node-red-contrib-lcd 0.0.3
A Node-RED node for Raspberry Pi to write to all liquid crystal lcds.
npm install node-red-contrib-lcd
About
This module is lcd node for node red. in this node you can write a string to liquid crystal lcd.
Install via Git
Run the following code in your raspberry pi terminal
cd /home/pi/.node-red/node_modules
git clone https://github.com/erfanjahanshahlo/node-red-contrib-lcd.git
and restart your node red server or reboot your raspberry pi.
Install via npm
Install via Download
in step one download this repository and rename main folder to node-red-contrib-lcd like the schematic below and copy to /home/pi/.node-red/node_modules path in your raspberry pi and restart your node red server or reboot your raspberry pi.
-node-red-contrib-lcd
---driver
------codecs
---------init.py
---------hd44780_a00.py
---------hd44780_a02.py
------init.py
------common.py
------compat.py
------contextmanagers.py
------gpio.py
------lcd.py
---package.json
---lcd.py
---lcd.js
---lcd.html
Getting started
Here's how to send data to this node.
ROW,COL:YOUR TEXT
for clear lcd send 1,1: to the node to clear lcd. in node settings form in pins, type you must enter the pins to which the LCD is attached and the number of rows and columns shown below. Note that the pin numbering are physical and board not BCM. if not set pins and the row,cols the node not working.
RS,EN,D4,D5,D6,D7,ROW,COL
Be careful not to use any spaces in any of these commands.
Example
Example
Version: 0.0.3
Updated 7 years, 5 months ago
Rating: 4.0 1
9 in the last week
  • lcd
  • lcd
  • nodered
  • node-red-node
  • node_red
  • node-red-node-lcd
