node-red-contrib-kissdb 1.0.9
A lightweight JSON-based database node for Node-RED
npm install node-red-contrib-kissdb
Node-RED npm version license
๐Ÿ’พ KISSDB โ€” Keep It Simple, Structured Database
KISSDB is a lightweight, file-backed JSON database designed for Node-RED and JavaScript environments.
It offers elegant in-memory CRUD operations, field manipulation, time series aggregation, and export utilities โ€” all through a single function node driven by msg.action.
Run the following command in your Node-RED user directory:
๐Ÿ“ฆ Database Structure
Each KISSDB database is a plain JSON object with two keys:
  "lastID": 27,
  "records": [
      "ID": 1,
      "Title": "This is the title 2",
      "Cathegory": "This is the cathegory",
      "Status": "Done",
      "DueDate": "2025-10-11",
      "Notes": "check a, b and c"
๐Ÿš€ Basic Usage
A msg with the command and the parameters is sent to the KISSDB node. KISSBD will return the full dataset updated as per command if an update is necessary. In case of a query a second node will answer to the query. The format of the answer depends to the command requested: normally it is a JSON, but can be a CSV formatted string or a simple answer (string or number).
As an example, to insert a new record into your KISSDB database, send a message to the function node with the following structure:
msg.data = {
  Title: "This is the title 2",
  Cathegory: "This is the cathegory",
  Status: "Done",
  DueDate: "2025-10-11",
  Notes: "check a, b and c",
msg.DBFile = "/data/KissDBTest.json";
msg.action = "INSERT";
๐Ÿ”— Using KISSDB with readFile and writeFile Nodes
The KISSDB node is designed to work seamlessly with Node-REDโ€™s built-in readFile and writeFile nodes to manage a lightweight JSON-based database. This setup allows you to persist data across flows and perform CRUD operations directly on a file. You just need to pay attention that the writeFile node needs to owerwrite completely the file in the filesystem: full rewrite is needed and not append. This clearly puts a limit to the dimension of the dababase: it has to reside in memory and ideally, everytime a change is made, the full database is written to disk, tush reducing the performance.
๐Ÿงญ Typical Flow Structure
[Command Node] โ†’ [readFile] โ†’ [KISSDB] โ†’ [writeFile]
Normal functioning is through the command nodes that communicate the name of the .json file containing the database in the msg.DBFile field. The read node reads the dabatase and places it in the msg.payload field completeing the dataset that the node KISSDB receives. KISSDB exports two outputs. On Output 1, the new complete database to be saved/written and on Output 2 the status message to inform about the activities performed and the results. KISSDB exports once again the name of the file in the field msg.DBFile: the write node have to overwrite at this point completely the file on the disk.
This architecture is simple and modular, this allows the user to decide if and when the database has to be written on a file or kept in memory. An example with some support nodes, manages the database in memory and flushes it to the disk ony as a "backup".
Furthermore, passing the filename in the messages everythime, while increasing slightly the programming burden, it allows the flexibilty to manage multiple files in the same flow. This allows to simulate multiple tables (one per file) instead of having one single file that becomes big, or too big.
The model is simple: all the database is read and kept in memory (under msg.payload) and completely written back to the file every time. This is clearly possible with small databases:KISSBD is not suited for big data (or growing over time data).
An alternative approach is possible, where the DB is stored in a flow variable and a dirty wariable is set; then, on scheduled (every minute) timeframe, the database is also stored in the filesystem with a writeFile node. This reduces the number of accesses and write operation to disk, but it complicats slightly the management of multiple tables (multiple JSON files).
