node-red-contrib-ksql 0.0.2
Node-Red module for KSQL processing with Apache Kafka
npm install node-red-contrib-ksql
Node-RED (http://nodered.org) nodes for KSQL processing of Apache Kafka streams. Written using the HTTP/REST interface provides with the Confluent KSQL Engine (https://github.com/confluentinc/ksql).
Works with Confluent Open Source and Confluent Enterprise distributions (versions 3.3 or greater).
Start node-red as normal or use the -v flag for more verbose debugging
node-red -v
Point your browser to http://localhost:1880
You should see two KSQL nodes in the output area of the pallet on the left side of the screen.
  • KSQL
  • QUERY
The main difference between the two nodes is that the KSQL node has an input so the configured KSQL statement is not executed immediately at startup like the QUERY node does. This is useful for chaining multiple KSQL commands together such that a CREATE statement can be executed before a dependant SELECT statement.
Drag either ksql node to the canvas and double click to configure the KSQL Engine URL, KSQL Command/Query (remember the trailing semicolon ';'), and node name (for display on the canvas).
Click on the pencil icon to the right of the rest-proxy selection box to configure a rest-proxy URL if one does not already exist.
Author
Hans Jespersen, https://github.com/hjespers
Feedback and Support
For more information, feedback, or support see https://github.com/hjespers/node-red-contrib-ksql/issues
Version: 0.0.2
Updated 9 years, 2 months ago
4 in the last week
  • ksql
  • ksql query
  • kafka
  • confluent
  • ksql
