node-red-contrib-kafkajs-no-crash 1.0.0
Crash-proof Kafka nodes for Node-RED built on KafkaJS: auto-reconnect, clear errors, and a disk-backed offline queue that stores messages while Kafka is unreachable and replays them in order when the connection comes back.
npm install node-red-contrib-kafkajs-no-crash
CI npm License: MIT
Apache Kafka nodes for Node-RED, built on KafkaJS 2.2.4, that never crash Node-RED. Problems such as an unreachable broker, a missing password or a bad certificate show up as a node status, one clear log line and a message for your catch node. The nodes keep reconnecting on their own, and they do not give up. While Kafka cannot be reached, the producer stores messages in an offline queue on disk and sends them in their original order once the connection is back. The palette has a producer, a consumer, an admin node and a shared broker configuration, and it supports SASL (PLAIN, SCRAM-SHA-256/512), TLS and mutual TLS.
Contents
Why this palette?
Node-RED runs all flows in one process. When a node leaves an asynchronous error unhandled, Node-RED does not just log it: the process exits, and every other flow on that instance stops with it. We tested node-red-contrib-kafkajs version 0.0.7, which is what the palette manager installs, with Node.js 22, Node-RED 4.1 and Kafka 3.9. Anything that made the producer's first connection fail ended the Node-RED process with exit code 1. That included a stopped broker, a typo in the host name, an empty or wrong SASL password, and TLS against a plain listener. A catch node could not prevent it. The crash even happened after a redeploy had deleted the producer node, because the old Kafka client kept retrying in the background. Later, unreleased changes in that project's git repository avoid this particular crash. With those changes, though, the node stops for good after a failed connection and silently drops every message after that.
This palette is a clean-room rewrite: no code was copied. Its node types have different names (kafkajs-nc-*), so both palettes can be installed side by side while you migrate.
Situation node-red-contrib-kafkajs 0.0.7 (as tested) This palette
Kafka unreachable when the flow starts Node-RED exits Yellow status with the reason, retries forever, messages are queued
SASL selected but the password is empty or wrong Node-RED exits Red config error (empty: no connection attempts until fixed) or auth failed · retry 60s (wrong: slow retries); messages are queued
Redeploy while Kafka is down Node-RED exits, even if the node was deleted Old clients are shut down within 10 s; nothing keeps retrying in the background
Kafka restarted while producing Messages sent during the outage are lost (200 of 448 in a test with a 2-minute outage) Stored on disk and sent in order after the reconnect
Kafka comes back after a failed first connection Crash (0.0.7), or no reconnect until the next deploy (git version) Reconnects automatically
A tombstone (record without value) or a header without value is consumed The consumer stops and fails at the same offset after every restart msg.payload = null / header value null
Payload 0, "", a number or an object Dropped silently or rejected Sent as "0", "", text or JSON
Something goes wrong Generic "Kafka Producer Error", the cause is lost The cause is shown in the status, the log and msg.error
kafkajs logging The log level setting is ignored; raw JSON on stdout Sent to the Node-RED log at the level you choose, with repeated lines suppressed
The design notes behind these decisions are in docs/ARCHITECTURE.md.
  • Never crashes Node-RED. Every error is handled inside the nodes. A ref-counted safety net also catches stray kafkajs promise rejections as a second line of defence. Close handlers always finish within 10 seconds.
  • Reconnects forever. Failed connections are retried with exponential backoff and jitter. Authentication, TLS and configuration errors are retried slowly (every 60 s by default), because they rarely fix themselves. A broker configuration that is invalid from the start (for example a missing password) is reported once and waits for a fix.
  • Clear errors. The status text names the problem (ECONNREFUSED broker:9092 · retry 8s, auth failed, TLS: self-signed cert). The first failure of an outage is logged once, not hundreds of times. Messages that cannot be sent reach catch nodes together with the original msg.
  • Producer with store-and-forward. While Kafka is unreachable, messages go to a disk queue, or to a memory queue, or you can turn the queue off. They are sent in their original order after the reconnect, with at-least-once delivery. Size limits, an overflow policy, expiry and a dead-letter file keep the queue under control.
  • Any payload. Strings, Buffers, objects (as JSON), numbers, booleans and dates are accepted; null sends a tombstone. You can set keys, headers (static, or taken from msg.headers), partitions and timestamps, and send batches with msg.messages. Every input gets a delivery report: sent with the partition and offset, or queued.
  • Delivery options: acks all/leader/none, gzip/snappy/lz4 compression, and the default or legacy partitioner. Kafka errors that clear up by themselves (a partition leader moving, a request timeout) are retried by resending the whole request, so a message is written at least once and never dropped silently.
  • Consumer. Output as a UTF-8 string, a Buffer or parsed JSON. Subscribe to a list of topics or to a regular expression. The group ID stays the same across restarts. Commit automatically or manually. Control messages pause, resume, stop, start, restart, seek and commit steer the consumer.
  • Admin node with 15 actions: topics, partitions, offsets, consumer groups, the cluster and configs.
  • Security: SASL PLAIN, SCRAM-SHA-256 and SCRAM-SHA-512, plus TLS through Node-RED's standard TLS configuration node (private CA, client certificates, self-signed certificates). Credentials are stored encrypted, and every field accepts ${ENV_VAR}.
  • No ghost clients. Every connection attempt uses a fresh kafkajs client. A late connect after a redeploy is shut down instead of living on as a hidden consumer group member.
  • Pure JavaScript dependencies (kafkajs, snappyjs, lz4js), so nothing has to be compiled on a Raspberry Pi or in Alpine containers.
Requirements & compatibility
Node.js 18.5 or newer. CI runs Node.js 18, 20, 22 and 24.
Node-RED 3.1 or newer. Tested with 3.1, 4.1 and 5.0 (Node-RED 5 itself needs Node.js 22.9 or newer). Node-RED 3.0 is not supported: it gives the nodes inside a subflow a new id on every start, which would change their default queue directory and consumer group each time.
Kafka Any broker KafkaJS 2.2.4 can talk to (KafkaJS states Kafka 0.10+). The end-to-end tests run against Apache Kafka 3.9.1 in KRaft mode. Kafka-compatible services such as Redpanda, Confluent Cloud, Amazon MSK or the Azure Event Hubs Kafka endpoint can work too; see the recipes.
Authentication None, SASL/PLAIN, SASL/SCRAM-SHA-256, SASL/SCRAM-SHA-512, mutual TLS. Not supported: OAUTHBEARER, AWS IAM (MSK IAM authentication), Kerberos/GSSAPI.