๐Ÿ“š Available Commands
msg.action Description Required Parameters
CREATE Initialize an empty database โ€”
INSERT Add a new record data
UPDATE Update a record by ID ID, update
DELETE Delete a record by ID ID
FIND Search records by query query
COUNT Count records containing a given field count.field
COUNTBYGROUP Count records grouped by a field group
RENAME Rename a field rename.from, rename.to
REMOVE Remove a field remove.field
ADD Add a field with a fixed value add.field, add.value
REORDERFIELDS Reorder fields in each record order
KEEPONLYFIELDS Keep only selected fields (auto-keeps ID) fields
MERGEFIELDS Merge multiple fields into one merge.fields, merge.newField
SPLITFIELD Split a field into multiple parts split.field, split.format, split.into
BEAUTIFYFIELD Transform field values (e.g. trim, capitalize) beautify.field, beautify.operation, beautify.options
CONVERTTODATE Create a new field with Date object field
GETUNIQUEVALUES Return unique values of a field field
SORT Sort records by field sort.field, sort.order
FILTERBYDATERANGE Filter records within a date range filter.field, filter.from, filter.to
SUMBYDATERANGE Sum values in a date range sum.dateField, sum.from, sum.to, sum.valueField
AVGBYDATERANGE Average values in a date range avg.dateField, avg.from, avg.to, avg.valueField
MAXBYDATERANGE Max value in a date range max.dateField, max.from, max.to, max.valueField
MINBYDATERANGE Min value in a date range min.dateField, min.from, min.to, min.valueField
COUNTBYDATERANGE Count records in a date range count.dateField, count.from, count.to
TIMESERIESBYDATERANGE Time series aggregation timeseries.dateField, timeseries.from, timeseries.to, timeseries.valueField, timeseries.groupBy, timeseries.method
TIMESERIESCSVBYDATERANGE Export time series as CSV Same as above
EXPORTFIELDS Export exactly two fields from all records fields (array of 2)
EXPORTJSONBYDATERANGE Export exactly two fields in JSON within a date range export.fields (array of 2), export.dateField, export.from, export.to
EXPORTCSV Export exactly two fields to CSV fields (array of 2)
EXPORTCSVBYDATERANGE Export exactly two fields to CSV in a date range export.fields (array of 2), export.dateField, export.from, export.to
VALIDATE Check for missing required fields requiredFields (optional, defaults to ["ID","titolo","stato"])
HELP List all available commands โ€”
๐Ÿ› ๏ธ Command: CREATE
Initializes a new, empty database with no records.
This is typically used at the beginning of a flow or to reset the database file.
๐Ÿ“ฆ Message Format
msg.action = "CREATE";
โœ… Tip: this command has no checks: it overwrites completely the database and initialize it to zero. Be careful using it: once created the file on the filesystem the first time, my recommendation is to detatch (or even remove) the node "CREATE" from the flow in order to avoid mistakes and destroy everything.
โž• Command: INSERT
Adds a new record to the database.
The ID is automatically assigned, and a createdAt timestamp is added.
๐Ÿ“ฆ Message Format
msg.data = {
  Title: "This is the title",
  Status: "Done",
โœ๏ธ Command: UPDATE
Updates an existing record by its ID.
You can modify one or more fields, and an updatedAt timestamp will be added automatically.
๐Ÿ“ฆ Message Format
msg.ID = 1;
msg.update = {
  Status: "In Progress",
  Notes: "Updated notes with new checklist",
msg.action = "UPDATE";
๐Ÿ—‘๏ธ Command: DELETE
Removes a record from the database by its unique ID.
This operation is permanent โ€” once deleted, the record cannot be recovered.
๐Ÿ“ฆ Message Format
msg.ID = 1;
msg.action = "DELETE";
๐Ÿ” Command: FIND
Searches the database for records that match a given query.
Matching is case-insensitive and partial โ€” useful for filtering by keywords or status. Multiple conditions can be used in the query part: KISSDB interprets them as logical AND. The querying capability of KISSBD is clearly not the one of a normal database but it allows for simple queries:
๐Ÿ“ฆ Message Format
msg.query = {
  Status: "done",
  Cathegory: "cathegory",
msg.action = "FIND";
Rusult: FIND retuns an array of records:
    Status: "Done",
    createdAt: "2025-10-25T20:00:00.000Z",
๐Ÿ”ข Command: COUNT
Returns the total number of records currently stored in the database that contains a certain field. If you want to count the total number of records just count ID field.
Useful for monitoring database size or validating insert/delete operations.
๐Ÿ“ฆ Message Format
msg.count = { field: "ID" };
msg.action = "COUNT";
๐Ÿงพ Behavior
  • Reads the full database from the specified file.
  • Scans all records and checks if the given field exists.
  • Returns the total number of records containing that field in msg.payload.
  • If you want the total number of records in the database, use field: "ID".
msg.payload = 7;
๐Ÿ“Š Command: COUNTBYGROUP
Counts how many records share the same value in a specified field.
Useful for generating summaries, dashboards, or visualizations of categorical data.
