node-red-contrib-json-filter-advanced 1.0.28
A Node-RED node for interactive JSON filtering with selectable output structure and template editor.
npm install node-red-contrib-json-filter-advanced
A powerful Node-RED node for interactive JSON filtering with a visual tree interface, template editor, and flexible output options.
  • Interactive Tree View: Visual representation of JSON structure with expandable/collapsible nodes
  • Flexible Property Selection: Select any message property (msg.payload, msg.data, etc.) as the data source
  • Template Editor: Build and test JSON structures directly in the editor
  • Multiple Output Modes: Choose between Object, Flattened, or Array output formats
  • Parent/Child Selection: Smart selection logic that automatically includes parent paths
  • Real-time Preview: See your JSON structure as you work with live messages
  • Professional UI: Clean, Node-RED-styled interface with intuitive controls
Or install via the Node-RED palette manager.
Basic Setup
  1. Drag the "json filter advanced" node into your flow
  2. Double-click to open the configuration dialog
  3. Select your data source:
    • Use Latest Message: Work with live data from your flow
    • Use JSON Template: Define a JSON structure for testing
Configuration Options
Property Selection
  • Property: Choose which message property to filter (default: payload)
  • Supports nested properties like data.items, response.body, etc.
Output Modes
  • Object: Returns the filtered data as a nested object structure
  • Flattened: Returns key-value pairs with dot-notation keys
  • Array: Returns an array of the selected leaf values
Data Sources
  • Use Latest Message: Automatically loads the structure from the last message received
  • Use JSON Template: Define your own JSON structure for testing and development
Tree Navigation
  • Expand/Collapse: Click the arrow icons or use the "Expand All"/"Collapse All" buttons
  • Selection: Check boxes to select specific fields
  • Parent/Child Logic: Selecting a parent automatically includes its children
  • Visual Feedback: Selected items are highlighted with different colors
Examples
Example 1: Basic Filtering
Input Message:
  "user": {
    "name": "John Doe",
    "email": "[email protected]",
    "address": {
      "street": "123 Main St",
      "city": "New York",
      "zip": "10001"
  "timestamp": "2024-01-01T00:00:00Z"
Selected Paths: user.name, user.email, user.address.city
Output (Object mode):
  "user": {
    "name": "John Doe",
    "address": {
      "city": "New York"
Output (Flattened mode):
  "user.name": "John Doe",
  "user.email": "[email protected]",
  "user.address.city": "New York"
Output (Array mode):
["John Doe", "[email protected]", "New York"]
Example 2: Working with Arrays
Input Message:
  "products": [
      "id": 1,
      "name": "Laptop",
      "price": 999.99,
      "category": "Electronics"
      "id": 2,
      "name": "Mouse",
      "price": 29.99,
Selected Paths: products.name, products.price
  "products": [
      "name": "Laptop",
      "price": 999.99
      "name": "Mouse",
      "price": 29.99
Use Cases
API Response Filtering
Filter large API responses to extract only the data you need, reducing payload size and improving performance.
Data Transformation
Convert between different JSON structures while preserving the relationships between fields.
Development and Testing
Use the template editor to prototype JSON structures before connecting to live data sources.
Message Routing
Extract specific fields for routing decisions or conditional processing.
Technical Details
Node Properties
  • name: Optional display name for the node
  • property: Message property to filter (supports dot notation)
  • mode: Output format (object/flattened/array)
  • selectedPaths: Array of selected JSON paths
  • sourceType: Data source type (message/template)
  • templateData: JSON template for testing
Performance Considerations
  • Maximum JSON size: 1MB
  • Maximum tree nodes: 1000
  • Debounced updates for better performance
  • Efficient tree rendering with virtual scrolling
Security Features
  • Input validation and sanitization
  • XSS prevention in UI components
  • Safe JSON parsing with error handling
  • Size limits to prevent memory issues
Error Handling
The node includes comprehensive error handling:
  • Invalid JSON structure detection
  • Property path validation
  • Size limit enforcement
  • User-friendly error messages
  • Graceful fallback behavior
Requirements
  • Node-RED 2.0.0 or higher
  • Node.js 14.0.0 or higher
Contributing
Contributions are welcome! Please feel free to submit issues or pull requests.
MIT License - see LICENSE file for details.
Changelog
1.0.26
  • Improved output mode terminology (Object/Flattened/Array)
  • Enhanced property selection with typedInput component
  • Better error handling and validation
  • Performance optimizations
1.0.25
  • Added property selection support
  • Modular code architecture
  • Enhanced security features
  • UI improvements
1.0.0
  • Initial release
  • Interactive tree view
  • Template editor
  • Multiple output modes
  • Parent/child selection logic
Version: 1.0.28
Updated 1 year, 5 months ago
  • json-filter-advanced
  • json
  • filter
  • interactive
  • tree
  • template
  • editor
  • data
  • extraction
  • transformation
  • parsing
