node-red-contrib-kramer 0.3.6
Kramer Control For Node Red
Kramer Control for Node Red
Tested Using the VP-774A
In Development Not Ready For Use!
Required MSG Object (Will also be the same on the output unless msg.topic is response in which case the msg.payload will be the response)
msg.payload.type*
The type of command to be set, can either be "set" or "get"
msg.payload.func*
The function to be processed, look below at the supported functions, can also be sent the raw command ID found in the offical documentation
msg.payload.param*
The parameters for the function, look below for the supported parameters, can also be sent the raw command ID found in the offical documentation (* = required)
List of Supported Commands
msg.payload.func = "display mode"
- msg.payload.param = "single window"
- msg.payload.param = "picture In picture"
- msg.payload.param = "picture + picture"
- msg.payload.param = "split"
- msg.payload.param = "customized"
msg.payload.func = "input source"
- msg.payload.param = "hdmi1"
- msg.payload.param = "hdmi2"
- msg.payload.param = "hdmi3"
- msg.payload.param = "hdmi4"
- msg.payload.param = "pc1"
- msg.payload.param = "pc2"
- msg.payload.param = "vc"
- msg.payload.param = "dp"
- msg.payload.param = "sdi"
msg.payload.func = "input volume"
msg.payload.param = volume level (-20 -> 4) [dB]
msg.payload.func = "output volume"
msg.payload.param = volume level (-80 -> 20) [dB]
msg.payload.func = "mic1 volume"
msg.payload.param = volume level (-100 -> 12) [dB]
msg.payload.func = "mic2 volume"
msg.payload.func = "mic1 mix"
msg.payload.param = volume level (-100 -> 1) [dB]
msg.payload.func = "mix2 mix"
msg.payload.func = "line mix"
msg.payload.param = volume level (-100 -> 0) [dB]
