node-red-contrib-kafka-suite 0.0.6
BETA — A comprehensive Kafka integration for Node-RED with producer, consumer, admin, and Schema Registry nodes. Dual backends (kafkajs / @confluentinc/kafka-javascript) and presets for Confluent Cloud, AWS MSK, Azure Event Hubs, Aiven, and Redpanda. Plea
npm install node-red-contrib-kafka-suite
npm version npm downloads license Node-RED Sponsor
Status: 0.0.4 — Beta. Functionally complete and end-to-end tested against five local Kafka setups (Confluent CP, Redpanda PLAINTEXT, Redpanda SASL_SSL, mTLS Aiven-style, and Keycloak + Redpanda OAUTHBEARER/OIDC) on both client backends (kafkajs, @confluentinc/kafka-javascript). It has not yet been validated against live managed services with paid accounts (Confluent Cloud, AWS MSK, Azure Event Hubs, Aiven). Please try it and file issues at https://github.com/blanpa/node-red-contrib-kafka-suite/issues — bug reports, reproductions, and editor-UX feedback are very welcome.
A comprehensive Apache Kafka integration for Node-RED with full producer, consumer, admin, and Schema Registry support. Built around a dual-backend abstraction layer (kafkajs + @confluentinc/kafka-javascript), with service presets for the major managed Kafka offerings and OAuth 2.0 / OIDC (OAUTHBEARER) authentication.
  • Producer — single + batch mode, message keys, headers, explicit partition selection, compression (GZIP, Snappy, LZ4, ZSTD), delivery confirmation as msg.kafka on the success output.
  • Consumer — consumer groups, auto/manual commit, pause/resume via control input, JSON / UTF-8 / Buffer payload formats, configurable concurrency.
  • Admin — listTopics, createTopic, deleteTopic, describeCluster, listGroups, describeGroup, fetchTopicOffsets, resetOffsets, deleteGroup.
  • Schema Registry — Confluent wire format (magic byte + schema id) for Avro, JSON Schema and Protobuf. Optional auto-registration of schemas from the producer when msg.schemaDefinition is provided.
  • Dual backend — pick kafkajs (pure JS, runs everywhere) or confluent (native librdkafka, higher throughput, Kafka 4.0 ready) per broker config node.
  • Service presets — Confluent Cloud, AWS MSK (IAM + SCRAM), Azure Event Hubs, Aiven, Redpanda, and self-hosted.
  • Authentication — SASL/PLAIN, SCRAM-SHA-256/512, OAUTHBEARER (OAuth 2.0 / OIDC with the password and client_credentials grants, Strimzi-style), mutual TLS (mTLS), or unauthenticated.
  • Connection management — MQTT-style shared connection per broker config node, ref-counted producer/consumer/admin lifecycle, auto-reconnect with exponential backoff, status badges propagated to the editor.
  • Error handling via Node-RED's standard error channel — attach a catch node scoped to the producer/admin/consumer to handle failures (invalid topic, schema-registry errors, unknown admin action, etc.).
Architecture
The producer, consumer, and admin nodes never talk to Kafka directly. They all share one connection through the kafka-suite-broker config node, which delegates to one of two interchangeable backend adapters. Your flow logic is identical regardless of the backend or the Kafka distribution behind it.
flowchart LR
    subgraph NR["Node-RED flow"]
        P["kafka-suite-producer"]
        C["kafka-suite-consumer"]
        A["kafka-suite-admin"]
    end
    B["kafka-suite-broker (config)"]
    SR["kafka-suite-schema-registry (config)"]
    P -->|references| B
    C -->|references| B
    A -->|references| B
    P -.->|optional| SR
    C -.->|optional| SR
    B --> ADP{"Backend adapter"}
    ADP -->|kafkajs| JS["kafkajs (pure JS)"]
    ADP -->|confluent| RD["librdkafka (native)"]
    JS --> K[("Kafka / Redpanda cluster")]
    RD --> K
    SR -->|HTTP| REG[("Schema Registry")]
  • One broker connection, ref-counted. The broker node opens the connection when the first child node needs it and closes it when the last one is removed (MQTT-style), with auto-reconnect and exponential backoff.
  • Adapter abstraction. Every backend implements the same interface (lib/adapter-interface.js), so producer/consumer/admin code is backend-agnostic — switching kafkajs ↔ confluent is a one-field change in the config node.
Or install via the Node-RED palette manager (search for node-red-contrib-kafka-suite).