๐Ÿงฉ Parameters
  • msg.group: The name of the field to group by (e.g. "Status", "Category").
  • msg.DBFile: Path to the JSON file where the database is stored.
  • msg.action: Must be "COUNTBYGROUP" to trigger the operation.
๐Ÿ“ฆ Example
msg.group = "Status";
msg.action = "COUNTBYGROUP";
๐Ÿงพ Behavior
  • Scans all records and groups them by the value of msg.group.
  • Returns an object in msg.payload where each key is a unique field value and each value is the count.
  "Done": 5,
  "In Progress": 3,
  "Pending": 2
โœ๏ธ Command: RENAME
Renames a field across all records in the database.
Useful for correcting typos, updating schema, or aligning field names with external systems.
๐Ÿ“ฆ Message Format
msg.action = "RENAME";
msg.rename = {
  to: "ExpectedDateNew",
๐Ÿงน Command: REMOVE
Deletes a specific field from all records in the database.
Useful for cleaning up unused fields or simplifying the data structure.
๐Ÿ“ฆ Message Format
msg.action = "REMOVE";
msg.remove = {
  field: "ExpectedDateNew",
โž• Command: ADD
Adds a new field to all records in the database.
If the field already exists in a record, it will be left unchanged.
Useful for initializing a new column or tagging all records with a default value.
๐Ÿ“ฆ Message Format
msg.add = { field: "Author", value: "ADDED BY NODERED" };
msg.action = "ADD";
๐Ÿ”€ Command: REORDERFIELDS
Reorders the fields in each record according to a specified sequence.
Useful for customizing column order before exporting or displaying data.
๐Ÿงฉ Parameters
  • msg.order: An array of field names defining the desired order (e.g. ["Title", "DueDate", "Status"]).
  • msg.action: Must be "REORDERFIELDS" to trigger the operation.
๐Ÿ“ฆ Example
msg.order = ["Title", "DueDate", "Status"];
msg.action = "REORDERFIELDS";
๐Ÿงพ Behavior
  • Reorders the fields in each record to match the sequence in msg.order.
  • Fields not listed in msg.order will be omitted.
  • The result is returned in msg.payload as an array of reordered records.
    Title: "Prepare report",
    Status: "Done",
    Title: "Submit budget",
    DueDate: "2025-10-25",
    Status: "Pending",
โœ… Tip: Use REORDERFIELDS before EXPORTCSV to control column layout in the final CSV output.
๐Ÿงผ Command: KEEPONLYFIELDS
Keeps only the specified fields in each record and removes all others.
This is useful for slimming down the dataset before exporting or visualizing.
๐Ÿ“ฆ Message Format
msg.fields = ["Title", "DueDate", "Status"];
msg.action = "KEEPONLYFIELDS";
๐Ÿงพ Behavior
  • Only the fields listed in msg.fields will be kept.
  • The "ID" field is always preserved automatically, even if not listed.
  • All other fields will be removed from each record.
๐Ÿ”— Command: MERGEFIELDS
Combines multiple fields into a single new field across all records.
Useful for creating summary fields, labels, or concatenated strings for export or display.
๐Ÿ“ฆ Message Format
msg.action = "MERGEFIELDS";
msg.merge = {
  fields: ["Title", "Category"],
  newField: "CompleteTile",
  separator: " - ",
๐Ÿงฉ Parameters
  • merge.fields: An array of field names to merge (e.g. "Title", "Status").
  • merge.newField: The name of the new field that will contain the merged result.
  • separator: Optional string to insert between merged values (default is a single space " ").
  • msg.action: Must be "MERGEFIELDS" to trigger the operation.
๐Ÿงพ Behavior
  • The values of the listed fields are concatenated using the specified separator.
  • If a field is missing in a record, it is skipped in that recordโ€™s merge.
  • The new field is added to each record with the combined value.
โœ‚๏ธ Command: SPLITFIELD
Splits the value of a single field into multiple new fields based on a defined format.
Useful for breaking apart compound strings like dates, names, or tags.
๐Ÿ“ฆ Message Format
msg.split = {
  field: "DueDate",
  format: "YYYY-MM-DD",
  into: ["Year", "Month", "Day"],
msg.action = "SPLITFIELD";
๐Ÿงฉ Parameters
  • split.field: The name of the field to split (e.g. "DueDate").
  • split.format: The format of the original value (e.g. "YYYY-MM-DD", "Name - Status").
