node-red-contrib-jsonscada 0.1.0
Node-RED nodes for bidirectional integration with JSON-SCADA over its NODE-RED driver WebSocket protocol.
npm install node-red-contrib-jsonscada
Node-RED nodes for bidirectional integration with JSON-SCADA over its NODE-RED protocol driver. Drag nodes to move process data in and out of JSON-SCADA — no broker required.
From the Node-RED palette manager, search for node-red-contrib-jsonscada, or:
Requires a running JSON-SCADA NODE-RED driver instance (see src/node-red-driver).
Node Purpose
jsonscada-server (config) The shared, auto-reconnecting WebSocket connection to the driver. Set host, port, TLS, and the access token (the connection's password).
jsonscada tag in Subscribe to live tag updates (all / by tag / by group1). Emits msg.payload = value, msg.topic = tag, msg.point = full tag object.
jsonscada tag out Inject values (single via address + msg.payload, or bulk array). Optionally declares a commandable point.
jsonscada cmd in Receive operator commands for points this flow owns; reply with a result.
jsonscada cmd out Command any commandable JSON-SCADA tag; second output carries the ack.
jsonscada read Request a one-shot snapshot of tags/topics.
Quick start
  1. Add a jsonscada tag out node, create a jsonscada-server config pointing at your driver (default 127.0.0.1:51931), set an Address like PLANT1~LINE2~temperature, and wire an inject/function producing a numeric msg.payload. The tag auto-creates in JSON-SCADA (if autoCreateTags is on).
  2. Add a jsonscada tag in node, subscribe by topic PLANT1, and wire a debug node to watch live updates flow back.
Examples
Import from the Node-RED menu → Import → Examples → node-red-contrib-jsonscada:
  • 01 ingest — HTTP API → tag out (auto-created tags)
  • 02 notify — tag in (alarms) → notification
  • 03 actuate — commandable point + cmd in → actuate → result
  • 04 command out — buttons commanding a field breaker tag
  • 05 raw websocket — the same ingest using only built-in nodes (no palette)
Protocol
These nodes speak the versioned JSON WebSocket protocol documented in the driver's PROTOCOL.md. The config node checks the driver's protocolVersion and reports a mismatch.
GPL-3.0-or-later, as part of the JSON-SCADA distribution.
Version: 0.1.0
Updated 2 months, 2 weeks ago
License: GPL-3.0-or-later
144 in the last week
  • jsonscada-server
  • jsonscada tag in
  • jsonscada tag out
  • jsonscada cmd in
  • jsonscada cmd out
  • jsonscada read
  • json-scada
  • scada
  • iiot
  • automation
