node-red-contrib-kakao-bizmessage-toast 1.0.3
Node-RED node for kakao-bizmessage-toast
npm install node-red-contrib-kakao-bizmessage-toast
To install the stable version use the Menu - Manage palette - Install option and search for node-red-contrib-kakao-bizmessage-toast, or run the following command in your Node-RED user directory, typically ~/.node-red
Wrapper kakao-bizmessage-toast
기능
카카오톡 비즈메세지(알림톡/친구톡/상담톡) 전송
파라미터
  • api : sendMessages, sendMessages, sendSameRawMessagesToMultipleUsers
  • templateCode
  • recipientList
message sample
msg = {};
msg.api = 'sendRawMessages';
msg.recipientList =  [{
  recipientNo: '01012345678',
  content: '누구누구님 안녕하세요?',
Sample flow
[{"id":"db8fe58d.b0d448","type":"kakao-bizmessage-toast","z":"b17d7b00.cf5848","name":"test","api":"sendRawMessages","templateCode":"213123","creds":"db7a1f23.b774c","x":490,"y":120,"wires":[["30b54949.46df56"]]},{"id":"8d014466.5537d8","type":"inject","z":"b17d7b00.cf5848","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":140,"y":120,"wires":[["198f8d3c.94b1e3"]]},{"id":"198f8d3c.94b1e3","type":"function","z":"b17d7b00.cf5848","name":"","func":"msg = {};\nmsg.recipientList =  [{\n  recipientNo: '01012345678',\n  content: '현호님 카플랫 이용은 어떠셨나요?',\n}];\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":300,"y":120,"wires":[["db8fe58d.b0d448"]]},{"id":"30b54949.46df56","type":"debug","z":"b17d7b00.cf5848","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":670,"y":120,"wires":[]},{"id":"db7a1f23.b774c","type":"toastkey","z":"","name":"test"}]
Version: 1.0.3
Updated 4 years, 7 months ago
Rating: 5.0 2
10 in the last week
  • kakao-bizmessage-toast
  • toastkey
  • node-red-contrib-contribgen
  • kakao
  • kakaotalk
  • 알림톡
  • 카카오톡
  • 비즈톡