Optional dependencies
# Schema Registry support (Avro / JSON Schema / Protobuf)
npm install @kafkajs/confluent-schema-registry
# High-performance native backend (alternative to kafkajs)
npm install @confluentinc/kafka-javascript
# Compression codecs for the kafkajs backend
# Snappy and LZ4 are auto-installed as optionalDependencies — install
# manually only if your environment skipped them (e.g. `npm install --no-optional`).
npm install kafkajs-snappy kafkajs-lz4
# ZSTD support for the kafkajs backend (requires a working C/C++ toolchain;
# not installed automatically because the upstream package's native build
# is fragile on newer Node versions). Use the `confluent` backend instead
# for hassle-free ZSTD.
npm install @kafkajs/zstd
@confluentinc/kafka-javascript builds a native module — make sure your platform has a working C/C++ toolchain (build-essential on Debian/Ubuntu, Xcode CLI tools on macOS, MSVC build tools on Windows). On ARM/Raspberry Pi the pure-JS kafkajs backend is recommended.
The kafkajs library only ships GZIP natively. The Snappy / LZ4 codec packages are pulled in automatically as optionalDependencies and must be present whenever a topic's batches use one of those codecs — even if your producer is configured for none, the consumer needs the codec to decode batches written by other producers in the cluster. ZSTD requires the optional @kafkajs/zstd package and a working native build toolchain. The confluent backend handles all four codecs natively without extra packages.
Quick start
A minimal produce → consume loop against a local broker:
  1. Drag in a broker config node. Set Brokers to localhost:9092, Backend kafkajs, Auth None, and deploy.
  2. Wire an inject node → kafka-suite-producer. On the producer set Topic demo. Configure the inject to send msg.payload = { "hello": "world" }.
  3. Wire a kafka-suite-consumer → debug node. On the consumer set Topics demo, Start from earliest, Format json.
  4. Deploy. Every inject publishes a message to demo; the consumer decodes it and the debug pane prints { hello: "world" }.
A ready-made flow exercising all nodes ships at examples/test-all-nodes.json — import it via the Node-RED menu → Import.
In the Node-RED editor the three flow nodes are grouped under a dedicated Kafka Suite category in the left-hand palette. The two config nodes (kafka-suite-broker, kafka-suite-schema-registry) have no palette entry — they are created on demand from the config dropdown of a flow node and live under Configuration nodes in the sidebar.
flowchart TB
    subgraph PAL["Palette: Kafka Suite"]
    end
    subgraph CFG["Configuration nodes"]
        B["kafka-suite-broker"]
        SR["kafka-suite-schema-registry"]
    end
    PAL -.->|created on demand| CFG
kafka-suite-broker (config node)
Shared connection used by all other nodes. Manages the Kafka client lifecycle with automatic connect/disconnect based on the registered child nodes. If the cluster is unreachable, connecting is retried with exponential backoff (Init Retry, doubling up to Max Retry). Producers, consumers and admin nodes start as soon as the broker connects; if their own setup fails (missing topic, ACL denied, ...) they retry with backoff as well.
Setting Description
Service Preset Auto-fills auth and SSL for managed services (Confluent Cloud, AWS MSK, Azure Event Hubs, Aiven, Redpanda, self-hosted).
Brokers Comma-separated list of broker addresses (host:port or PROTOCOL://host:port; the prefix is stripped, security comes from Auth). Validated in the editor. IPv6 literals are not supported.
Backend kafkajs (default, pure JS) or confluent (native librdkafka).
Auth None, SASL/PLAIN, SCRAM-SHA-256, SCRAM-SHA-512, OAUTHBEARER, SSL/mTLS.
OAUTHBEARER Token URL, grant (password / client_credentials), client id/secret, username/password, scope, audience, per-endpoint TLS verify. See OAUTHBEARER.
Use TLS For SASL mechanisms: SASL_SSL (default) or, unchecked, SASL_PLAINTEXT.
SSL CA cert (whenever TLS is on), client cert, client key, passphrase (mTLS), rejectUnauthorized.
Sends messages to Kafka topics. Default partitioner is the modern Java-compat murmur2 partitioner; set KAFKAJS_NO_PARTITIONER_WARNING=1 to silence the upgrade notice when running on kafkajs.