Compression gzip, snappy and lz4, for both producing and consuming. zstd is not supported.
Not included Transactions / exactly-once, the idempotent producer (see Retries), schema registry (Avro/Protobuf: consume as a Buffer and decode in a function node), IPv6 literal broker addresses (use a host name).
Node-RED palette manager
In the Node-RED editor open Menu → Manage palette → Install, search for node-red-contrib-kafkajs-no-crash and click install. The nodes appear in the kafka category of the palette.
npm
Run this in your Node-RED user directory (usually ~/.node-red), then restart Node-RED:
Docker (official nodered/node-red image)
Either install the palette into a running container (the user directory of the image is /data):
docker exec -it mynodered bash -c "cd /data && npm install node-red-contrib-kafkajs-no-crash"
docker restart mynodered
or build your own image:
FROM nodered/node-red:latest
RUN npm install --no-fund --no-update-notifier node-red-contrib-kafkajs-no-crash
The disk queue lives in the user directory (/data/kafkajs-nc-queue in the image). Keep /data on a volume (-v node_red_data:/data), otherwise queued messages are lost when the container is recreated. Inside a container, localhost means the container itself: use the broker's host name or IP address. With Docker Desktop, a broker on the host is reachable as host.docker.internal.
From source (contributors)
git clone https://github.com/patel-deepanshu/node-red-contrib-kafkajs-no-crash.git
cd node-red-contrib-kafkajs-no-crash
npm install
# link the working copy into your Node-RED user directory, then restart Node-RED
npm install /path/to/node-red-contrib-kafkajs-no-crash
See Development for the tests and CONTRIBUTING.md for the workflow.
Quick start
You need a Kafka broker. For a local test broker, run the official Apache Kafka image: docker run -d --name kafka -p 9092:9092 apache/kafka:3.9.1. It listens on localhost:9092 without security.
  1. Install the palette (see Installation).
  2. Add a producer. Drag an inject node, a kafka producer and a debug node into a flow and wire them in that order. Open the producer and click the pencil next to Broker. Brokers already says localhost:9092, so click Add. Set the producer's Topic to demo and leave everything else at its default.
  3. Add a consumer. Drag a kafka consumer and a debug node into the flow and wire them. Select the same broker, set Topics to demo and tick Read from the beginning when the group has no stored position. Click Deploy.
  4. Send something. Click the inject button. The producer's debug output shows msg.kafka.status: "sent" with the partition and offset. The producer creates the topic on first use if the broker allows automatic topic creation, which is Kafka's default: it waits the moment the broker needs for that, so even the first message is reported sent. Until the topic exists, the consumer shows unknown topic/partition · retry … and keeps trying. At its next retry (within a minute at most) it joins and prints the message.
  5. Watch it survive an outage. Run docker stop kafka and click inject a few times. The producer reports msg.kafka.status: "queued" (the first report can take a few seconds while kafkajs retries) and shows offline · 3 queued · retry …. Run docker start kafka. The queued messages are sent in order, and the consumer receives them.
Ready-made flows for every feature are in examples/. In Node-RED they are under Menu → Import → Examples → node-red-contrib-kafkajs-no-crash.
Nodes overview
Node (palette label) Type Input Output
kafka broker (configuration node) kafkajs-nc-broker – –
kafka producer kafkajs-nc-producer A message to send, or a control message (msg.action) A delivery report: the input msg with msg.kafka
kafka consumer kafkajs-nc-consumer Control messages only (msg.action) One message per Kafka record
kafka admin kafkajs-nc-admin An action and its parameters The input msg with the result in msg.payload
The broker node holds the connection settings: brokers, security, timeouts and reconnect behaviour. It does not open a connection itself. Every producer, consumer and admin node that uses it opens its own connection.
Broker configuration
Settings
The editor has three tabs. The Property column is the name in the flow JSON.
Tab Setting Property Default Description
– Name name Label shown in the editor.
Connection Brokers brokers localhost:9092 host:port list, separated by commas, semicolons or spaces. Port 9092 is used when none is given. Prefixes such as PLAINTEXT://, SSL://, SASL_SSL:// or SASL_PLAINTEXT:// are accepted, but security is set on the Security tab: a prefix that contradicts it (for example SASL_SSL:// with Use TLS off) logs a warning. Credentials (user:password@host) are refused here. IPv6 literals are not supported by kafkajs.
Connection Client ID clientId node-red Sent with every request. Visible in broker logs and used for quotas.
Security Mechanism authMechanism none none, plain, scram-sha-256 or scram-sha-512.
Security Username / Password credentials Both are required for SASL. They are stored encrypted in the credentials file, never in the flow.
Security Use TLS tls off Encrypts the connection. Needed for SSL and SASL_SSL listeners.
Security TLS configuration tlsConfig none Optional Node-RED TLS configuration node, for a private CA, a client certificate, a different server name or a self-signed certificate. Without one, the system CA certificates are trusted and the server certificate is verified.
Advanced Connect connectionTimeout 10000 ms Time to open the TCP/TLS connection (100 – 300000).
Advanced Authentication authenticationTimeout 10000 ms Time for the SASL handshake (100 – 300000).
Advanced Request requestTimeout 30000 ms Time to wait for each broker answer (1000 – 600000).
Advanced Retries retries 5 How often kafkajs itself retries one operation, such as connecting (0 – 50). Keep this small, because the nodes reconnect on their own afterwards. Produce requests are not retried by kafkajs: the producer resends them itself (see Retries).
Advanced First retry after initialRetryTime 300 ms First kafkajs retry delay (50 – 60000).
Advanced Longest retry wait maxRetryTime 30000 ms Longest kafkajs retry delay (100 – 600000).
Advanced Reconnect: first wait reconnectMin 1000 ms After a failed or lost connection, the node waits this long, then doubles the wait after each failure (±20 % jitter) (100 – 600000).
Advanced Reconnect: longest wait reconnectMax 60000 ms Upper limit of that wait (100 – 3600000; never below the first wait).
Advanced After auth/config errors authRetryMin 60000 ms Minimum wait after authentication, authorisation, TLS or configuration errors (1000 – 3600000). This avoids account lock-outs and log spam.
Advanced kafkajs log level logLevel warn off, error, warn, info or debug. See Logs.
Advanced Crash safety net safetyNet on See Safety net.
Numbers outside their range are clamped to it. A value that is not a number falls back to the default and logs a warning. The editor marks invalid values before you deploy.
