node-red-contrib-kafka-client 0.1.0
Node-RED Kafka Consumer and Producer
npm install node-red-contrib-kafka-client
This node can be used in order to produce and consume messages to Kafka. It is highly depends on 'kafka-node' library. Consists three nodes.
  • kafka-broker
  • kafka-producer
  • karka-consumer
Note: This library only supports 'plaintext' and 'tls' authorization. SASL authorization will develop upcoming days
Input Parameters
kafka-broker
Name (Optional)
Name wanted to be shown in Node
Hosts
Host names comma delimited (Multiple host is provided)
Use TLS
Check if tls security is required for Kafka Cluster
CA Certs (Optional)
CA Root certificate path defined in Kafka Cluster
Client Cert (Optional)
Client cert path created by openssl derived from Private Key (pem)
Private Key (Optional)
Private Key path created by openssl (pem)
Passphare (Optional)
Passphrase of created private Key
Self Sign
Check if want to be allowed untrusted certificates
kafka-producer
Name (Optional)
Name wanted to be shown in NodeRename your node
Broker
Broker which is wanted to be connect
Topic
Topic name of selected broker which is wanted to be consume
Require Ack
Default value is 1. 0 can be past if Acknowledge is not required.
Ack Timeout
Timeout of acknowledge response.
Attiributes
Can be selected if compression is important
kafka-consumer
Name (Optional)
Broker
Topic
From Offset
'latest', 'none' or 'earliest' options can be selected
Out of Range Offset
  1. Example JSON here
{"topic":"TOPIC_NAME","value":"DENEME","offset":16638,"partition":0,"highWaterOffset":16639,"key":null,"timestamp":"2020-08-19T08:58:27.866Z"}
Screenshots
kafka-broker
kafka-consumer
kafka-flow
kafka-producer
Version: 0.1.0
Rating: 3.9 8
123 in the last week
  • kafka-consumer
  • kafka-producer
  • kafka-broker
  • kafka-producer
  • kafka-consumer
  • kafka-broker
  • kafka-node
  • big-data
  • data
