node-red-contrib-labview 1.0.1
Node-RED Integration Toolkit for LabVIEW
npm install node-red-contrib-labview
Easily integrate Node-RED with LabVIEW.
Introduction
The node-red-contrib-labview node allows seamless data exchange between Node-RED and LabVIEW. By using this node, you can leverage the Node-RED dashboard as a front panel while keeping the logic within the LabVIEW block diagram. This integration simplifies the development process and enhances the capabilities of both platforms.
  • Data Exchange: Efficiently transfer data between Node-RED and LabVIEW.
  • Dashboard Integration: Use Node-RED Dashboard as the front panel for user interactions.
  • Seamless Logic Execution: Maintain your logic in the LabVIEW block diagram.
To install the node-red-contrib-labview node, use the following command:
Setting Up
  1. Add the Node: Drag the node-red-contrib-labview node from the palette to your flow.
  2. Configure the Node: Double-click the node to open the configuration panel. Specify the necessary parameters for LabVIEW communication.
  3. Deploy the Flow: Click the Deploy button to apply your changes.
Example
Here is an example of how to use the node-red-contrib-labview node:
  1. Create a Flow: Design a flow in Node-RED that includes the node-red-contrib-labview node.
  2. Connect to LabVIEW: Configure the node to connect to your LabVIEW application.
  3. Interact with the Dashboard: Use the Node-RED dashboard to send and receive data from LabVIEW.
Contributing
Contributions are welcome! Please fork the repository and submit a pull request with your improvements.
This project is licensed under the MIT License.
Version: 1.0.1
Updated 7 months ago
7 in the last week
  • labview-config
  • labview-input
  • labview-output
  • Node-RED
  • LabVIEW