Environment variables
Any field, including the username and password, can be ${NAME} to read the environment variable NAME, for example Brokers ${KAFKA_BROKERS}, Username ${KAFKA_USER} and Password ${KAFKA_PASSWORD}. Node-RED only replaces a reference that makes up the whole field. For nodes inside a flow, environment variables defined on that flow or its group in the editor work as well.
KAFKA_BROKERS="broker1:9093,broker2:9093" KAFKA_USER="node-red" KAFKA_PASSWORD="<secret>" node-red
# or with Docker:
docker run -e KAFKA_BROKERS=broker1:9093 -e KAFKA_USER=node-red -e KAFKA_PASSWORD=<secret> ... nodered/node-red
If a variable used in Brokers, Username or Password is not set, the configuration is invalid (environment variable KAFKA_PASSWORD is not set). If one used in a numeric field is not set, the default is used and a warning is logged. A reference inside a longer value, such as kafka-${REGION}:9092, is never replaced by Node-RED; it is reported as ${REGION} is only replaced by Node-RED when it is the whole value, and the editor marks it before you deploy.
When the configuration is broken (for example credentials missing)
Missing credentials were the crash that started this project. Here they are handled like any other configuration problem:
  • At deploy time the broker node logs every problem at once, for example Invalid Kafka broker configuration: SASL password is required. The editor already flags a missing username. A password cannot be checked in the editor.
  • Every node that uses this broker shows a red config error status and logs the same reason. None of them tries to connect until you fix the configuration and deploy again.
  • The producer keeps accepting messages and queues them (config error · 3 queued). They are sent after the fix. With the queue off, each message fails with done(err) instead.
  • The consumer does not start. Control messages fail with the reason.
  • The admin node fails each message with the reason, which goes to your catch node.
Other problems reported the same way: no brokers, an invalid host:port, credentials written into a broker address, an IPv6 literal, an unknown mechanism, an unset environment variable, a TLS configuration node that is missing or whose certificate/key files cannot be read. A certificate, key or CA that the TLS library refuses (for example a key that does not belong to the certificate) shows TLS: invalid cert, key or CA and is retried slowly. SASL/PLAIN without TLS is allowed but logs a warning, because the password then travels in clear text, and so is a broker prefix that contradicts the security settings (Brokers are given as SASL_SSL:// but "Use TLS" is off).
Recipes
Local broker without security (PLAINTEXT)
Brokers localhost:9092, Mechanism None, Use TLS off.
SASL/PLAIN or SCRAM on a SASL_PLAINTEXT listener
Mechanism SASL/PLAIN, SASL/SCRAM-SHA-256 or SASL/SCRAM-SHA-512, matching how the user was created on the broker. Enter the username and password, leave Use TLS off. Use this only on a trusted network: PLAIN sends the password in clear text, and the data is never encrypted.
SASL over TLS (SASL_SSL)
As above, with Use TLS on. If the broker certificate comes from a public CA, no TLS configuration node is needed.
TLS with a private CA (SSL listener)
  1. Turn Use TLS on, open the TLS configuration list and choose Add new tls-config….
  2. In the TLS configuration node, set CA Certificate to your CA file (ca.pem, upload it or point to a local file) and keep Verify server certificate ticked.
  3. Mechanism None, or a SASL mechanism for SASL_SSL.
If you connect by IP address, through a tunnel, or with a name that is not in the certificate, set Server Name in the TLS configuration node to the name the certificate was issued for. When the broker address is a host name, it is sent as the server name automatically.
Mutual TLS (client certificate)
In the TLS configuration node set Certificate (client certificate), Private Key, the Passphrase if the key is encrypted, and the CA Certificate. Leave Mechanism on None: the certificate is the identity.
Self-signed broker certificate
Preferred: put the self-signed certificate (or the CA that signed it) into CA Certificate, so the connection is still verified. For a test system only, you can untick Verify server certificate instead. The status TLS: self-signed cert · retry 60s tells you that one of the two is needed.
Cloud services
These settings follow each provider's published client settings. The underlying mechanisms (PLAIN, SCRAM, TLS, mutual TLS) are covered by this project's tests, but the services themselves are not. Check your provider's documentation for current host names and ports.
Service Brokers Mechanism Username / Password TLS
Confluent Cloud Bootstrap server, e.g. pkc-xxxxx.<region>.<cloud>.confluent.cloud:9092 SASL/PLAIN API key / API secret On, no TLS configuration
Redpanda Cloud Bootstrap server URL from the console SCRAM-SHA-256 (or -512, as created) User / password On, no TLS configuration
Aiven for Apache Kafka, SASL Service host with the SASL port SCRAM-SHA-256 Service user / password On, TLS configuration with the project CA (ca.pem)
Aiven for Apache Kafka, client certificate Service host with the default TLS port None – On, TLS configuration with ca.pem, service.cert, service.key
Azure Event Hubs (Kafka endpoint) <namespace>.servicebus.windows.net:9093 SASL/PLAIN $ConnectionString (literally) / the namespace connection string Endpoint=sb://… On, no TLS configuration
Amazon MSK, SASL/SCRAM Bootstrap brokers on port 9096 SCRAM-SHA-512 User / password from AWS Secrets Manager On, no TLS configuration
Amazon MSK, mutual TLS Bootstrap brokers on port 9094 None – On, TLS configuration with your client certificate and key
A SASL_SSL:// prefix copied from a provider's console is fine, but it does not configure anything: you still have to select the mechanism and turn on TLS (the broker node logs a warning when they do not match the prefix). $ConnectionString is not an environment variable reference: Node-RED only treats ${NAME} and $(NAME) that way. A recommended pattern is Brokers ${KAFKA_BROKERS}, Username ${KAFKA_USER} and Password ${KAFKA_PASSWORD}, with the values kept outside the flow.
Producer
The producer sends msg.payload (or a batch in msg.messages) to Kafka and passes the input message on as a delivery report once Kafka has acknowledged it, or once it is safely in the offline queue.
Input
Property Type Notes
msg.payload anything except undefined The message value. See How values are encoded. Ignored when msg.messages is an array.
msg.topic string Used when the node's Topic is empty.
msg.key string, Buffer, number, object Used when the node's Key is empty. Messages with the same key go to the same partition, which keeps their order.
msg.partition integer ≥ 0 Used when the node's Partition is empty. Without it, the partitioner chooses (from the key, if there is one).
msg.headers object (or Map) Kafka headers, { name: value }. A value may be an array for a header that repeats. Only used when Also send msg.headers is ticked (the default). Static headers win on equal names.
msg.timestamp number (epoch ms), Date, or a string of digits The Kafka timestamp. Defaults to the time the message reached the node, so messages sent later from the queue keep their original time. ISO date strings are rejected: use Date.parse() first.
msg.messages array A batch: see Batches.
msg.action string flush, reconnect, queue-status or queue-clear make the message a control action. Any other value is ordinary data: the message is sent.