  • split.into: An array of new field names to hold the split parts.
  • msg.action: Must be "SPLITFIELD" to trigger the operation.
๐Ÿงพ Behavior
  • The field value is split using the format as a guide.
  • The split parts are assigned to the new fields listed in split.into.
  • If the format doesn't match or the value is missing, the new fields will be empty.
  • Original field is preserved unless removed with a REMOVE command.
  "Year": "2025",
  "Month": "10",
  "Day": "11"
๐ŸŽจ Command: BEAUTIFYFIELD
Applies a transformation to a specific field across all records.
Useful for cleaning up text, formatting values, or standardizing data before export or filtering.
๐Ÿ“ฆ Message Format
msg.beautify = {
  field: "Title",
  operation: "capitalize",
  options: {},
msg.action = "BEAUTIFYFIELD";
๐Ÿงฉ Parameters
  • beautify.field: The name of the field to transform (e.g. "Title", "Status").
  • beautify.operation: The type of transformation to apply. Supported operations include:
    • "trim": Removes leading/trailing whitespace.
    • "lowercase": Converts text to lowercase.
    • "uppercase": Converts text to uppercase.
    • "capitalize": Capitalizes the first letter of each word.
    • "replace": Replaces substrings (requires options.from and options.to).
  • beautify.options: Optional parameters for operations like replace.
  • msg.action: Must be "BEAUTIFYFIELD" to trigger the transformation.
๐Ÿงพ Behavior
  • The specified operation is applied to the field in every record.
  • If the field is missing in a record, it is skipped.
  • Original values are overwritten with the transformed result.
Exemples:
round
msg.beautify = {
  field: "Umidity",
  operation: "round",
multiply
msg.beautify = {
  field: "Price",
  operation: "multiply",
  options: { factor: 1.2 },
abs (absolute value)
msg.beautify = {
  field: "Umidity",
  operation: "abs",
lowercase
msg.beautify = {
  field: "Status",
  operation: "lowercase",
uppercase
msg.beautify = {
  field: "Status",
  operation: "uppercase",
capitalize
msg.beautify = {
  field: "Status",
trim
msg.beautify = {
  field: "Notes",
  operation: "trim",
replace
msg.beautify = {
  field: "Status",
  operation: "replace",
  options: { from: "TO DO", to: "To Do!" },
dateformat (example 1)
msg.beautify = {
  field: "DueDate",
  operation: "dateformat",
  options: { format: "DD/MM/YYYY" },
dateformat (example 2)
msg.beautify = {
  field: "DueDate",
  options: { format: "YYYY-MM-DD" },
๐Ÿ“… Command: CONVERTTODATE
Creates a new field containing a JavaScript Date object based on an existing string field.
Useful for enabling date-based filtering, sorting, and time series operations.
๐Ÿ“ฆ Message Format
msg.field = "DueDate";
msg.action = "CONVERTTODATE";
๐Ÿงฉ Parameters
  • field: The name of the field containing a date string (e.g. "DueDate").
  • msg.action: Must be "CONVERTTODATE" to trigger the conversion.
๐Ÿงพ Behavior
  • The specified field is parsed into a JavaScript Date object.
  • A new field named field + "Obj" is added to each record (e.g. "DueDateObj").
  • If the original value is invalid or missing, the new field will be null.
๐Ÿงฎ Command: GETUNIQUEVALUES
Retrieves all unique values found in a specified field across the database.
Useful for building dropdowns, filters, or understanding the range of categories in your data.
๐Ÿ“ฆ Message Format
msg.action = "GETUNIQUEVALUES";
msg.field = "Status";
๐Ÿงฉ Parameters
  • unique.field: The name of the field to scan for unique values (e.g. "Status", "Category").
  • msg.action: Must be "GETUNIQUEVALUES" to trigger the operation.
๐Ÿงพ Behavior
  • Scans all records and collects distinct values from the specified field.
  • Returns an array of unique values in msg.payload.
  • If the field is missing in all records, the result will be an empty array.
["Done", "In Progress", "Pending"]
๐Ÿ”ƒ Command: SORT
This command allows for massive interventions in the .json file. the aim is to organize the records based on some criteria. This simplifies readibility if you want to access directly the .json file in the filesystem for any reason, This command sorts all records in the database by a specified field.
Supports both ascending (asc) and descending (desc) order.
