node-red-contrib-kintone 1.0.3
Node-RED nodes for kintone
npm install node-red-contrib-kintone
npm version
Node-RED node that operates kintone records using kintone REST API.
Support operations are as following:
  • read
  • create
  • update
See http://developer.cybozu.io/ for REST API specs.
Manually install:
  1. In the directory containing the node’s package.json file, run npm link
    $ git clone https://github.com/chick-p/node-red-contrib-kintone.git
    $ cd node-red-contrib-kintone
    $ npm link
  2. Restart Node-RED.
Using Node Package Manager:
  1. Change to your Node-RED user directory and install this package.
    $ cd ~/.node-red
    $ npm install node-red-contrib-kintone
Getting Started
This example that output getting records from kintone.
  1. Add a kintone node, edit [Config] and fill properties of your kintone environment.
    width=300
  2. Fill request setting.
  3. Connect to [inject] and [debug] nodes.
  4. Delopy and Execute. You can get as following JSON format data.
      "records": [
          "$id":{"type":"__ID__","value":"1"},
          "$revision": { "type": "__REVISION__", "value": "1" },
          "created at": { "type": "CREATED_TIME", "value": "2019-02-04T00:47:00Z" },
          "updated at": { "type": "UPDATED_TIME", "value": "2019-02-04T00:47:00Z" },
          "name": { "type": "SINGLE_LINE_TEXT", "value": "Taro" }
          "$id":{"type":"__ID__","value":"2"},
          "name": { "type": "SINGLE_LINE_TEXT", "value": "Hanako" }
      "totalCount": "2"
Licence
The MIT License.
Copyright (c) 2019 chick-p
Version: 1.0.3
Updated 7 years, 4 months ago
6 in the last week
  • kintone
  • kintone-config
  • kintone