Precedence: a Topic, Key or Partition set in the node is used for every message, and the matching msg property is ignored. Leave the field empty to take the value from the message. Headers are merged: msg.headers (if enabled) plus the node's static headers, and a static header wins when both have the same name.
Topic names may contain letters, digits, ., _ and - (at most 249 characters). An MQTT-style topic such as sensors/temp is rejected: set the node's Topic, or change msg.topic first.
JavaScript value Sent to Kafka as
string UTF-8 text, as is
Buffer, typed array (Uint8Array, ...), ArrayBuffer, DataView the bytes, unchanged
object or array JSON text
number, boolean, bigint text, e.g. 42, true
Date ISO 8601 text
null no value: a tombstone, which deletes the key on compacted topics
undefined, a function, a symbol, a circular object not sent: the message fails with done(err)
Keys follow the same rules, except that undefined, null and "" mean "no key". Header values follow them too: null/undefined header values are left out, and an array value sends the header once per element.
Batches (msg.messages)
Set msg.messages to an array to send several Kafka messages from one input message:
msg.messages = [
    { key: "a", value: { n: 1 } },
    { key: "b", value: { n: 2 }, headers: { source: "line-3" } },
    { topic: "audit", value: "batch sent" }
  • Each element is { value, key, headers, partition, timestamp, topic }. payload is accepted instead of value. msg.payload is ignored.
  • An element without topic uses the node's Topic or msg.topic. The other msg properties (key, headers, partition, timestamp) do not apply to the elements. Node settings still win, and element headers are only used when Also send msg.headers is ticked.
  • Every element is checked before anything is sent: one invalid element rejects the whole input.
  • The input gets one delivery report and one done(). The elements are sent in order, split into requests of at most Batch size messages and one topic each. If Kafka refuses part of the batch for good (for example message too large), the input fails with done(err). Parts that were already written stay written.
Control actions
Send a message whose msg.action is one of these values. Upper or lower case and spaces around the value do not matter (" Queue-Status" works too). These four values are reserved: a message carrying one of them is never sent to Kafka. Any other msg.action value is ordinary data, and the message is sent to Kafka normally.
msg.action What it does Output
flush Retry the connection now instead of waiting for the backoff, or start sending the queue now. none
reconnect Same as flush. none
queue-status Report the queue and connection state. msg.payload = statistics (see Monitoring)
queue-clear Delete every queued message without sending it (logged as a warning). Fails if the queue is off or not open yet. msg.payload = statistics
Output: delivery report
The input message is sent on with msg.kafka added. An existing msg.kafka is replaced, including the one a consumer set: keep a copy if you commit manually after producing (see Commit).
Property sent queued Meaning
msg.kafka.status "sent" "queued" sent: Kafka acknowledged the message. queued: stored in the offline queue. It will be sent later, and no second report follows.
msg.kafka.topic ✓ ✓ The topic (for a batch: the topic of its first message).
msg.kafka.partition when known – The partition.
msg.kafka.offset when known exactly – The offset, as a string.
msg.kafka.results ✓ – kafkajs' answer for the request(s): [{ topicName, partition, baseOffset, ... }]. Empty with Acknowledgement: none.
msg.kafka.count batches batches Number of Kafka messages, when the input carried more than one.
msg.kafka.queueSize – ✓ Messages in the queue after this one was added.
Messages that cannot be sent end with done(err). A catch node then receives the original message with msg.error. This happens for a missing or invalid topic, an undefined payload, a partition that does not exist, a message too large for the broker, a full queue with Reject new messages, or Kafka unreachable with the queue off.
A partition counts as missing only when the producer's list of the topic's partitions is current: its connection is less than 10 s old, or it reconnected to fetch the list because of exactly this partition. kafkajs keeps that list for up to 5 minutes: after partitions were added, a message for a new partition may not be written at first. The producer then reconnects at once, which fetches the current list, and sends that message again (logged at debug level; messages arriving meanwhile wait behind it). A partition confirmed missing this way is remembered for one minute: a flow that keeps sending to a partition that does not exist causes at most one such reconnect per partition per minute, and the other messages for it fail at once. Other partitions of the topic are not affected, so a partition that was really added is always used.
Settings
– Broker broker The broker configuration node (required).
Message Topic topic empty Empty: use msg.topic.
Message Key key empty Empty: use msg.key.
Message Partition partition empty Empty: msg.partition, or the partitioner.
Message Static headers headers none Name/value list. A name used twice becomes a repeated header.
Message Also send msg.headers useMsgHeaders on Untick it if msg.headers holds something else, for example the HTTP headers that http in and http request nodes put there.
Delivery Acknowledgement acks all all (acks=-1, all in-sync replicas), leader (acks=1) or none (acks=0, fire and forget).
Delivery Ack timeout ackTimeout 30000 ms How long the broker may wait for the replicas (100 – 600000).
Delivery Compression compression none none, gzip, snappy or lz4.
Delivery Partitioner partitioner default default (same key-to-partition mapping as the Java client) or legacy (kafkajs 1.x mapping).
Delivery Batch size batchSize 100 At most this many messages per produce request (1 – 10000). Used both for messages that pile up while a request is in flight and for sending the queue.
Delivery Let the broker create missing topics allowAutoTopicCreation on Only has an effect if the broker allows it (auto.create.topics.enable). While on, the node waits up to about 2.5 s for a new topic to be created (see New topics below).
Offline queue Offline queue queueMode disk disk, memory or off. See Offline queue.
Offline queue Directory queueDir empty Empty: kafkajsNcProducerQueueDir from settings.js, else kafkajs-nc-queue. Relative paths are relative to the Node-RED user directory. Disk mode only.
Offline queue Queue name queueName empty Empty: the node's id. Disk mode only.
Offline queue Maximum size queueMaxMB 100 MB 0 = unlimited. Fractions are allowed.
Offline queue Maximum messages queueMaxMessages 0 0 = unlimited.
Offline queue When full queueOverflow drop-oldest drop-oldest (remove the oldest queued messages, with a warning) or drop-newest (reject the new message with done(err)).
