node-red-contrib-lcd20x4-i2c 0.1.1
Driver for 20x4 HD44780 LCD Display connected via I2C PCF8574
npm install node-red-contrib-lcd20x4-i2c
This node is a driver for 20x4 HD44780 LCD Display connected via I2C PCF8574
Dependencies: SMBus, enable i2c in raspi-config
sudo apt-get install python-smbus
sudo raspi-config
    Interfacing Options>I2C>Enable
This node will accept an object msg.payload.msgs. If the object passed does not contain 4 lines, the difference is filled with blank lines.
Line data structure:
  • msg must be a string.
    • If msg is more than 20 characters the node will handle scrolling.
  • pos (position) is optional and must be a number with any value between 1-20. This value is used for offsetting text, but you can also insert spaces in to msg instead of supplying pos.
    • If pos is not supplied it will default to 1.
  • center is optional and must be a boolean value passed as a string
    • If pos and center are both set, center will override pos.
If there is an error it will be logged to Node-RED and display an error on the LCD screen.
Object format:
msg.payload = {
    msgs: [
            msg: "string",
            pos: number,
            center: "boolean"
            msg: "string",
            pos: number,
            center: "boolean"
            msg: "string",
            pos: number,
            center: "boolean"
            msg: "string",
            pos: number,
            center: "boolean"
Version: 0.1.1
Updated 7 years, 8 months ago
Rating: 4.2 5
19 in the last week
  • LCD20x4-I2C
  • 20x4
  • LCD
  • 20x4 LCD
  • PCF8574
  • PCF8574T
  • PCF8574AT
  • HD44780