Works with numeric, string, and date fields.
๐Ÿ“ฆ Message Format
msg.sort = {
  field: "DueDate",
  order: "asc",
msg.action = "SORT";
๐Ÿงพ Behavior
  • Records missing the sort field are ignored during comparison.
  • Sorting is case-insensitive for strings.
  • Numeric and date fields are sorted by value.
โœ… Tip: Use SORT before exporting or visualizing data to ensure consistent order.
๐Ÿ“† Command: FILTERBYDATERANGE
Filters records based on whether a date field falls within a specified start and end range.
Useful for extracting time-based subsets of your data, such as upcoming tasks or historical logs.
๐Ÿ“ฆ Message Format
msg.action = "FILTERBYDATERANGE";
msg.filter = {
  field: "DueDateObj",
  to: "2025-10-31",
๐Ÿงฉ Parameters
  • filter.field: The name of the field containing a JavaScript Date object (e.g. "DueDateObj").
  • filter.from: Start of the date range (inclusive), in ISO format (YYYY-MM-DD).
  • filter.to: End of the date range (inclusive), in ISO format (YYYY-MM-DD).
  • msg.action: Must be "FILTERBYDATERANGE" to trigger the operation.
๐Ÿงพ Behavior
  • Only records where the specified field is a valid Date and falls within the range are kept.
  • Records with missing or invalid date values are excluded.
  • The result is returned in msg.payload as an array of matching records.
    "ID": 1,
    "Title": "Prepare report",
    "DueDateObj": "2025-10-11T00:00:00.000Z"
    "ID": 2,
    "Title": "Submit budget",
    "DueDate": "2025-10-25",
    "DueDateObj": "2025-10-25T00:00:00.000Z"
โž• Command: SUMBYDATERANGE
Calculates the total sum of a numeric field across all records within a specified date range.
Useful for aggregating values like expenses, hours, or quantities over time.
๐Ÿงฉ Parameters
  • msg.field: The name of the numeric field to sum (e.g. "Amount", "Hours").
  • msg.datefield: The name of the date field to filter by (e.g. "DueDate").
  • msg.start: Start date in YYYY-MM-DD format (inclusive).
  • msg.end: End date in YYYY-MM-DD format (inclusive).
  • msg.action: Must be "SUMBYDATERANGE" to trigger the operation.
๐Ÿ“ฆ Example
msg.action = "SUMBYDATERANGE";
msg.sum = {
  dateField: "DueDate",
  to: "2025-12-31",
  valueField: "Amount",
๐Ÿงพ Behavior
  • Filters records where msg.datefield falls between msg.start and msg.end (inclusive).
  • Sums the values of msg.field across all matching records.
  • Returns the result in msg.payload as a number.
  • If no records match, the result will be 0.
msg.payload = 1250.75;
โœ… Tip: Use SUMBYDATERANGE to generate monthly totals, budget rollups, or time-based summaries.
๐Ÿ“ˆ Command: AVGBYDATERANGE
Calculates the average value of a numeric field across all records within a specified date range.
Useful for analyzing trends, performance metrics, or normalized totals over time.
๐Ÿงฉ Parameters
  • msg.field: The name of the numeric field to average (e.g. "Amount", "Hours").
  • msg.action: Must be "AVGBYDATERANGE" to trigger the operation.
๐Ÿ“ฆ Example
msg.action = "AVGBYDATERANGE";
msg.avg = {
  to: "2025-10-31",
  valueField: "Hours",
๐Ÿงพ Behavior
  • Averages the values of msg.field across all matching records.
msg.payload = 7.25;
โœ… Tip: Use AVGBYDATERANGE to monitor weekly workloads, average expenses, or normalized KPIs.
๐Ÿ“Š Command: MAXBYDATERANGE
Finds the maximum value of a numeric field across all records within a specified date range.
Useful for identifying peak values like highest expense, longest duration, or max output over time.
๐Ÿงฉ Parameters
  • msg.field: The name of the numeric field to evaluate (e.g. "Amount", "Hours").
  • msg.action: Must be "MAXBYDATERANGE" to trigger the operation.
๐Ÿ“ฆ Example
msg.action = "MAXBYDATERANGE";
msg.max = {
  to: "2025-10-31",
๐Ÿงพ Behavior
  • Finds the highest value of msg.field across all matching records.
msg.payload = 980.0;
โœ… Tip: Use MAXBYDATERANGE to detect peak usage, highest cost, or longest task duration within a time window.
