node-red-contrib-kafka-manager 0.6.2
Node-RED implements Kafka manager with associand associated .
npm install node-red-contrib-kafka-manager
Node Red for working with apache kafka, a streaming product. First initial release using kafka-node .
  • Kafka Broker
  • Kafka Admin
  • Kafka Commit
  • Kafka Consumer
  • Kafka ConsumerGroup
  • Kafka Offset
  • Kafka Producer
  • Kafka Rollback
Has a test GUI which allows topics to be added.
Special features:
  • Generic topic(s) for a consumer using regex which dynamically adds new topics as they are defined
  • For consumer add/remove topics (not persisted)
  • Convert "/" to "." to assist with interfaces to other queueing technologies
Note: all nodes run in debug mode for 111 messages then turns off.
Kafka Broker
Defines the client interface to kafka. One can add process.env for hosts with
process.env.atesthosts='[{"host":"atesthost1","port":1234},{"host":"atesthost2","port":4321}]';
in settings.js
Kafka Broker Kafka Broker Options
Kafka Admin
Provide the ability to process administration tasks such as create and list topic.
Following topics commnads or via GUI allowed:
  • describeCluster
  • describeDelegationToken
  • describeReplicaLogDirs
  • listConsumerGroups
  • listGroups
  • listTopics
Plus following topics commands allowed where paramaters are payload:
  • alterConfigs, alterReplicaLogDirs, createAcls,createDelegationToke
  • createPartitions, createTopics, deleteAcls, deleteConsumerGroups, deleteRecords
  • deleteTopics, describeAcls, describeConsumerGroups, describeGroups, describeLogDirs, describeTopics * electPreferredLeaders, expireDelegationToken, incrementalAlterConfigs, listConsumerGroupOffsets, renewDelegationToken
Admin
Kafka Commit
If msg._kafka exists and the consumer associated with the message is not on autocommit, it issues commit for the consumer that had produced the message. Sends to OK or Error port depending on state. Note, as Kakfa keeps giving messages to consumer regardless if commit being outstanding, the commit may commit many in-flight messages. Haven't identified a method of readily preventing this behavour without complications.
Kafka Consumer
Consumer of topic messages in kafka which are generated into node-red message. Provides types of base and high level. If wildcard selected then topics are regex patterns which are dynamically made active (or removed) when available. A check is performed once every minute for chanaes to topics.
Kafka Consumer Kafka Consumer Options Kafka Consumer Fetch Kafka Consumer Encoding
Kafka Consumer Group
Kafka Consumer Group Kafka Consumer Group Options
Kafka Offset
Get various offsets from Kafka. Which type are set via msg.action or msg.topic. msg.payload states the types of options.
Kafka Offset
Kafka Producer
Converts a node-red message into a kafka messages. Provides types of base and high level.
Kafka Producer
Kafka Rollback
If msg._kafka exists and the consumer associated with the message is not on autocommit, it closes the consumer. This effectively rolls back the message in Kafka plus ensures the message cannot be automatically handed to the the consumer. It is expected that the message or problem is fixed and the consumer opened again for processing.
Simple Web Admin Panel
Simple Web page monitor and admin panel
Web
Run the following command in the root directory of your Node-RED install or via GUI install
Tests
Test/example flow in test/generalTest.json
Tests
Version
0.6.1 Major change in compression and add deadletter q
0.5.0 add consumer wildcard topics + topics / to . along with fix on to/from/json
Author
Peter Prib
Version: 0.6.2
Updated 4 years, 2 months ago
License: GPL-3.0
Rating: 4.0 4
154 in the last week
  • Kafka Admin
  • Kafka Broker
  • Kafka Commit
  • Kafka Consumer
  • Kafka Consumer Group
  • Kafka Offset
  • Kafka Producer
  • Kafka Rollback
  • admin
  • adminstration
  • broker
  • consumer
  • consumerGroup
  • kafka
  • manager
  • offset
  • producer
  • topic
  • wildcard
  • streaming