Offline queue Expire after queueMaxAgeHours 0 Queued messages older than this many hours are moved to the dead-letter file instead of being sent. 0 = never.
Offline queue Sync every write to disk queueFsync on A message is only reported queued once it is on disk, even if the power fails. Disk mode only.
Any setting can be ${NAME}; Node-RED only replaces it when it is the whole field. If a variable used in Topic, Key, Partition or the static headers is not set, every message fails with a clear error, so nothing is sent to an unintended topic. In Directory or Queue name, an unset variable, or a ${NAME} inside a longer path such as ${HOME}/queues, makes the offline queue unavailable (logged at deploy) instead of creating a directory with that literal name. In Acknowledgement, Compression and Offline queue a warning is logged and the default is used; in the other settings the default is used.
Flows saved by a development version before 1.0 may still contain idempotent: true. The option no longer exists: it is ignored, and the node logs one warning at deploy (see Retries for why).
Acknowledgements, retries and compression
  • acks. all is the safe default: Kafka confirms only after every in-sync replica has the message. leader is faster but can lose a message if the leader fails right after answering. none never waits for an answer, so the report says sent as soon as the request went out, and msg.kafka.results is empty.
  • Retries. Kafka errors that usually clear up within a second or two (a partition leader moving during a broker restart or a leader rebalance, NOT_ENOUGH_REPLICAS, a request timeout) are retried by the node: it sends the whole request again, up to 3 times, after pauses of about 0.2, 0.6 and 1.6 s (logged at debug level). If it still fails, the messages go to the offline queue (or fail with done(err) with the queue off) and the node reconnects. kafkajs' own produce retry is switched off: in kafkajs 2.2.4 a retried request can report success without having written the messages for partitions whose leader moved to a broker that had already answered, and nothing reports the loss. Resending the whole request can only cause a duplicate, never a silent loss. The broker node's Retries setting still applies to connecting.
  • New topics. While a broker creates a topic automatically it answers unknown topic for a moment (typically 0.1 to 1 s). With Let the broker create missing topics on, the node sends the request again after 0.05, 0.1, 0.2, 0.4, 0.8 and 0.8 s (debug log only), so the first messages to a new topic are reported sent. If the topic still does not exist after that (about 2.5 s), the broker does not create topics: the message fails (msg.topic) or is queued (the node's Topic), and for one minute further messages for that topic do not wait again. With the option off, unknown topic is not waited for. All pauses of one request together never exceed 5 s.
  • No idempotent producer. kafkajs' idempotent mode only works with its own produce retry switched on, which is exactly the retry that can lose messages, so this palette does not offer it. Earlier development versions had an Idempotent producer option; a flow that still sets it loads normally, the option is ignored, and a warning says so. De-duplicate on the consuming side instead (see below).
  • Compression. gzip is built into kafkajs. Snappy (through snappyjs) and LZ4 (compressed through lz4js) are registered automatically, and both are pure JavaScript. Both are decompressed with size checks: a batch that claims more than its compressed size can hold, or more than 256 MiB, is refused before any memory is allocated, so a crafted batch cannot exhaust the memory of Node-RED. The end-to-end tests check that Kafka's own Java client can read what this palette writes and that this palette reads what the Java client writes, for all three. zstd is not available.
Ordering and delivery guarantees
  • Order. Each producer node sends one request at a time, in the order the messages arrived. That includes messages that went through the offline queue: older queued messages are always sent before newer ones. Kafka keeps the order per partition, so give messages whose order matters the same key (or a fixed partition). Each request carries only one topic, so the order across topics is kept as well. Separate producer nodes are independent of each other.
  • At least once. sent means Kafka acknowledged the message. queued means it is stored (on disk when Sync every write is on). If the connection breaks after Kafka wrote a message but before its answer arrived, or a retried request had partly been written, the messages are sent again, so in rare cases a consumer sees a duplicate. Messages are never dropped silently, except by the queue limits and expiry you configure. Consumers that must not process a message twice should de-duplicate, for example with a unique id in a header.
Things to watch out for
  • Consumer → producer. A consumer's output carries msg.topic, msg.key, msg.partition, msg.headers and msg.timestamp. Wired straight into a producer with empty settings, these are reused, and msg.partition may not exist in the target topic. Set the producer's Topic (and Partition, if needed), or delete those properties first.
  • HTTP headers. http in and http request nodes put HTTP headers in msg.headers. Untick Also send msg.headers, or delete msg.headers, unless you want them as Kafka headers.
  • Right after a deploy, until the first connection is up, messages are queued (with the queue on). Their report says queued, and they are sent a moment later. With Offline queue: Off they fail with done(err) instead.
  • An idle producer does not notice an outage until it sends again: it shows connected until then. kafkajs first tries to reach the broker again for the next message (the broker node's Retries), so its queued report and the yellow status can take a few seconds.
Offline queue (store-and-forward)
The offline queue makes sure messages are not lost while Kafka cannot be reached. More detail, including the file format and recovery procedures, is in docs/OFFLINE-QUEUE.md.
How it works
              connected and the queue is empty ("live")
  msg ─► check & convert ───────────────────────────────► Kafka ─► report "sent"
              │  invalid content: done(err), never queued
              │  not connected, or older messages still queued ("backlog")
        offline queue ─► report "queued"
              └─ after reconnecting: oldest first, in batches ─► Kafka
  1. Every message is checked and converted first. A message with invalid content fails at once with done(err) and is never queued.
  2. Live: while connected, with an empty queue, messages are sent directly, one request at a time. Messages that arrive meanwhile are batched (up to Batch size). The report is sent.
  3. Backlog: while Kafka is not connected, every message is appended to the queue, the report queued is sent and the message is done. This also covers the time right after a deploy, an authentication problem and a broken broker configuration.
  4. When a live send fails because of the connection (broker down, timeout, network), or a Kafka error that usually clears up by itself is still there after 3 retries, the failed messages and every message waiting behind them move to the queue, in order, and the node reconnects.
  5. When Kafka is slow (a request has been in flight for more than 3 s) or more than 10000 messages wait in memory, new messages go to the queue, so they are safe on disk instead of piling up in memory.
  6. After the reconnect, the queue is sent oldest-first, in batches of Batch size, one topic per request. Messages that arrive meanwhile are queued behind it. When the queue is empty, the node switches back to live mode and the queue's message files are deleted.
  7. A queued message that Kafka refuses for good is moved to the dead-letter file so that it cannot block the messages behind it.