๐Ÿ“‰ Command: MINBYDATERANGE
Finds the minimum value of a numeric field across all records within a specified date range.
Useful for identifying lowest values like minimum expense, shortest duration, or least output over time.
๐Ÿงฉ Parameters
  • msg.action: Must be "MINBYDATERANGE" to trigger the operation.
๐Ÿ“ฆ Example
msg.action = "MINBYDATERANGE";
msg.min = {
  to: "2025-10-31",
๐Ÿงพ Behavior
  • Finds the lowest value of msg.field across all matching records.
msg.payload = 1.5
โœ… Tip: Use MINBYDATERANGE to detect minimum effort, lowest cost, or shortest task duration within a time window.
๐Ÿ”ข Command: COUNTBYDATERANGE
Counts how many records fall within a specified date range.
Useful for tracking activity volume, task frequency, or event density over time.
๐Ÿงฉ Parameters
  • msg.action: Must be "COUNTBYDATERANGE" to trigger the operation.
๐Ÿ“ฆ Example
msg.action = "COUNTBYDATERANGE";
msg.count = {
  to: "2025-10-31",
๐Ÿงพ Behavior
  • Counts how many records match the criteria.
msg.payload = 12;
โœ… Tip: Use COUNTBYDATERANGE to measure task volume, submission frequency, or event density across time windows.
๐Ÿ“ˆ Command: TIMESERIESBYDATERANGE
Generates a time series count of records grouped by day, week, or month within a specified date range.
Useful for visualizing trends, activity spikes, or historical distributions.
๐Ÿ“ฆ Message Format
msg.timeseries = {
  to: "2025-10-31",
  interval: "day",
msg.action = "TIMESERIESBYDATERANGE";
๐Ÿงฉ Parameters
  • timeseries.field: The name of the field containing a JavaScript Date object (e.g. "DueDateObj").
  • timeseries.from: Start of the date range (inclusive), in ISO format (YYYY-MM-DD).
  • timeseries.to: End of the date range (inclusive), in ISO format (YYYY-MM-DD).
  • timeseries.interval: Granularity of grouping โ€” "day", "week", or "month".
  • msg.action: Must be "TIMESERIESBYDATERANGE" to trigger the operation.
๐Ÿงพ Behavior
  • Records are filtered by the specified date range.
  • Matching records are grouped by the selected interval.
  • Returns an object in msg.payload with keys as time buckets and values as counts.
  "2025-10-01": 2,
  "2025-10-11": 1,
  "2025-10-25": 3
๐Ÿ“† Command: TIMESERIESCSVBYDATERANGE
Generates a time series CSV file by aggregating values of a numeric field across a date range.
Each row represents a single day and its corresponding total.
Useful for plotting trends, generating reports, or feeding external dashboards.
๐Ÿงฉ Parameters
  • msg.field: The name of the numeric field to aggregate (e.g. "Amount", "Hours").
  • msg.datefield: The name of the date field to group by (e.g. "DueDate").
  • msg.action: Must be "TIMESERIESCSVBYDATERANGE" to trigger the operation.
๐Ÿ“ฆ Example
msg.field = "Amount";
msg.datefield = "DueDate";
msg.start = "2025-10-01";
msg.end = "2025-10-07";
msg.action = "TIMESERIESCSVBYDATERANGE";
๐Ÿงพ Behavior
  • Aggregates the values of msg.field for each day in the range.
  • Returns a CSV-formatted string in msg.payload, with two columns: Date and Total.
  • If no records match a given day, that day will still appear with a total of 0.
Date,Total
2025-10-01,250
2025-10-02,0
2025-10-03,180
2025-10-04,90
2025-10-05,0
2025-10-06,60
2025-10-07,0
โœ… Tip: Use TIMESERIESCSVBYDATERANGE to feed charting tools, generate daily reports, or visualize trends.
๐Ÿ“ค Command: EXPORTFIELDS
Exports exactly two fields from all records into a simplified array.
Useful for extracting paired columns for reporting, filtering, or external processing.
๐Ÿงฉ Parameters
  • msg.fields: An array with exactly two field names to export (e.g. ["Title", "Status"]).
  • msg.action: Must be "EXPORTFIELDS" to trigger the operation.
