaw. Agents can:
  • Discover available tools via tools/list
  • Invoke tools with typed parameters
  • Batch multiple operations in single requests
Data Integrity Guarantees
LeafEngines provides formal data integrity guarantees:
  1. Provenance Tracking - Chain of custody from source to decision
  2. Formal Uncertainty - Calibrated confidence intervals on all outputs
  3. Cryptographic Integrity - SHA-256 validation of cached data
  4. Temporal Consistency - Data staleness bounds per data type
  5. Compliance-Ready Audit Trail - SOC 2-aligned logging
Performance Benchmarks
Endpoint P50 Latency P95 Latency Cache Hit Rate
get-soil-data 12ms 45ms 94%
county-lookup 8ms 32ms 97%
territorial-water-quality 85ms 210ms 78%
carbon-credit-calculator 45ms 120ms 85%
Troubleshooting
Common Issues
  1. "Invalid API key" error
    • Verify your key starts with ak_
    • Check for typos or extra spaces
    • Ensure you're using the correct tier configuration
  2. "Network error: No response received"
    • Check your internet connection
    • Verify the API URL is correct
    • Check firewall/network restrictions
  3. Rate limit errors
    • Check your tier's rate limits
    • Implement batch operations for multiple calls
    • Add delay nodes between calls if needed
  4. "County FIPS must be 5 digits"
Debug Mode
Enable detailed logging:
# Start Node-RED with debug logging
node-red --verbose
# Or set environment variable
export DEBUG=node-red-contrib-leafengines*
node-red
Contributing
We welcome contributions! The LeafEngines Contributor Program provides API access and recognition for developers who extend the platform.
Contribution Tracks
  1. Integration Developer - Build Node-RED nodes, n8n workflows, Zapier actions
  2. Data Connector - Add new data source adapters
  3. Domain Expert - Crop-specific model validation, regional calibration
  4. Security Researcher - Responsible disclosure, penetration testing
See CONTRIBUTING.md for details.
Support
MIT License - see LICENSE file for details.
Acknowledgments
  • USDA Natural Resources Conservation Service for soil data
  • EPA for water quality monitoring data
  • Google Earth Engine for satellite imagery
  • Anthropic for Model Context Protocol specification
  • Node-RED community for the amazing low-code platform
Podcast Listeners: Visit soilsidekickpro.com/podcast for exclusive Founders Series API keys with lifetime preferential pricing.
Version: 1.0.0
Updated 8 months ago
  • leafengines
  • agriculture
  • soil
  • weather
  • crop
  • environmental
  • api
  • mcp
  • precision-agriculture
  • farm
  • iot
  • automation
  • carbon-credits
  • water-quality