Inputs (on msg):
Property Type Description
payload string | Buffer | object | Array Message value. Arrays trigger batch mode.
topic string Target topic (overrides the node configuration).
key string | Buffer Message key for partitioning. Buffers are sent as binary keys.
partition number Explicit partition number (otherwise key-based hashing).
headers object Message headers as a key/value map. Read from the property configured in Headers from (default msg.headers). Numbers/booleans are stringified, objects JSON-encoded, null values dropped.
schemaDefinition object If a Schema Registry is attached and autoRegister is enabled, the producer registers this schema and encodes with it. Registrations are cached, so sending it on every message costs no extra round-trip.
schemaType string AVRO, JSON, or PROTOBUF. Defaults to AVRO.
Output (on success): original msg plus msg.kafka = { topic, partition, offset, timestamp, key, results } where results is the raw RecordMetadata[] array returned by the adapter (useful for batch sends across multiple partitions).
Errors are raised through Node-RED's standard error channel — catch them with a catch node scoped to the producer.
Setting Description
Headers from msg property holding the Kafka headers (default headers). msg.headers is also set by http in; use e.g. kafkaHeaders behind HTTP nodes so request headers are not forwarded to Kafka.
Auto-create Let the broker create missing topics (default on).
Consumes messages from Kafka topics using consumer groups.
Setting Description
Topics Comma-separated list of topics (each name is validated).
Group ID Consumer group ID. Auto-generated if empty.
Start from latest (only new messages) or earliest (replay from the start).
Format string (UTF-8 decode), json (parse JSON), or raw (raw Buffer).
Key format string (UTF-8 decode) or raw (Buffer, for binary keys).
Headers to msg property receiving the Kafka headers (default headers). Use e.g. kafkaHeaders when the message goes on to HTTP nodes.
Auto Commit Enable/disable automatic offset commits. When off, commit each processed message (see below).
Concurrency Number of partitions to consume in parallel.
Session Timeout / Heartbeat Consumer-group session timeout and heartbeat interval (default 30000 / 3000 ms).
Output (on msg):
payload any Decoded message value.
topic string Source topic.
key string | Buffer Message key (Buffer with key format raw).
partition number Source partition.
offset string Message offset.
timestamp string Message timestamp.
headers object Message headers.
commit() function Manual commit callback (only present when auto-commit is off).
Control input: send msg.action = "pause" or msg.action = "resume" to pause/resume consumption from upstream nodes. A pause survives a consumer restart.
Manual commit: with auto-commit off, either call msg.commit() in a function node, or route the processed message back into the consumer with msg.action = "commit" (it still carries topic, partition and offset). The second way also works after the message was serialized or copied, where a function on msg would be lost.
Crash recovery: if the client library gives up on the consumer (a non-retriable error), the node shows consumer crashed and rebuilds the consumer with exponential backoff instead of silently staying idle.
kafka-suite-admin
Performs Kafka cluster administration. Pick a fixed Action in the node config, or leave it on from msg.action and set msg.action to one of:
Action Required msg properties Description
listTopics — List all topics.
createTopic topic, optional config.partitions, config.replicationFactor Create a topic. Partitions and replication factor default to the broker defaults (-1), which also works on managed clusters that require RF 3.
deleteTopic topic (string or array) Delete one or more topics.
describeCluster — Get controller, broker list, cluster id.
listGroups — List consumer groups.
describeGroup groupId Get group details.
fetchTopicOffsets topic Get partition offsets for a topic.
resetOffsets groupId, topic Reset consumer-group offsets.
deleteGroup groupId (string or array) Delete one or more consumer groups.
deleteTopic, deleteGroup and resetOffsets are rejected unless Allow destructive actions is checked. New admin nodes start with it off; nodes saved before the option existed keep working as before.
kafka-suite-schema-registry (config node)
Confluent Schema Registry connection. When referenced by a producer or consumer node, messages are automatically encoded/decoded using the Confluent wire format. Supports Avro, JSON Schema, and Protobuf. Requires @kafkajs/confluent-schema-registry.
Setting Description
URL Schema Registry URL (http:// or https://). Validated in the editor.
Auth Optional basic auth (username/password).
Auto Register If checked, the producer registers msg.schemaDefinition under the topic's value subject before encoding.
Backend selection
Backend Pros Cons
kafkajs (default) Pure JS, no native deps, runs on ARM/Raspberry Pi/Alpine, simple install. Largely unmaintained since 2023; no Kafka 4.0 protocol support.
confluent Actively maintained by Confluent, Kafka 4.0 ready, higher throughput. Requires a working C++ toolchain at install time, larger footprint.
