node-red-contrib-lambda-io 0.2.3
Lambda Input/Output node for Node-RED
npm install node-red-contrib-lambda-io
Node-RED nodes to make AWS Lambda Functions on lambda
sudo npm install node-red-contrib-lambda-io
Provides 3 nodes. (input, output and test)
Input
Lambda Function input node. Create and Send Message when a Lambda Function is invoked.
Output
Lambda Function output node. Return Message to correponding a Lambda Function invocation.
Test
Lambda Funciton input/ouput test node. Test above 2 nodes on Node-RED editor.
How to create a Lambda Function
Precondition
  • Setup aws cli configuration
  • Checkout this repogitory
    git clone https://github.com/sakazuki/node-red-contrib-lambda-io.git
  • See samples
In your local environment (PC or else)
  • Create a lambda deploy package
    cd samples/
    npm install
    npm run zip ## create app.zip
  • Create a Node-RED flow
    export S3_BUCKET=XXXXXX
    export AWS_LAMBDA_FUNCTION_NAME=YYYYYYY   ## this must be the same as the lambda function name on AWS.
    npm run dev
    access the URL http://localhost:1880 , and create and deploy a flow using the lambda nodes.
    Flow files save in S3.
Create a lambda Function
  • Name must be the same as above AWS_LAMBDA_FUNCTION_NAME
  • The environment variable S3_BUCKET must be set.
  • This function must be attached with the role having S3 GetObject/PutObject.
  • Upload app.zip
Tips
  • Timeout sec maybe should be over 30 sec. (At first time, it takes a long)
Version: 0.2.3
4 in the last week
  • lambda in
  • lambda out
  • lambda test
  • lambda
  • aws
  • frontops
  • sakazuki