Queue modes
disk (default) memory off
While Kafka is unreachable Messages appended to files Messages kept in memory Each message fails with done(err)
Survives a redeploy / restart / reboot Yes No (a warning says how many were discarded) –
Limits, overflow, expiry Yes Yes –
Dead letters dead-letter.jsonl Counted and logged. The last 100 are kept in memory: queue-status returns them in msg.payload.deadLetters. Lost on restart. –
Use it for Data you cannot afford to lose Short outages, read-only file systems, sensitive data that must not touch the disk Callers that handle failures themselves (catch node)
Where the files live
Messages are stored in <directory>/<queue name>/:
  • Directory: the node's Directory setting. If empty, kafkajsNcProducerQueueDir from settings.js is used, and if that is empty too, kafkajs-nc-queue. A relative path is relative to the Node-RED user directory. A leading ~ means the home directory.
  • Queue name: the node's Queue name setting, or the node's id if empty. Characters other than letters, digits, ., _ and - are replaced by _.
So by default a producer with id 3f2a9c1e5b7d4a10 stores its queue in ~/.node-red/kafkajs-nc-queue/3f2a9c1e5b7d4a10/ (/data/kafkajs-nc-queue/... in the Docker image).
An administrator can move all queues that use the default, for example to a larger disk, in settings.js:
module.exports = {
    kafkajsNcProducerQueueDir: '/var/lib/node-red/kafka-queue',
File Content
seg-<16 digits>.jsonl The queued messages, one JSON object per line, in segments of about 4 MB. A segment is deleted once everything in it has been sent.
cursor.json How far the queue has been sent. Replaced atomically.
dead-letter.jsonl Messages that could not be delivered (see below). Rotated to dead-letter.1.jsonl at 50 MB, replacing the previous .1 file; a warning says how many bytes of older dead letters that deleted.
When the queue is empty, the segment and cursor files are deleted. The dead-letter file stays.
Limits, overflow and expiry
  • Maximum size (default 100 MB) and Maximum messages (default unlimited) limit what is waiting. The size counts the stored JSON, so binary payloads take about a third more than their raw size (base64).
  • When full: Drop the oldest removes the oldest queued messages to make room and logs a warning with the number dropped. Reject new messages fails the new message with done(err). An input message that is larger than the whole limit on its own is always rejected.
  • Expire after (hours, 0 = never): when the queue is sent, messages older than this are moved to the dead-letter file instead of being sent. Use it when old data is worthless, for example sensor readings that are only useful for a day.
Dead-letter file
A queued message that Kafka refuses for good cannot be sent at all. Examples: message too large, a partition that does not exist, an invalid or unauthorised topic taken from the message, a damaged queue line, or an expired message. Such a message is appended to dead-letter.jsonl in the queue directory, a warning is logged, and sending continues with the next message. A batch that fails 5 times in a row with an error the node does not recognise is checked message by message in the same way. Each line looks like this:
{"ts":"2026-10-28T12:05:00.000Z",
 "error":{"name":"KafkaJSProtocolError","message":"...","kind":"message","reason":"MESSAGE_TOO_LARGE","retriable":false,"type":"MESSAGE_TOO_LARGE"},
 "record":{"v":1,"t":"telemetry","tf":0,"ts":1793188800000,
           "m":{"k":{"s":"sensor-1"},"v":{"s":"{\"temp\":21.5}"},"h":{"source":{"s":"line-3"}},"ts":"1793188800000"}}}
record.t is the topic and record.ts the time the message was queued. record.m holds the key (k), value (v), headers (h), partition (p) and Kafka timestamp (ts). Values are { "s": "text" }, { "b": "<base64>" }, or null for a tombstone. To resend a dead letter, read the file with a file in node (one message per line), rebuild the message in a function node and pass it to a producer.
Monitoring the queue
Send msg.action = "queue-status" to the producer, for example from an inject node every minute. The producer outputs:
  "size": 57, "bytes": 18432, "segments": 1, "droppedTotal": 0, "deadLettered": 0,
  "oldestTs": 1793188800000,
  "state": "waiting", "mode": "backlog", "queueMode": "disk",
  "queueDir": "/home/pi/.node-red/kafkajs-nc-queue/3f2a9c1e5b7d4a10",
  "pending": 0, "lastError": "ECONNREFUSED 127.0.0.1:9092"
Field Meaning
size, bytes Messages and bytes waiting in the queue.
segments Number of segment files (disk mode).
droppedTotal Messages removed by Drop the oldest since the node started.
deadLettered Messages moved to the dead-letter file since the node started.
oldestTs When the oldest queued message arrived (epoch ms), when known.
state Connection state: idle (starting, the queue is not open yet), connecting, connected, waiting (to reconnect), stopped (no broker / invalid configuration) or closing.
mode live (sending directly) or backlog (going through the queue).
queueMode disk, memory, or off (also when the queue could not be opened).
queueDir The queue directory (disk mode), else null.
pending Messages waiting in memory: behind the request in flight (live mode), or for the queue to open.
queueError, lastError Only present after a problem: why the queue could not be opened; the last connection error.
deadLetters Memory mode only: the last 100 dead letters, oldest first, each { ts, error, record } like a line of dead-letter.jsonl. They exist nowhere else and are lost on restart.
A switch node on msg.payload.size can then raise an alarm, for example when more than 10000 messages are waiting or oldestTs is more than an hour old.
Redeploy, restart, crash and power loss
Event disk memory
Redeploy, or Node-RED stopped normally The node waits up to 5 s for a request in flight, then writes everything not yet sent to the queue (Stored N unsent message(s) in the offline queue while closing; if some could not be stored or are still being written to a slow disk, the warning Closing: X unsent message(s) stored in the offline queue, Y could not be stored ..., Z still being written says so). The new instance waits until the old one has really closed the queue, then sends it first. On a very slow disk it starts without the queue after 12 s and opens it as soon as the old instance is done; it never writes the directory at the same time. Queued messages are discarded with a warning. Messages still waiting in memory fail with done(err).
Node-RED crashes or is killed (kill -9) Messages reported queued are safe. A few already-sent messages may be sent again (duplicates). Messages that had not yet received a report may be lost, as in any Node-RED flow. Everything waiting is lost.
Power loss With Sync every write to disk on (default), every message reported queued is safe. With it off, the last messages written may be lost. Everything waiting is lost.
Node deleted The files stay on disk. A warning names the directory if messages were left. Lost.
