node-red-contrib-jsontransform 0.1.0
Node-RED node that filters only required fields from objects in a JSON Array
npm install node-red-contrib-jsontransform
Node-RED node that transforms all records in a JSON Array to another JSON Array by renaming the field names based on a configuration provided.
Added "Config JSON" to specify the configuration for transformation. example: { "Id":"Identifier", "FName":"FirstName" } The above example provides a config for transforming the fields "Id" and "FName" to "Identifier" and "FirstName" in all the records in a JSON Array.
Version: 0.1.0
Updated 9 years, 2 months ago
22 in the last week
  • JSONTransform
  • transform
  • json
  • jsontransform
  • cache
  • Febin Joy
