node-red-contrib-ldap-login 0.0.15
Node-RED node for Microsoft Active Directory (LDAP).
npm install node-red-contrib-ldap-login
LDAP user login check for Node-RED
node-red-contrib-ldap-login is a Node-RED node for Microsoft Active Directory. It is based on the ldapjs ldapjs client for auth (authentication) and authZ (authorization) for Microsoft Active Directory.
If you want to contribute in order to add brand new features and/or nodes, do not hesitate to join and submit your merge requests!
Getting started
  1. Install Node-RED (more):
sudo npm install -g node-red
  1. Go to your node-RED conf directory (basically ~/.node-red)
  1. There you go! You can run Node-RED with:
node-red
Documentation
Connection
Every node requires LDAP configuration/credentials to create an instance of the client configured according to the following options:
  • url {string}: Active Directory server to connect to, e.g. ldap://ad.example.com.
  • [baseDN] {string}: Optional, The root DN from which all searches will be performed, e.g. dc=example,dc=com.
  • username {string}: An account name to check.
  • password {string}: Password for the given username.
image of node credentials
login
image of node finduser
Connects to a Microsoft Active Directory and returns the user corresponding to the username/DN set in msg.payload.
Inputs
  • msg.payload {JSON Object}: the AD username and password of the user we want to get information. It also works with DN. payload.username - username in format [email protected] payload.password - password for username
  • msg.ad_attributes {JSON Object}: the attributes we want to return for users and groups. By default:
  "user": [
      "dn", "distinguishedName",
      "userPrincipalName", "sAMAccountName", "mail",
      "lockoutTime", "whenCreated", "pwdLastSet", "userAccountControl",
      "employeeID", "sn", "givenName", "initials", "cn", "displayName",
      "comment", "description", "url"
  "group": [
      "dn", "cn", "description", "distinguishedName", "objectCategory"
  • msg.tlsOptions {JSON Object}: (Optional) Additional options passed to TLS connection layer when connecting via ldaps://. (See: TLS docs for node.js).
Outputs
  • msg.payload {JSON Object}: the standard output of the command, a JSON object that contains all the information about the user.
Version: 0.0.15
Updated 6 years, 8 months ago
Rating: 3.5 2
23 in the last week
  • login-user
  • find-user
  • node
  • ad
  • active
  • directory
  • ldapjs
  • ldap