Directory or Queue name changed, or the queue turned off The messages stay in the old directory and are not sent. A warning names it (N unsent message(s) are left in the offline queue <dir>, which this node no longer uses ...); set the old values again to send them. Lost.
Node copied or imported The copy gets a new id and so a new, empty queue. The old directory is not sent. –
A half-written last line from a crash is removed when the queue is opened again. That message had not been reported as queued.
Operational tips
  • Give production producers a Queue name. Then the queue survives replacing the node, for example deleting it and importing it again. Two producers must never use the same queue name: the second one logs an error, shows connected · queue unavailable and runs without a queue. A copy of a node keeps its Queue name, so give the copy a name of its own.
  • Orphaned queue. About 10 s after a disk queue opens, the producer looks at the other directories next to its own and warns once about those that hold messages no producer in the deployed flows uses (Found N offline queue(s) under <directory> with unsent messages that no producer in the deployed flows uses: <name> (<size>), ...). Producers that are disabled or in a disabled flow count as using their queue. If a node lost its queue because it got a new id, set its Queue name to the old directory's name (the old node id); the messages are then sent on the next deploy. A listed directory may also belong to a flow you will import again or to another Node-RED instance that uses the same directory: delete it only when you are sure no producer needs those messages.
  • One Node-RED per directory. The lock that prevents two producers from sharing a directory only works inside one Node-RED process. Never point two Node-RED instances at the same queue directory, for example on a shared network drive. Use a local disk.
  • Persistent storage. In containers, keep the user directory (or kafkajsNcProducerQueueDir) on a volume.
  • Size the limits. A Raspberry Pi with a small SD card should have a Maximum size that leaves room for the system. Expire after stops very old data from being sent after a long outage.
  • Plain text on disk. The queue holds message contents unencrypted. Protect the directory with file permissions or disk encryption, or use the memory mode for sensitive data. See SECURITY.md.
  • Version control. If your user directory is a git repository, add kafkajs-nc-queue/ to .gitignore.
  • Clearing a queue: send msg.action = "queue-clear", or delete the directory while Node-RED is stopped.
Consumer
The consumer subscribes to topics as a member of a consumer group and sends one message per Kafka record.
Output
Property Type Notes
msg.payload string, Buffer, any (parsed JSON), or null The value, in the chosen Payload format. null for a tombstone.
msg.topic string The topic.
msg.key string, Buffer or null The key, in the chosen Key format. null when there is none.
msg.partition number The partition.
msg.offset string The offset. A string, because offsets can exceed JavaScript's safe integers.
msg.timestamp number Kafka timestamp in ms since the epoch.
msg.headers object { name: value }. Values are strings (or Buffers with Header values: Buffers). A repeated header is an array, and a header without a value is null.
msg.kafka object { groupId, topic, partition, offset, timestamp, highWatermark }. highWatermark (string) is the offset after the last message in the partition when the batch was fetched, so highWatermark - offset - 1 is roughly the lag. Keep msg.kafka if you commit manually: a producer node replaces it with its delivery report.
Formats. UTF-8 string (default). Buffer, which keeps binary data such as Avro or Protobuf intact; each Buffer is a private copy. Parsed JSON: a value that is not valid JSON is not sent. Instead a catch node receives it with the raw text in msg.payload, and the consumer carries on with the next record. With automatic commits the bad record is committed like any other, since reading it again would fail the same way. Keys and header values can be strings or Buffers.
Subscription
  • Topics: a list separated by commas or spaces, e.g. orders, payments. Each name must be a valid Kafka topic name.
  • Topics is a regular expression: the field is then one JavaScript regular expression, either plain (^orders-.*) or in slashes with flags (/^orders-.*$/i). The g and y flags are ignored. Caveat: the expression is matched against the topics that exist when the consumer starts. A matching topic created later is only consumed after msg.action = "restart", a redeploy, or the next reconnect.
  • Group ID: consumers with the same group ID share the partitions, and Kafka remembers per group how far it has read. Give two nodes different group IDs if both should receive every message. If empty, the group ID is node-red-<node id>. It stays the same across restarts and deploys, so the node continues where it stopped. Copying or importing the node creates a new id and therefore a new group: set a Group ID if the position must survive that. Inside a subflow the node id is <subflow instance id>-<node id>, so each instance of the subflow has a group of its own, which also stays the same across restarts.
  • Read from the beginning when the group has no stored position (fromBeginning) only matters for a group without a committed offset for a partition, typically a new group. It then starts with the oldest message instead of only new ones. It does not rewind an existing group: use seek, or the admin action resetOffsets while the consumer is stopped.
  • Start consuming on deploy (autoStart, default on): untick it to start the node in the stopped state, waiting for msg.action = "start".
  • A topic that does not exist yet is retried with the normal backoff (status unknown topic/partition · retry …, and a warning rather than an error in the log, since it is often created a moment later), and consuming starts at the first retry after the topic was created: at most Reconnect: longest wait (60 s by default) later. By default the consumer does not create topics itself.
  • A regular expression that matches no topic, or a member of a group whose partitions all went to other members, shows the yellow status connected · no partitions instead of a green one. With a regular expression a warning is logged too.
Commit modes and delivery guarantees
Kafka stores, per group and partition, the offset of the next record to read (the committed offset). When that is stored decides what happens when Node-RED stops while records are being processed.
Mode When the position is stored If Node-RED crashes Use it for
Automatically (default) Every Every ms (default 5000; 0 = only at the end of each batch), every Or every records (0 = off), and at the end of each fetched batch, as soon as the record was handed to the flow Records handed to the flow since the last stored position (at most the last fetched batch) are delivered again (at least once, with possible duplicates). The position does not wait for your flow, so a record that was still being processed when its position was stored is not delivered again. Telemetry, dashboards, anything where an occasional gap or duplicate is fine
Manually Only when you send msg.action = "commit" with the record's msg.kafka Every record not committed is delivered again after a restart, reconnect or rebalance (at least once) Processing that must not lose records. Make it tolerate duplicates.
The committed position is the record's offset + 1. Committing a record also commits every earlier record of the same partition. Commit in order per partition: committing an older offset after a newer one moves the group back, so records are delivered again (nothing is lost).
