node-red-contrib-json-rpc-processor 1.0.1
A Node-RED node to process JSON RPC 2.0 messages
npm install node-red-contrib-json-rpc-processor
A Node-RED node to process and validate JSON RPC 2.0 messages.
Purpose
JSON RPC 2.0 is a lightweight request/response protocol that is well suited to process incoming messages in the Node-RED environement.
There are already JSON RPC 2.0 related nodes like node-red-contrib-jsonrpc. That node wraps the node-jsonrpc2 library which bakes the transport (http, tcp) within the library.
I wanted tp create a node that is transport agnostic to leverage the different transport nodes that are available within Node-RED's core library (http, tcp, udp, websockets, mqtt). The result is node-red-contrib-json-rpc-processor, it's role is to parse and validate incoming messages as well as format responses.
The node is used in a similar fashion as some of the parser nodes like the JSON node, one instance is used after the transport to parse and validate the message and another instance is used before the response to format the outgoing message.
server
Specifying methods
In order to work, the node needs to know which method it needs to process and validate. The methods to process are passed to the node using the msg.methods property. Each method has a JSON Schema attached to it that will allow the node to validate the method's parameters. Here is a simple example that defines two methods:
  "getRandomAnimal": {
    "request": {
      "title": "getRandomAnimal",
      "type": "object"
  "add": {
    "request": {
      "title": "add",
      "type": "object",
      "properties": {
        "number1": {
          "type": "number",
          "minimum": 0
        "number2": {
          "type": "number",
          "minimum": 0
      "required": [
        "number1",
        "number2"
In the above example, we define two methods, getRandomAnimal and add. The getRandomAnimal method doesn't have any parameters so we simply define an empty schema ({"type": "object"}) in the request property of the method.
For the add method we specify two parameters, number1 and number2 which are both of type number with a minimum value of 0. Note also that both properties are required.
Processing an incoming message
When processing an incoming message, if the message is valid the parameters will be sent on the first output as msg.payload. If the message is not valid (badly formatted JSON RPC 2.0 or parameters that don't validate against the JSON Schema) a JSON RPC 2.0 error will be sent out of the second output which can be sent directly as a response.
A valid message will also have it's method in msg.rpcMethod and extra information like the id of the message in msg.rpcData.
The rpcMethod would typically be used to route the message to a function, flow or subflow using a switch node.
Processing the parameters
The actual processing of the parameters can be done any way the user wants, could be a normal flow, a function, a subflow etc. The result needs to be in msg.payload and sent to the second node-red-contrib-jsonrpc-processor where the response will be formatted. It is important the message still has the properties originating from the first node (msg.rpcData and msg.rpcMethod) for the node to work properly.
If the user needs to generate an error he can use a function node with the usual node.error('Error message', msg) mechanism along with a catch node connected to the second node-red-contrib-jsonrpc-processor. The node will automatically format the error.
Version: 1.0.1
Updated 6 years ago
6 in the last week
  • json-rpc-processor