Pick the backend in the broker config node. The confluent backend requires @confluentinc/kafka-javascript to be installed in the same Node-RED environment.
Managed-service configuration
Confluent Cloud
  • Service preset: Confluent Cloud
  • Auth: SASL/PLAIN — API Key as username, API Secret as password.
  • SSL is enabled automatically.
AWS MSK (IAM)
  • Service preset: AWS MSK (IAM) — selects SASL/OAUTHBEARER.
  • ⚠️ Not yet natively supported. AWS MSK IAM authenticates with SigV4-signed tokens (via aws-msk-iam-sasl-signer-js), which this package does not bundle yet. The built-in OAUTHBEARER support targets OAuth 2.0 / OIDC token endpoints (see OAUTHBEARER), not IAM signing. If you need MSK IAM, please open an issue.
AWS MSK (SCRAM)
  • Service preset: AWS MSK (SCRAM)
  • Auth: SASL/SCRAM-SHA-512.
Azure Event Hubs
  • Service preset: Azure Event Hubs
  • Auth: SASL/PLAIN — username $ConnectionString, password = the connection string.
  • Port: 9093.
Aiven
  • Service preset: Aiven
  • Auth: mutual TLS — CA cert, client cert, and client key downloaded from the Aiven console.
Redpanda
  • Service preset: Redpanda
  • Fully Kafka-protocol-compatible; same configuration as a self-hosted cluster. SASL/SSL is supported the same way as for Apache Kafka. For a SASL listener without TLS, uncheck Use TLS (SASL_PLAINTEXT).
OAUTHBEARER (OAuth 2.0 / OIDC)
Select Auth → SASL/OAUTHBEARER to obtain a bearer token from an OAuth 2.0 token endpoint. This is the equivalent of the Strimzi org.apache.kafka.common.security.oauthbearer.OAuthBearerLoginModule with the JaasClientOauthLoginCallbackHandler:
Strimzi connect.properties Broker field
oauth.token.endpoint.uri Token URL
oauth.grant.type Grant (client_credentials or password)
oauth.client.id Client ID
oauth.client.secret Client Secret (optional)
oauth.password.grant.username Username (password grant)
oauth.password.grant.password Password (password grant)
— Scope / Audience (optional)
The token is cached and refreshed automatically before it expires.
sequenceDiagram
    autonumber
    participant N as Broker node
    participant T as Token provider (in-process)
    participant I as OAuth 2.0 / OIDC token endpoint
    participant K as Kafka broker
    N->>T: connect()
    alt token cached and valid
        T-->>N: cached access_token
    else needs refresh
        T->>I: POST grant_type = password or client_credentials
        I-->>T: access_token (+ expires_in)
        Note over T: cache until ~30s before expiry
        T-->>N: access_token
    end
    N->>K: SASL/OAUTHBEARER handshake (bearer token)
    K->>K: validate JWT (signature / issuer / audience, via JWKS)
    K-->>N: authenticated
  • kafkajs backend — supports both the password and client_credentials grants; the token is fetched in-process via the built-in token provider (no extra dependency).
  • confluent backend — client_credentials uses librdkafka's native OIDC (sasl.oauthbearer.method=oidc); the password grant is kafkajs-only (librdkafka's native OIDC has no password grant).
Verified end-to-end against a real OIDC provider — see the OAUTHBEARER E2E test.
Development
Setup
git clone https://github.com/blanpa/node-red-contrib-kafka-suite.git
cd node-red-contrib-kafka-suite
npm install
Unit tests
npm test
The unit suite exercises the adapters, the broker/preset config logic, the HTML editor defaults, schema registry integration, and the Node-RED node behaviour through node-red-node-test-helper.