Control messages
The consumer's input only takes control messages. msg.action is case-insensitive. Every control message completes with done(), so a complete node can follow it. A failed one goes to catch nodes. Control messages are not passed to the output.
msg.action Parameters What it does
pause – Stop fetching all subscribed topics, keeping the group membership. It takes effect after the record being delivered. A pause sent before the consumer has joined its group is applied as soon as it joins, and it is re-applied after every reconnect and rebalance.
resume – Continue fetching.
stop – Leave the group and disconnect. The node does not reconnect until start. Status stopped.
start – Start a stopped consumer. Does nothing if it is already running.
restart – Disconnect and connect again now, which also picks up new topics that match a regular expression.
seek msg.payload = { topic, partition, offset } Continue reading a partition from another offset. topic may be left out when the node subscribes to a single topic. offset is a number, a string of digits, "earliest" (the oldest record still stored) or "latest" (only new records). See Seek.
commit msg.kafka = { groupId, topic, partition, offset } Store the position after this record (manual mode). msg.kafka must be the one this consumer set on its output. Uses msg.topic, msg.partition and msg.offset when msg.kafka is missing. See Commit.
Examples, each in a function node wired to the consumer's input:
// rewind partition 0 of "orders" to the oldest record
return { action: "seek", payload: { topic: "orders", partition: 0, offset: "earliest" } };
// manual commit: after processing, send the record back with action "commit"
msg.action = "commit";   // msg.kafka is still the one the consumer set
A typical at-least-once flow: consumer (Commit: Manually) → your processing → a change node that sets msg.action to commit → a link out back to the consumer's input. A catch node on the processing step can log failures: the uncommitted record is delivered again after the next restart.
Seek
Before seeking, the consumer looks up the partition's current offsets with a short admin connection (at most 15 s):
  • "earliest" (also "beginning") becomes the partition's oldest stored offset and "latest" (also "end") its end. kafkajs itself would treat those names as "no position" and apply Read from the beginning instead.
  • A number outside the partition's offsets is refused (seek: offset N is outside the offsets of orders[0] (low to high); ...): Kafka would otherwise jump to its default position and store it, even in manual mode, silently replacing the position your flow committed.
  • A seek only works while the consumer is connected and not rebalancing, for a partition assigned to this member of the group; the error lists the assigned partitions.
With Commit: Automatically the new position is stored right away; with Manually only when you commit.
Commit
msg.kafka must be the one this consumer set on its output message. A commit is refused when its groupId is not this consumer's group or its topic is not one the consumer subscribes to, and fields are never mixed between msg.kafka and msg. This matters when the processing includes a producer node: the producer replaces msg.kafka with its delivery report (the topic, partition and offset it wrote to), and committing that would store a position for the wrong topic. Keep a copy before the producer and put it back before the commit:
// function node before the producer
msg.consumed = msg.kafka;
// function node after the producer, wired back to the consumer's input
msg.kafka = msg.consumed;
A commit fails (Commit not stored: the Kafka consumer was stopping. ...) when the consumer stopped or restarted before Kafka stored the position. The records after the last stored position are then delivered again.
Back-pressure with pause and resume
The consumer hands each record to the flow and immediately goes on with the next one: it does not wait for your flow to finish. If the processing is slower than Kafka (a slow database, an HTTP API with rate limits), pause the consumer while too much is in progress and resume it later. One way is a counter in flow context:
// function node right after the consumer; output 1 → processing, output 2 → consumer input
const inFlight = (flow.get("inFlight") || 0) + 1;
flow.set("inFlight", inFlight);
return [msg, inFlight === 500 ? { action: "pause" } : null];
// function node at the end of the processing; output → consumer input
const inFlight = Math.max(0, (flow.get("inFlight") || 0) - 1);
return inFlight === 50 ? { action: "resume" } : null;
If a message can fail along the way, decrease the counter on the error path (for example after a catch node) as well, or the consumer stays paused.
Settings
Subscription Topics topics Required. A list, or one regular expression.
Subscription Topics is a regular expression topicIsRegex off
Subscription Group ID groupId empty Empty: node-red-<node id>.
Subscription Read from the beginning ... fromBeginning off Only for a group without a stored position.
Subscription Start consuming on deploy autoStart on
Output Payload payloadFormat string string, buffer or json.
Output Key keyFormat string string or buffer.
Output Header values headersFormat string string or buffer.
Commit Commit commitMode auto auto or manual.
Commit Every autoCommitInterval 5000 ms 0 = only at the end of each batch (0 – 86400000).
Commit Or every autoCommitThreshold 0 Records; 0 = off (0 – 1000000000).
Advanced Session timeout sessionTimeout 30000 ms A member without a heartbeat for this long is removed from the group (1000 – 3600000). The broker limits it too.
Advanced Heartbeat interval heartbeatInterval 3000 ms Must be lower than the session timeout. A value that is too high is replaced by a third of the session timeout, with a warning (100 – 3600000).
Advanced Rebalance timeout rebalanceTimeout 60000 ms (1000 – 3600000)
Advanced Max per partition maxBytesPerPartition 1048576 Bytes per partition per fetch.
Advanced Max per fetch maxBytes 10485760 Bytes per fetch.
Advanced Max wait maxWaitTimeInMs 1000 ms How long the broker may hold a fetch when there is no new data (0 – 300000). Stopping the node waits for that fetch, so keep it short.
Advanced Concurrency partitionsConsumedConcurrently 1 Partitions processed at the same time (1 – 100). Records of one partition always arrive in order. Above 1, records of different partitions may be interleaved.
Advanced Let the broker create missing topics allowAutoTopicCreation off
Compression: records compressed with gzip, snappy or lz4 are decoded. A topic that contains zstd-compressed records makes the consumer fail with compression codec missing. It then retries slowly, and the log explains why.
Admin
The admin node runs one Kafka admin operation per input message. The action comes from the node's Action setting, or from msg.action (case-insensitive) when the setting is set by msg.action. If both are present, the node setting wins. The parameters come from msg.payload.
Action action empty One of the actions below, used for every message. Empty (set by msg.action): take it from msg.action.
Timeout timeout 30000 ms Limit for each message, counted from its arrival: waiting behind earlier messages and connecting are included (100 – 600000). setOffsets and resetOffsets always get at least 15 s.
  • The node connects on the first message and then stays connected. Messages are handled one after another, in arrival order. At most 1000 mess
Version: 1.0.0
Updated 3 weeks ago
  • kafkajs-nc-broker
  • kafkajs-nc-producer
  • kafkajs-nc-consumer
  • kafkajs-nc-admin
  • kafka
  • kafkajs
  • apache-kafka
  • producer
  • consumer
  • admin
  • offline
  • store-and-forward
  • queue
  • sasl
  • scram
  • tls
  • iot
  • edge
