node-red-contrib-knx-ultimate 8.4.0
KNX integration for Node-RED with KNX/IP and KNX Secure, ETS import, routing, diagnostics, automation utilities, MQTT and Modbus adapters. Optional Hue Ultimate and Matter Ultimate packages connect through the KNX gateway.
npm install node-red-contrib-knx-ultimate
KNX Ultimate - Max Supervibe
Logo
The most popular KNX node for Node-RED
KNX Ultimate provides KNX/IP and KNX Secure communication, ETS project import, routing, diagnostics, virtual devices and automation utilities.
The palette contains KNX Device, KNX Utility, KNX Viewer, KNX IoT Bridge, KNX Multi Routing and KNX Router Filter.
🚨 IMPORTANT — UPGRADING FROM VERSION 7.1.4 🚨
Preferred: migrate before installing version 8
Install version 7.1.4 first, then use Upgrade to v8 from any KNX Ultimate node.
The migration is fully automated with the push of a button
If version 8 was installed directly from an older v7, restart Node-RED and open the editor: the built-in recovery bridge offers the same protected backup, package installation, conversion and Deploy. Legacy KNX AI nodes still require manual replacement or removal.
▶️ Watch the KNX Ultimate 7 → 8 migration video (Italian)
Follow the upgrade steps to keep your flows working.
Native seamless integrations
  • Philips Hue: install node-red-contrib-hue-ultimate.
  • Matter Controller and Matter Bridge: install node-red-contrib-matter-ultimate. Select your existing KNX gateway in those nodes to enable KNX integration. The package can also work without KNX Ultimate.
  • AI-driven KNX control, on-field diagnostics and unit testing for KNX installers: install node-red-contrib-cerebrum-ultimate.
NPM version Node.js version Node-RED Flow Library Docs Commit activity Last commit NPM downloads per month NPM downloads total MIT License JavaScript Style Guide Youtube
Sample Node
📘 Go to documentation (English)
📘 Vai alla documentazione (Italiano)
📘 Zur Dokumentation (Deutch)
📘 Accéder à la documentation (Français)
📘 Ir a la documentación (Español)
📘 前往文档 (中文)
CHANGELOG
Made in Italy — Designed and developed in Italy
Version: 8.4.0
Updated 1 day ago
Rating: 4.8 43
3185 in the last week
  • knxUltimate
  • knxUltimateUtility
  • knxUltimateViewer
  • knxUltimateMultiRouting
  • knxUltimateRouterFilter
  • knxUltimateIoTBridge
  • knxUltimate-config
  • node-red-contrib
  • KNX
  • knx-secure
  • ETS
  • eib
  • konnex
  • IOT
  • mqtt
  • modbus
  • home-assistant
  • building-automation
  • home-automation
  • smarthome
  • routing