Multi-broker E2E smoke test
The repository ships with a real end-to-end smoke test that runs against four locally-spawned Kafka clusters and both client backends:
Local target Port Auth Purpose
Confluent CP (cp-kafka + Schema Registry) 9092 / 8081 none Apache Kafka + SR baseline
Redpanda 9192 none Redpanda PLAINTEXT
Aiven-sim (Redpanda) 9094 mutual TLS Mimics Aiven's mTLS-only access
Redpanda SASL 9095 SASL_SSL + SCRAM-SHA-256 Mimics Confluent Cloud / Aiven SASL access
# 1. Generate self-signed test certificates (CA + server + client, PEM)
./scripts/gen-test-certs.sh
# 2. Start the baseline stack (Confluent CP + Schema Registry + Node-RED)
docker compose up -d
# 3. Start the extra Redpanda PLAINTEXT broker
docker compose -f docker-compose.redpanda.yml up -d
# 4. Start the mTLS Aiven-sim and the SASL_SSL Redpanda
docker compose -f docker-compose.aiven-sim.yml up -d
# 5. Bootstrap the SCRAM users on the SASL broker
./scripts/setup-redpanda-sasl.sh
# 6. Run the smoke test against all targets and both backends
BROKERS_CP=localhost:9092 \
BROKERS_REDPANDA=localhost:9192 \
BROKERS_AIVEN_SIM=localhost:9094 \
BROKERS_REDPANDA_SASL=localhost:9095 \
SCHEMA_REGISTRY=http://localhost:8081 \
BACKENDS=kafkajs,confluent \
KAFKAJS_NO_PARTITIONER_WARNING=1 \
node test/integration/multi-broker-smoke.js
Expected output: ALL E2E SMOKE TESTS PASSED after exercising admin, single
  • batch produce, consume, and (where the Schema Registry is reachable) an Avro round-trip on every target × backend combination.
⚠️ The files in test/certs/ are self-signed and for local testing only. They are git-ignored. Never deploy them.
OAUTHBEARER (OAuth 2.0 / OIDC) E2E test
A dedicated stack verifies the full SASL/OAUTHBEARER handshake — token acquisition and broker authentication — against a real OIDC provider:
Service Role
Keycloak (quay.io/keycloak/keycloak) OIDC IdP; realm kafka, client kafka-client, user alice
Redpanda Broker with native OIDC OAUTHBEARER validation (JWKS from Keycloak)
# kafkajs backend (password + client_credentials grants)
npm run test:oauth
# both backends (confluent uses native librdkafka OIDC, client_credentials)
BACKENDS=kafkajs,confluent npm run test:oauth
# leave the stack up afterwards for manual poking
KEEP_UP=1 npm run test:oauth
The runner starts Keycloak + Redpanda, waits for health, then executes test/integration/oauth-smoke.js inside the compose network (so it reaches keycloak:8080 and redpanda-oauth:19096 by hostname, independent of host port publishing). For each grant it fetches a real bearer token, asserts the JWT audience, then runs an admin → produce → consume round-trip over SASL/OAUTHBEARER. Expected output: ALL OAUTHBEARER E2E TESTS PASSED.
The same credentials map directly to the broker node's OAUTHBEARER fields: token URL http://localhost:8088/realms/kafka/protocol/openid-connect/token, client kafka-client / secret kafka-client-secret, user alice / alice-password — handy for manual testing in the Node-RED editor against the host-published broker port 9096 (with KEEP_UP=1).
Docker Compose (full stack with Node-RED)
docker compose up
Then open Node-RED at http://localhost:1880 and import the example flow from examples/test-all-nodes.json.
Reporting issues
Bug reports, reproduction steps, and editor-UX feedback are extremely welcome — this is a beta release and live-account validation against managed services has not happened yet. Please open an issue at https://github.com/blanpa/node-red-contrib-kafka-suite/issues.
When filing a bug, including the following helps a lot:
  • Node.js version (node -v)
  • Node-RED version
  • Backend in use (kafkajs or confluent) and broker distribution
  • The minimal reproducing flow as a JSON export
  • The complete stack trace from the Node-RED debug pane
Sponsor this project
This package is developed and maintained in my own time. If it saves you some, consider supporting it:
Sponsor on GitHub Buy Me a Coffee
Apache License 2.0 — see LICENSE and NOTICE.
Copyright 2026 blanpa
Contributing and forks
Pull requests are welcome, including large ones. If you are planning a bigger change — a dependency migration, a restructure, new nodes — please open an issue first. We are happy to discuss it and to land substantial work here; that is usually less effort than maintaining a parallel package, and it keeps a single place for users to report bugs.
If you do publish a fork under its own package name, please also rename the Node-RED node type IDs (for example myprefix-kafka-suite-*) and use your own palette category. Node-RED refuses to register a node type that is already claimed, so identical type IDs make it impossible to install both packages side by side.
Version: 0.0.6
Updated 1 month, 2 weeks ago
Rating: 5.0 3
24 in the last week
  • kafka-suite-broker
  • kafka-suite-producer
  • kafka-suite-consumer
  • kafka-suite-admin
  • kafka-suite-schema-registry
  • kafka
  • apache-kafka
  • confluent
  • producer
  • consumer
  • schema-registry
  • avro
  • streaming
  • iot