๐Ÿ“ฆ Example
msg.fields = ["Title", "Status"];
msg.action = "EXPORTFIELDS";
๐Ÿงพ Behavior
  • Extracts only the fields listed in msg.fields from each record.
  • Returns the result in msg.payload as an array of simplified objects.
  • If a field is missing in a record, it will be omitted from that object.
    "Status": "Done"
    "Status": "Pending"
โœ… Tip: Use EXPORTFIELDS before EXPORTCSV to limit which columns appear in the final CSV
๐Ÿ“ค Command: EXPORTJSONBYDATERANGE
Exports exactly two fields from all records within a specified date range into a JSON array.
Useful for archiving or transferring filtered datasets with only the required columns.
๐Ÿ“ฆ Message Format
msg.action = "EXPORTJSONBYDATERANGE";
msg.export = {
  fields: ["ID", "Title"], // exactly two fields
  to: "2025-10-31",
๐Ÿงพ Behavior
  • Filters records where msg.datefield falls between msg.start and msg.end.
  • Returns only the two requested fields in msg.payload as an array of objects.
  • Records missing either field are skipped.
  { "ID": 5, "Title": "Prepare report" },
  { "ID": 7, "Title": "Submit budget" }
โœ… Tip: Use EXPORTJSONBYDATERANGE to archive filtered records, share datasets, or feed external APIs.
๐Ÿ“ค Command: EXPORTCSV
Generates a CSV string from the database using a custom separator and optional field selection.
Useful for exporting structured data to spreadsheets or external systems.
๐Ÿงฉ Parameters
  • export.datafields: (Optional) An array of field names to include in the CSV output (e.g. ["Title", "DueDate"]).
  • export.separator: (Optional) A string used to separate columns in the CSV (e.g. ",", ";", "|"). Defaults to comma if not specified.
  • msg.action: Must be "EXPORTCSV" to trigger the operation.
๐Ÿ“ฆ Example
msg.export = {
  datafields: ["Title", "DueDate"],
  separator: ";",
msg.action = "EXPORTCSV";
๐Ÿงพ Behavior
  • Generates a CSV string using the chosen separator.
  • If export.datafields is provided, only those fields are included as columns.
  • If export.datafields is omitted, all fields from the first record are used.
  • The result is returned in msg.payload as a plain-text CSV.
  • If the database is empty, the result will be an empty string.
Title;DueDate
Prepare report;2025-10-11
Submit budget;2025-10-25
โœ… Tip: Use SORT or FILTERBYDATERANGE before exporting if you want to refine the dataset, but note that EXPORTCSV always reads directly from the full database file.
๐Ÿ“ค Command: EXPORTCSVBYDATERANGE
Exports exactly two fields from all records within a specified date range into a CSV string.
Useful for generating filtered CSV reports for Excel, Google Sheets, or BI dashboards.
๐Ÿ“ฆ Message Format
msg.action = "EXPORTCSVBYDATERANGE";
msg.export = {
  fields: ["ID", "Status"], // exactly two fields
  to: "2025-10-31",
๐Ÿงพ Behavior
  • Converts the matching records into CSV format, including headers.
  • Returns the result in msg.payload as a CSV-formatted string.
  • If no records match, the result will be a CSV string with only headers.
ID,Status
5,Done
7,Pending
โœ… Command: VALIDATE
Checks the integrity of the database by verifying that required fields exist in each record.
Useful for debugging and ensuring consistency.
๐Ÿ“ฆ Message Format
msg.action = "VALIDATE";
msg.requiredFields = ["ID", "Title", "Status"];
๐Ÿงพ Behavior
  • For each record, checks whether all required fields are present.
  • Returns an array of objects in msg.payload, each containing:
    • ID: the record ID
    • missing: an array of missing field names
  • If all records are valid, the result is an empty array.
๐Ÿ“Š Example Output
  { "ID": 3, "missing": ["Status"] },
  { "ID": 7, "missing": ["Title"] }
in case of success this is the ouput:
  "payload": [],
  "info": "Command VALIDATE: 0 incomplete records"
โœ… Tip: Use VALIDATE after manual edits or migrations to ensure the database remains consistent and error-free.
Version: 1.0.9
Updated 1 year ago
104 in the last week
  • kissdb
  • database
  • json
  • kissdb
  • lightweight
  • structured
  • file-backed
